Lotus Elan
Update... Re: Stil no luck--- Deep vibration at idle problem
PostPost by: davidwinegar » Tue Sep 12, 2006 12:20 pm
I just checked the gear box mount and it seems to be ok--I also don't
see any play in the drive shaft--it is secure. I tried to start it
and it turns over but the thumping sound is so bad that I just did not
want to keep it running as there is certainly something wrong. Anyway
to check the flywheel without pulling the engine out?
David
--- In ***@***.***, "les mellor" <[email protected]> wrote:
Loose flywheel.
----- Original Message -----
To: ***@***.***
Sent: Tuesday, September 12, 2006 1:34 PM
Subject: [LotusElan.net] Re: Stil no luck--- Deep vibration at
idle problem
Hi Tony,
Thanks for the reply. Just to clarify the situation with my car is
that the ibration is at its worst when it is in neutral and at idle.
At speed it seems to be about normal. So if I understand correctly,
this does not point to the prop shaft as the car would rightly need to
be moving for this to be a problem.
I guess I am back to looking at the mounts.
David
--- In ***@***.***, "Tony Vaccaro" <[email protected]> wrote:
> The only way the drive shaft vibration would not be felt is if the
car is
> not moving...and in neutral. Is is being felt when the car is NOT
moving?
> I had a very deep vibration on my Elan..tried everything. Got to the
point
> where I could remove the prop shaft in under 20 minutes. Had it
balanced
> many times.but it was only when I took it to a new digital
balancer..that it
> got fixed. It was out of balance.
> Tony Vaccaro
> _____
> From: ***@***.***lto:***@***.***
On Behalf
> Of david_c_w
> Sent: Monday, September 11, 2006 3:33 PM
> To: ***@***.***
> Subject: [LotusElan.net] Re: Stil no luck--- Deep vibration at idle
problem
> HI Rod,
> Just wonderng would the u-joint be vibrating even when not in gear?
> Also, how the heck do I get at it to check it?
> Still haven't yet had a chance to check the other mounts so
those are
> also possibilities.
> David
> --- In ***@***.*** <mailto:lotuselan%40yahoogroups.com>
ps.com, Rod
> Bean <[email protected]> wrote:
> > David,
> > Try the u-joint in the drive shaft. It's not easy to remove if
that's
> > the problem but I suspect it might be.
> > Rod Bean
> > S1 & S2 Elans
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.1.405 / Virus Database: 268.12.3/445 - Release Date:
11/09/2006
davidwinegar
PostPost by: "Roger Sieling" » Tue Sep 12, 2006 1:40 pm
David,
I suppose we're running out of possibilities. What I'm beginning to
wonder is that we've been looking for something banging into some other
object, and that does have to happen to get the noise, but I'm starting
to wonder if maybe your engine has gone onto 3 cylinders at idle and the
noise is a result of the engine moving excessively (shaking) from uneven
idle.
So, have you been playing w/ the carbies or maybe broken a spark plug
lead while getting at the engine mount underneath the carbs. Or, did you
remove the carbs to make it easier to get at the mount and now have an
air leak at the O-ring seals to the manifold. Also, if you removed the
carbs, the carbs need to be resyncronized, as the connector between the
two throttle shafts will never go back the exact same way. If that is
the case, it could be that one carb is completely closed at idle and you
are only running on 2 cylinders at idle. Any of those things will cause
rough idle, that might seem to clear at higher engine speeds.
>> ***@***.*** 9/12/2006 8:16 AM >>>
David
Loose flywheel.
To: ***@***.***
idle problem
Hi Tony,
idle.
correctly,
to
David
the
car is
NOT
moving?
the
point
balanced
balancer..that it
> Tony Vaccaro
> _____
> From: ***@***.***
[mailto:***@***.***
On Behalf
> Of david_c_w
> To: ***@***.***
idle
problem
> HI Rod,
gear?
those are
> also possibilities.
> David
ps.com, Rod
> > David,
that's
> > Rod Bean
> > S1 & S2 Elans
11/09/2006
"Roger Sieling"
PostPost by: tvacc » Tue Sep 12, 2006 2:49 pm
No.you really cannot check the flywheel completely. I am beginning to think
you have a rod bolt coming loose and the rod is starting to move off the
crank.
Tony Vaccaro
_____
Of david_c_w
Sent: Tuesday, September 12, 2006 8:17 AM
To: ***@***.***
Subject: [LotusElan.net] Update... Re: Stil no luck--- Deep vibration at
idle problem
David
--- In ***@***.*** <mailto:lotuselan%40yahoogroups.com> ps.com, "les
Loose flywheel.
To: ***@***.*** <mailto:lotuselan%40yahoogroups.com> ps.com
idle problem
Hi Tony,
David
car is
moving?
point
balanced
balancer..that it
> Tony Vaccaro
> _____
> From: ***@***.*** <mailto:lotuselan%40yahoogroups.com> ps.com
[mailto:***@***.*** <mailto:lotuselan%40yahoogroups.com> ps.com]
On Behalf
> Of david_c_w
problem
> HI Rod,
those are
> also possibilities.
> David
ps.com, Rod
> > David,
that's
> > Rod Bean
> > S1 & S2 Elans
11/09/2006
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
71 Spyder Elan, ElanGTS, 93 Caterham, 05 Elise,
99 Elise190, 91 M100 Elan, 74 Europa, 72 Europa JPS #15, 68 Elan Coupe RHD
tvacc
PostPost by: lotuselanman » Tue Sep 12, 2006 9:22 pm
LOOSE FLYWHEEL !!
To: ***@***.***
Sent: Wednesday, September 13, 2006 12:45 AM
Subject: RE: [LotusElan.net] Update... Re: Stil no luck--- Deep vibration at idle problem
crank.
Tony Vaccaro
_____
Of david_c_w
To: ***@***.***
idle problem
David
> Loose flywheel.
> From: david_c_w
idle problem
> Hi Tony,
> David
> car is
> moving?
> point
> balanced
> balancer..that it
> > Tony Vaccaro
> > _____
> On Behalf
> > Of david_c_w
> problem
> > HI Rod,
those are
> > also possibilities.
> > David
> ps.com, Rod
> > > David,
that's
> > > Rod Bean
> > > S1 & S2 Elans
11/09/2006
Version: 7.1.405 / Virus Database: 268.12.3/445 - Release Date: 11/09/2006
lotuselanman
PostPost by: lotuselanman » Tue Sep 12, 2006 9:23 pm
LOOSE FLYWHEEL !!
To: ***@***.***
Sent: Tuesday, September 12, 2006 10:16 PM
Subject: [LotusElan.net] Update... Re: Stil no luck--- Deep vibration at idle problem
David
> Loose flywheel.
> From: david_c_w
> To: ***@***.***
idle problem
> Hi Tony,
> David
> car is
> moving?
> point
> balanced
> balancer..that it
> > Tony Vaccaro
> > _____
> On Behalf
> > Of david_c_w
> > To: ***@***.***
> problem
> > HI Rod,
those are
> > also possibilities.
> > David
> ps.com, Rod
> > > David,
that's
> > > Rod Bean
> > > S1 & S2 Elans
11/09/2006
lotuselanman
PostPost by: davidwinegar » Wed Sep 13, 2006 6:15 pm
Flywheel coming loose certainly may be the case as it would make
sense. I will let you all know what I find when I pull the engine.
I'm just trying to track down a portable engine lift and find a time
to do it.
Thanks again to all who offered their thoughts and wish me luck.
David
LOOSE FLYWHEEL !!
To: ***@***.***
David
> Loose flywheel.
> From: david_c_w
> To: ***@***.***
idle problem
> Hi Tony,
idle.
need to
> David
> car is
> moving?
to the
> point
> balanced
> balancer..that it
> > Tony Vaccaro
> > _____
> On Behalf
> > Of david_c_w
> > To: ***@***.***
idle
> problem
> > HI Rod,
gear?
those are
> > also possibilities.
> > David
> ps.com, Rod
> > > David,
that's
> > > Rod Bean
> > > S1 & S2 Elans
11/09/2006
11/09/2006
davidwinegar
PostPost by: "Roger Sieling" » Wed Sep 13, 2006 7:09 pm
David,
You know you can take the sheet metal cover off the bottom of the
bellhousing (4 x 1/4-20 screws) to have access to the flywheel. I would
tend to think you would get a lot of noise when the starter was cranking
the engine over if the f'wheel were loose.
All the talk about bolt strengths made me remember a poor application
for Gr8 hardware and that is to attach the flywheel to the crankshaft.
I've seen several engines with Gr8 and "Supertanium" brand cap screws
had failed in this application. It pretty well wrecks an aluminum
flywheel in doing so. Good luck.
>> ***@***.*** 9/13/2006 2:15 PM >>>
to do it.
David
LOOSE FLYWHEEL !!
To: ***@***.***
don't
not
Anyway
David
wrote:
> Loose flywheel.
> From: david_c_w
> To: ***@***.***
idle problem
> Hi Tony,
is
idle.
correctly,
need to
> David
the
> car is
NOT
> moving?
to the
> point
it
> balanced
> balancer..that it
> > Tony Vaccaro
> > _____
> > From: ***@***.***
[mailto:***@***.***
> On Behalf
> > Of david_c_w
> > To: ***@***.***
idle
> problem
> > HI Rod,
gear?
those are
> > also possibilities.
> > David
> > --- In ***@***.***
> ps.com, Rod
> > > David,
if
that's
> > > Rod Bean
> > > S1 & S2 Elans
11/09/2006
11/09/2006
"Roger Sieling"
