Smoke slowing & going
• Page 2 of 3 • 1, 2, 3
Try this one - www.jcwhitney.com - cylinder leakage tester, part no. HM817743 $69.99
Steve Waterworth <***@***.***> wrote: This is the one I use:
http://www.ccw-tools.co.uk/catalogue/pr ... &cat_id=85
As has already been said you will also need a compressor.
Ken Evans wrote:
- kayenney
Yes.that is correct. You want it to not change.then it is the valves.
Tony
_____
Of ***@***.***
Sent: Monday, May 08, 2006 8:19 PM
To: ***@***.***
Subject: RE: [LotusElan.net] Re: Smoke slowing & going
Ben
I think you have it the wrong way round if it's changed then it is the
rings.
The oil sits on top of the rings giving a better seal therefore increasing
the compression test reading.
If it doesn't change then it is probably a valve problem.
Rodney Stevens
CSIRO Minerals
phone 02 9710 6701
Mobile 0432 506 427
Web: http://www.minerals.csiro.au/
Personal Web Page
http://mywebpage.netscape.com/rodjohnst ... mepage.htm
-----Original Message-----
Of Benjamin Levy
Sent: Monday, 8 May 2006 2:21 PM
To: ***@***.***
Subject: Re: [LotusElan.net] Re: Smoke slowing & going
On 5/7/06, collins_dan2000 <***@***.***> wrote:
I've never tried doing it, but I've read that you can test for bad
rings by putting a tablespoon or two of oil in the low cylinder and
then do another compression test. If it's unchanged, it's probably
not the rings.
----Ben
Tony
_____
Of ***@***.***
To: ***@***.***
Ben
rings.
Rodney Stevens
CSIRO Minerals
phone 02 9710 6701
Mobile 0432 506 427
Personal Web Page
Of Benjamin Levy
To: ***@***.***
not the rings.
----Ben
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
ElanGTS, 93 Caterham, 05 Elise,
99 Elise190, 05 Elise, 2005 MiataSpeed Turbo
tvacc - Coveted Fifth Gear
If you do put oil in top end of cylinders may I suggest using a good
2-stroke oil. It will burn off cleanly when fired with virtually no
deposits. It is a great ring lube too.
Ken
'69 Lotus Elan +2 with BDR
_____
Of ***@***.***
To: ***@***.***
Ben
rings.
Rodney Stevens
CSIRO Minerals
phone 02 9710 6701
Mobile 0432 506 427
Personal Web Page
Of Benjamin Levy
To: ***@***.***
not the rings.
----Ben
Ken
_____
Of ***@***.***
To: ***@***.***
Ben
rings.
Rodney Stevens
CSIRO Minerals
phone 02 9710 6701
Mobile 0432 506 427
Personal Web Page
Of Benjamin Levy
To: ***@***.***
not the rings.
----Ben
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
- lotuselan2
Thanks for pointing out my dyslexia.
Rod
Rodney Stevens
CSIRO Minerals
phone 02 9710 6701
Mobile 0432 506 427
Personal Web Page
Behalf Of Marc Fuller
Sent: Tuesday, 9 May 2006 10:28 AM
To: ***@***.***
Rod,
Take the time to re-read Ben's post. You just restated what he wrote,
(albeit with a double negative).
-Marc
Rod
Rodney Stevens
CSIRO Minerals
phone 02 9710 6701
Mobile 0432 506 427
Personal Web Page
To: ***@***.***
Rod,
-Marc
- Guest
According to some sources, WD-40 contains substances that remain
after the volatiles evaporate, and that these are somewhat abrasive.
If you go this route, make sure to change the oil, run it at low rpm
for a while, and change the oil again.
Art
26/4934
Art
26/4934
Art Frederick
S2 Roadster, built in 1965, registered in 1966, No. 26/4934
Nothing else of interest at present
frearther - Fourth Gear
I tried squirting some oil into #4 and compression went up to 120
from 90. When I tried the same for the other 3, compression also
went up 30 pts from 120 to 150. So it seems like the rings are bad
on all 4, not just #4. I could still try soaking #4 in penetrating
oil, as it couldn't hurt, but is there something I could try that
might clean up the valves for #4. I'm just thinking that with all
the oil the car is going through, maybe #4's valves are the culprit.
Thoughts? Dan '70 S4 SE
--- In ***@***.***, "collins_dan2000"
In my opinion.you are just forestalling what will need to be done.
I think your rings are bad...and perhaps some valve problems on 4.
Since you have to remove the head anyways to do the valves.may as well pull
the whole motor and rebuild it.
Tony Vaccaro
_____
Of collins_dan2000
Sent: Monday, May 22, 2006 1:38 PM
To: ***@***.***
Subject: [LotusElan.net] Re: Smoke slowing & going
SPONSORED LINKS
Plus
<http://groups.yahoo.com/gads?t=ms&k=Plus&w1=Plus&w2=Sprint&w3=Devoted&w4=Im
pressions&c=4&s=52&.sig=0JmZMxFvZsC1_4q4AiO96A>
Sprint
<http://groups.yahoo.com/gads?t=ms&k=Sprint&w1=Plus&w2=Sprint&w3=Devoted&w4=
Impressions&c=4&s=52&.sig=fCbd1nSa8N0l5X1n3P7l4Q>
Devoted
<http://groups.yahoo.com/gads?t=ms&k=Devoted&w1=Plus&w2=Sprint&w3=Devoted&w4
=Impressions&c=4&s=52&.sig=coTGsjuoLJ86FK2pOfHHfQ>
Impressions
<http://groups.yahoo.com/gads?t=ms&k=Impressions&w1=Plus&w2=Sprint&w3=Devote
d&w4=Impressions&c=4&s=52&.sig=sv0upjHsFHKJ8fu5wUlVHw>
_____
* Visit your group "lotuselan
<http://groups.yahoo.com/group/lotuselan> " on the web.
* To unsubscribe from this group, send an email to:
<mailto:***@***.***ect=Unsubscribe>
* the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
_____
Tony Vaccaro
_____
Of collins_dan2000
To: ***@***.***
SPONSORED LINKS
Plus
Sprint
Devoted
Impressions
_____
* the Yahoo!
_____
Tony Vaccaro
Unfortunately, I am not as savvy with an engine as you guys, I'm
going to need to pay someone to pull the engine and replace the
rings, and while I'm at it, I will have the synchro's replaced as it
is tight getting into gear. How many hours should I anticipate for
such a job? The head should be in pretty good shape as the guides
were replaced just before I bought it in Oct '04. Thanks. Dan
Syncro? I don't think that the symptom would be "tight" that sounds like a
misadjusted clutch. If the syncro is bad.would not be able to get in during
a downshift.
Hours..it should cost you about $1000 plus parts to do the job.
At least that is the going rate around here.Buffalo, NY for a non Lotus
shop.
Tony Vaccaro
_____
Of collins_dan2000
Sent: Wednesday, May 24, 2006 1:39 PM
To: ***@***.***
SPONSORED LINKS
Plus
Sprint
Devoted
Impressions
_____
* the Yahoo!
_____
a downshift.
shop.
Tony Vaccaro
_____
Of collins_dan2000
To: ***@***.***
SPONSORED LINKS
Plus
Sprint
Devoted
Impressions
_____
* the Yahoo!
_____
Tony Vaccaro
I get a little bit of a crunch on occasion when downshifting, but
mostly just very tight trying to get into 1st and 2nd. No grinding
just balking. Dan
just balking. Dan
I'd tend to agree w/ Tony. Please check that the clutch is fully
disengaging before rebuilding the box. Nothing would be wrong w/ having
a rebuilt box, but if rebuilding the clutch hydraulics would cure the
symptoms, then why not take the easy way out. Besides, if you rebuild
the gearbox and our suspicions are right, you'll still need to fix the
clutch problem before your shifting problems are solved.
just balking. Dan
SPONSORED LINKS
Plus Sprint Devoted Impressions
Visit your group "lotuselan" on the web.
the system manager.
just balking. Dan
SPONSORED LINKS
the system manager.
- Elan45
I just replaced both the master and the slave cylinder and the
challenges getting into gear didn't change. I can always check the
seals and bleeds the lines again to be sure. As you say, much
cheaper solution. Dan
Also check the actuating arm adjustment.
Art
At 03:54 PM 5/24/2006, you wrote:
Arther H. Frederick
Initial Reaction - embroidered and decorated apparel
3869 Route 66, Chatham Centre
Valatie, NY 12184
518-392-4287
Art
Arther H. Frederick
Valatie, NY 12184
518-392-4287
Art Frederick
huh? Is that the rod that extends from the slave cylinder to push
the clutch in & out? If that's it, its currently extended as far as
it will reach. Dan
--- In ***@***.***, "Arther H. Frederick"
<initialreaction@...> wrote:
up/lotuselan>
up/lotuselan>
=0JmZMxFvZsC1_4q4AiO96A>Plus
ig=fCbd1nSa8N0l5X1n3P7l4Q>Sprint
sig=coTGsjuoLJ86FK2pOfHHfQ>Devoted
52&.sig=sv0upjHsFHKJ8fu5wUlVHw>Impressions
it will reach. Dan
up/lotuselan>
up/lotuselan>
