Starter motor questions
Posted: Thu Jul 13, 2006 4:41 pm
Went to start up the '66 S3 SE the other day and got what sounded like
an initial engagment of the starting gear followed by a whizzing type
noise. Never had a problem with what appears to be the stock starter
up to this point. I rocked the car to move the flywheel ring gear
along, and it started right up. Initially, I thought it may be a tooth
problem on the ring gear, but it's gotten progressively worse to the
point that the rocking no longer works. The battery is relatively new,
and next I'll check all the connections I can find leading up to the
starter. Any other ideas of what to look for before (if I have to)
pull the starter?
Jon Eckman
pull the starter?
Jon Eckman
