Any Disadvantage?
A PO replaced the original fan on my Elan Sprint with a thermostatically controlled electric fan. The power to the fan thermostat has a fused link. One end of the fused link has deformed and broken away. I'm wondering if it would hurt anything to just leave this link out. It certainly would prevent the engine from being reduced to slag for failure of a 25-cent fuse. I'm always scanning my instruments when I drive this thing - but it wouldn't take long for disaster to occur if the fan failed.
Paul Perkins
EarthLink Revolves Around You.
Paul Perkins
- "Paul Perkins"
Paul,
Perhaps the end of the fuse holder has deteriorated/distorted due to
overheating of the wiring. Have you checked to make sure that the
fuse, within the fused link, is of the correct value. The fan could
be failing and drawing too much current and heating things up or the
wiring could also be of the incorrect gauge. Either way, it should be
running through a relay and definitely have a servicable fuse, of the
correct rating, in the circuit. Fibreglass does not take kindly to
fire.
Colin.
fire.
Colin.
'68 S4 DHC
- fatboyoz
Paul,
fire.
Colin.
fire.
Colin.
'68 S4 DHC
- fatboyoz
All my documentation for this installation is unavailable. I don't
know how much current the fan should be drawing - or what size fuze
SHOULD be in the link. If anyone has these figures - I have a
voltameter I could use to check the fan draw.
Paul
Paul
- Perk1518
A 10 or 15A fuse should handle most fans; 20A max.
Ken
'69 Lotus Elan +2 with BDR
_____
Of Paul C. Perkins, MD
Sent: Wednesday, May 03, 2006 7:58 PM
To: ***@***.***
Subject: [LotusElan.net] Re: Any Disadvantage?
Paul
SPONSORED LINKS
Plus
<http://groups.yahoo.com/gads?t=ms&k=Plus&w1=Plus&w2=Sprint&w3=Devoted&w4=En
joy&w5=Impressions&c=5&s=63&.sig=dIq6370auMI5unlj264rKg>
Sprint
<http://groups.yahoo.com/gads?t=ms&k=Sprint&w1=Plus&w2=Sprint&w3=Devoted&w4=
Enjoy&w5=Impressions&c=5&s=63&.sig=muI6crmvtqUoTgRYka59Rg>
Devoted
<http://groups.yahoo.com/gads?t=ms&k=Devoted&w1=Plus&w2=Sprint&w3=Devoted&w4
=Enjoy&w5=Impressions&c=5&s=63&.sig=MYr8YVWitcFnMagQQ6nJVA>
Enjoy
<http://groups.yahoo.com/gads?t=ms&k=Enjoy&w1=Plus&w2=Sprint&w3=Devoted&w4=E
njoy&w5=Impressions&c=5&s=63&.sig=zUhOBysTd0f_oe18NDhODg>
Impressions
<http://groups.yahoo.com/gads?t=ms&k=Impressions&w1=Plus&w2=Sprint&w3=Devote
d&w4=Enjoy&w5=Impressions&c=5&s=63&.sig=fS0z9y1WMhoC-cy_ETCXnA>
_____
* Visit your group "lotuselan
<http://groups.yahoo.com/group/lotuselan> " on the web.
* To unsubscribe from this group, send an email to:
<mailto:***@***.***ect=Unsubscribe>
* the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
_____
Ken
_____
To: ***@***.***
Paul
SPONSORED LINKS
Plus
Sprint
Devoted
Enjoy
Impressions
_____
* the Yahoo!
_____
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
- lotuselan2
Paul,
The good thing about electrical items is that they always come with a label
showing voltage and current draw or watts (=volts x amperes). Unless this
label has been removed you should be able to get the details you need. A
fuse is there to protect the cabling downstream (between the fuse and the
load - in this case the fan. There are tables to show what fuse to use for
a given cable size. On my Mini, I relocated the fuse box from the engine
bay into the passenger compartment and changed from glass fuses to blade
type. End of corrosion problems!
Rgds,
Bill
-----Original Message-----
Behalf Of Paul C. Perkins, MD
Sent: 04 May 2006 00:58
To: ***@***.***
Paul
Rgds,
Bill
To: ***@***.***
Paul
- Bill Barry
The discussion of fuseable links (on Fan wiring) prompts me to ask:
What is the distiction between a "fuseable link" and a "fuse"?
Can a fuse be substituted for a fuseable link? Vice versa? Can one
carry more current? Does one "blow" quicker? Or resist corrosion
better? Or what?
I've always wanted to know.
Rich Boyd
better? Or what?
Rich Boyd
richboyd - Third Gear
Rich,
I would hazard a guess and say that, in the case of a modern auto'
cooling fan, a fusable link and a fuse would be one in the same.
Check out the link below for more info'.
http://www.carcare.org/Electrical/fusible_link.shtml
Colin.
Colin.
'68 S4 DHC
- fatboyoz
On 5/6/06, fatboyoz <***@***.***> wrote:
For an example of how NOT to replace a fuse, take a look at:
http://www.safetycenter.navy.mil/photo/ ... oto178.htm
---Ben
---Ben
- BenL
More relevant to Lotus, here is a picture of my Europa and the repair
done by the previous owner:
http://www.eng.auburn.edu/users/bulfin/fuse.html
---Ben
Bob
69 Elan S4 DHC
71 Europa S2
Bob Bulfin, Professor Department of Industrial/Systems
Engineering
207 Dunstan Hall Auburn University, AL 36849
(334) 844-1422 (Voice) (334) 844-1381 (FAX)
***@***.*** http://www.eng.auburn.edu/~bulfin
---Ben
Bob
69 Elan S4 DHC
71 Europa S2
Engineering
- bulfin
