Installation help with Engine mounts
Hi all,
Got a replacement set of engine mounts and was supposed to put them in
with a mechanic friend of mine but he cancelled on me. Now I am
looking at perhaps doing the job myself, but looking at it I have a
couple of questions I am hoping someone can answer for me.
First, it is the left hand side mount that is broken, just below the
carbs. I am wondering where to unbolt first. Should I unbold the
mount from the engine first or from the chassis first--or does it
actually matter.
Second, where should I support the engine. The only place I can see
is on the oil pan by puting a board under it and then carfully jacking
under it. Is there a better place?
Any other words of wisdom are appreciated.
David
+2S Helsinki, Finland
actually matter.
David
- davidwinegar
In a message dated 9/7/06 08:46:01 AM, ***@***.***es:
<< it is the left hand side mount that is broken, just below the
carbs. >>
David,
Before you begin, take the carbs off the left side of the engine and put them
on the right.
Frank Howard
'71 S4 SE
Minnesota
carbs. >>
David,
on the right.
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
'71 S4 SE
Minnesota
'71 S4 SE
Minnesota
- Frank Howard
Frank is right you know,but you have the basic idea,support the sump
with a piece of plywood to spread the load and jack,bearing in mind
the bolts are a bugger to get at...............
John (wink)
John (wink)
He didn't tell us he had a Zetec.
Ken
'69 Lotus Elan +2 with BDR
_____
Of ***@***.***
Sent: Thursday, September 07, 2006 10:17 AM
To: ***@***.***; ***@***.***
Subject: Re: [LotusElan.net] Installation help with Engine mounts
In a message dated 9/7/06 08:46:01 AM, ***@***.***.
<mailto:david_c_w%40yahoo.com> com writes:
carbs. >>
David,
them
on the right.
Frank Howard
'71 S4 SE
Minnesota
Ken
_____
Of ***@***.***
carbs. >>
David,
them
on the right.
Frank Howard
'71 S4 SE
Minnesota
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
- lotuselan2
--- In ***@***.***, ***@***.***e:
Yep--you got me--that's what happens when you've already had a long
day at work.
carbs. >>
David,
put them
on the right.
Frank Howard
'71 S4 SE
Minnesota
day at work.
- davidwinegar
Ken
Even Zetecs have the carbs on the right unless you are talking about the
Duratec in the Focus.
Rodney Stevens
CSIRO Minerals
phone 02 9710 6701
Mobile 0432 506 427
Web: http://www.minerals.csiro.au/
Personal Web Page
http://mywebpage.netscape.com/rodjohnst ... mepage.htm
-----Original Message-----
Behalf Of Lotus
Sent: Friday, 8 September 2006 3:28 AM
To: ***@***.***
Subject: RE: [LotusElan.net] Installation help with Engine mounts
Ken
Rodney Stevens
CSIRO Minerals
phone 02 9710 6701
Mobile 0432 506 427
Personal Web Page
Behalf Of Lotus
To: ***@***.***
Ken
- Guest
below the carbs. I am wondering where to unbolt first.
Should I unbold the mount from the engine first or from the
chassis first--or does it actually matter.
It is the generally agreed upon method to describe the left or right of the
car from the drivers perspective, so while it is the left looking at the it
is generally referred to as the right side or as I was taught to say when
working racetracks, it is drivers right. Don't let our teasing get to you on
this, since I much prefer drivers right and drivers left to the British
'OffSide' and 'Nearside' which I still can't get straight. <grin>
can see is on the oil pan by puting a board under it and then
carfully jacking under it. Is there a better place?
Here's what I did last week to put the mounts on, and what I'll be doing
next week when I get a Weber mount for the carb side since all 4 of the ones
I have were for the Stromberg engine (and exhaust side of Weber engine).
Since the carbs are off and waiting to be rebuilt I won't include that step,
but it does make it a little easier if they are off. If they are on you can
remove everything from underneath on the carb side, where I can't on the
exhaust side due to the tubular headers getting in the way.
I use a large saddle jack or a board between saddle and the engine to gently
support the oil pan.
I remove the safety wire on the two mount to chassis bolts and loosen the
bolts/nuts.
Next I remove the four mount to block bolts.
I then remove the two chassis to mount bolts.
Next I apply loctite to the four mount to block bolts and install the mount
to the block but I do not tighten the bolts yet, so it is easier to align
the mount to chassis bolts.
I then adjust the engine height with the jack and insert the chassis to
mount bolts and thread the nuts on a few threads to keep them from falling
out.
Once the chassis to mount bolts are in I torque the mount to block bolts
down.
Next I remove each chassis to mount nut, loctite the bolt and torque the nut
down.
Since my chassis to mount bolts are drilled for safety wire I then add the
safety wire and finish by removing the jack.
Hope this helps,
Rob LaMoreaux
A & D Technology Inc.
4622 Runway Blvd.
Ann Arbor, MI 48108
734-822-9696
Fax 734-973-1103
Main Desk 734-973-1111
www.AandDTech.com
Work email: ***@***.***
Home email: ***@***.***
- Rob_LaMoreaux
