oil pump removal help
I'm in the middle of trying to remove the oil pump, but there must be
some trick to it... I can't get it to clear the frame, even with the
filter off (?)
Can't search this topic in the archives the server may be down.
Any tips would be appreciated.
Carlos G.
filter off (?)
Carlos G.
- cbguerrajr
Hi Carlos,
This thread has a few suggestions.
http://www.lotuselan.net/forums/viewtopic.php?t=12553
Steve.
Steve.
- "steve_071"
and another thread........
http://www.lotuselan.net/forums/viewtopic.php?t=2039
Thanks for the info... at the time I sent the message,
lotuselan.net was unavailable, so I couldn't check the
archives.
I guess the lesson here is not to take the workshop
manual too literally, nothing is as simple as it says.
What started out as a minor thing to simplify oil
filter changes has escalated. While planning to
detach the right side motor mount, I realized that it
is about to break, the bottom edge of the air box is
almost resting on the fiberglass. Many years of
exposure to hot oil is not the best thing for rubber I
guess. So now I'm ordering a motor mount and changing
that too.
It seems that removing the carbs and working from
above would help the motor mount replacemenst.
Carlos
__________________________________________________
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
archives.
that too.
Carlos
- cbguerrajr
Carlos,
If its a +2 Elan S130 US version there are 2 methods.
The factory manual recommends loosening or removing the motor mounts and
lowering the engine about a 1/2 inch.
The method I used when replacing the oil pump was to take a set of
medium pliers and slightly bend the metal frame up about a 1/4 inch and
rotate the pump. Remove and re-install oil pump. Bend frame back into
place. No permanent or visible damage occurred.
If unsure about methed #2 go with the factory method.
Ty Rodgers
Tiger, Healey, Morgan, Lotus, MGA coupe, MGA roadster, TR3B
Sent: Saturday, June 03, 2006 4:11 PM
To: ***@***.***
Subject: [LotusElan.net] oil pump removal help
filter off (?)
Carlos G.
SPONSORED LINKS
Plus
<http://groups.yahoo.com/gads?t=ms&k=Plus&w1=Plus&w2=Sprint&w3=Devoted&w
4=Impressions&c=4&s=52&.sig=0JmZMxFvZsC1_4q4AiO96A> Sprint
<http://groups.yahoo.com/gads?t=ms&k=Sprint&w1=Plus&w2=Sprint&w3=Devoted
&w4=Impressions&c=4&s=52&.sig=fCbd1nSa8N0l5X1n3P7l4Q> Devoted
<http://groups.yahoo.com/gads?t=ms&k=Devoted&w1=Plus&w2=Sprint&w3=Devote
d&w4=Impressions&c=4&s=52&.sig=coTGsjuoLJ86FK2pOfHHfQ>
Impressions
<http://groups.yahoo.com/gads?t=ms&k=Impressions&w1=Plus&w2=Sprint&w3=De
voted&w4=Impressions&c=4&s=52&.sig=sv0upjHsFHKJ8fu5wUlVHw>
* Visit your group "lotuselan
<http://groups.yahoo.com/group/lotuselan> " on the web.
* To unsubscribe from this group, send an email to:
<mailto:***@***.***ect=Unsubscribe>
* the Yahoo! Terms of
Service
Ty Rodgers
To: ***@***.***
filter off (?)
Carlos G.
SPONSORED LINKS
Plus
Impressions
Service
- rodgerslotus
In simple terms, you must support the engine, and remove the motor mount
bolts so that you can move the engine slightly to the left side of the
car and there will then be enough clearance to remove the pump.
the system manager.
the system manager.
- Elan45
