GROOVED TAPPET - SEE PHOTOS
Steve this may be the answer to your tappet failure-
Don't use Mobil 1! It has nothing to do with dino vs syn. - It has to do
with the fact that the new SM grade oils (especially Mobile 1) are missing
friction modifiers (a zinc and phosphorus compound called zinc dialkyl
dithiophosphate (ZDDP)) that are being left out to meet emissions
goals. Our old direct "cam on tappet" engines need these ZDDP friction
modifiers.
There is a very relevant article in June's Hot Rod mag titled "Cam Info You
Need, Why are flat-tappet cams getting wasted more frequently these days?
You'll be surprised by the answer. " page 124. (Some of the article
photos look a lot like yours.)
Suggestions include using Racing Oils, using light duty Diesel Oils like
Rotella, using a friction modifier additive and hoarding non-SM oils.
-Marc
modifiers.
-Marc
-Marc '66 Elan DHC (36/6025)
http://www.lotuselan.us
- marcfuller
On Tue, 18 Apr 2006 12:44:41 -0600, Marc Fuller wrote:
So just about every engine that doesn't use rockers direct off the cam
is now doomed to failure by running on modern oils?
Is the full text of this article available online?
Martin
72/45
Martin
72/45
Martin
72 Sprint DHC
72 Sprint DHC
M100 - Fourth Gear
According to the article it is engines which use flat tappets or
lifters The engines that are not troubled by the new oils use roller cams.
The article text is not on Hot Rod's website just a reference to it as in
the June issue, at this time it is mag only. It is worth purchasing if you
find a news stand that stocks the issue in the UK. I have OCR scanned the
just the portion pertinent motor to oils (sans photos) and will email it to
you directly. The article also covers cam and tappet metallurgy.
- marcfuller
Thanks for the thought, but I think we found the reason for the
problem.
The #1 intake lost it's gap, I suppose from a bit of recession into
the head, which did not allow any lubrication to get berween the
tappet and cam. This was demonstrated when I put the new tappet in
with the original shim and had no gap at all. However, turning the
engine by hand copmpletly cleaned all of the pre-lube off the cam
and tappet, unlike the other intakes, which kept a coating of oil.
I installed a new shim and got a .008 gap - on the high side, but
close enough. All of the other intake gaps were at about .004, so I
re-gapped them to .007 to .008. All of the exhausts were at .008
to .009.
The engine runs fine now.
I find it hard to believe that Mobil One was the problem. My 1989
Golf had over 130,000 miles when I traded it and my current GTI-VR6
recently passed 200,000 miles with no problems at all.
We use it in every 4-cycle engine we have, including the
motorcycles, lawn mower and weed trimmer.
Steve B
--- In ***@***.***, Marc Fuller <marcfuller@...> wrote:
problem.
to .009.
Steve B
Steve B.<br>1969 Elan S4
- poiuyt
If you read the article you will see that the oils while carrying the same
name brand (even Mobile One) have been significantly reformulated over the
last few years to preserve long-term operation of the catalytic converters.
The zinc and phosphorus ZDDP can shorten the life of the cat as the engine
wears. The 2005 SM grade oils have 20%+ less friction modifiers than the
2004 SL grade oils, and 33% less than the 1996 SH grade oils. Interestingly
the 2005 SM oils have less than 50% of the friction modifiers present in
the current (2006) formulations of Quaker State and Pennzoil racing oils.
The reason that this is being encouraged is that newer (~post 2003) engines
in the US are not compromised by the SM oils due to the wide-spread use of
rollers instead of flat tappets.
- marcfuller
On Thu, 20 Apr 2006 09:23:04 +0100, Steve Waterworth wrote:
Spend your money on beer. In extensive research carried out by many
universities and scientific bodies over the years It has been
scientifically proven to have a more beneficial effect on engine
friction than Slick 50.
As an alternative, teetotalers may wish to sacrifice a goat at
midnight under a full moon. Vegetarian teetotalers can dance naked
for 38 minutes 23.4 seconds in a meadow full of daises to achieve the
same effect.
Martin
72/45
same effect.
Martin
72/45
Martin
72 Sprint DHC
72 Sprint DHC
M100 - Fourth Gear
I vote for the beer option. Any particular brand?
Art
26/4934
At 06:21 AM 4/20/2006, you wrote:
Arther H. Frederick
Initial Reaction - embroidered and decorated apparel
3869 Route 66, Chatham Centre
Valatie, NY 12184
518-392-4287
Art
26/4934
Arther H. Frederick
Valatie, NY 12184
518-392-4287
Art Frederick
S2 Roadster, built in 1965, registered in 1966, No. 26/4934
Nothing else of interest at present
frearther - Fourth Gear
Hmmm....... I would prefer whiskey. Won't cause (carb) frothing!
_____
Behalf Of Arther H. Frederick
Sent: Thursday, April 20, 2006 4:42 PM
To: ***@***.***
Subject: Re: [LotusElan.net] GROOVED TAPPET - SEE PHOTOS
Art
26/4934
Arther H. Frederick
Valatie, NY 12184
518-392-4287
_____
* Visit your group "lotuselan
<http://groups.yahoo.com/group/lotuselan> " on the web.
* To unsubscribe from this group, send an email to:
<mailto:***@***.***ect=Unsubscribe>
* the Yahoo! Terms of
Service
_____
_____
To: ***@***.***
Art
26/4934
Arther H. Frederick
Valatie, NY 12184
518-392-4287
_____
Service
_____
- ericsalomon
I bought the magazine and read the entire article. It seems to be
aimed at folks with modified engines and race-type cams, not stock.
Also, they talk about a problem with oil not getting to the tappet -
one of the tappets they show as a replacement is drilled at the top
to allow oil to flow to the top of the tappet.
In my case there was a constant pool of oil on the top of the
tappets, and the one that failed was where the oil for the intake cam
first enters the head. None of the other tappets were worn. As I
stated in a past e-mail, the problem was zero gap, which caused the
cam to wipe off any oil and no new oil could get between the tappet
and the lobe.
By the way, my 1996 VW GTI-VR6, which is a twin cam with flat topped
tappets, passed 200,000 miles a few weeks back with no problems -
everything is original. And it has been run on Mobil 1 since 13,000
miles, when I bought the car.
I'll stick with the Mobil 1 and take my chances.
Steve B
and the lobe.
Steve B
- poiuyt
Exactly "modified engines and race-type cams". While people who modify
older engines is the target market of Hot Rod, and it is also the reality
of our Elans' Twin Cams which are highly modified for higher performance
but based on simple old Ford engines. Our Twin Cams when compared to their
origin are modified engines and race-type cams. I have read reference to
the block we use, because of the broad applications and range of high
performance mods it has seen, as the 4 cylinder equivalent of the Chevy V8
small block.
In relation to oil - the point of the article is that today's API approved
oils (regardless of brand and type, even Mobil 1) are not the same formula
they were in the recent past ... due to changing emissions standards and
current engine component design. This is meaningful because our Twin Cams
are products of the past, which today's API oil formulas are not designed
to support.
I think in a few months/years we will see the advent of motor oils marketed
for vintage performance engines, which will have ZDDP friction modifier
formulas similar to the pre-2001 oils or today's racing oil and motorcycle
oils.
small block.
to support.
oils.
- marcfuller
Gents,
This seems to be a pretty easy question to get answered. We have a lot of
twin cam racers out there - are any of them currently using Mobil 1 (the new
reformulated version), and how is it working for them? Failing that, has
anyone had the dialogue with the pro race engine builders like Ivey,
Quicksilver and others (I don't know who the really good twin cam guys are,
but the Forum sure does) who are making their living building these (among
other) engines?
Bill Tebbutt
AVIS DE NON-RESPONSABILITE: Ce document transmis par courrier electronique est destine uniquement a la personne ou a l'entite a qui il est adresse et peut contenir des renseignements confidentiels et assujettis au secret professionnel. La confidentialite et le secret professionnel demeurent malgre l'envoi de ce document a la mauvaise adresse electronique. Si vous n'etes pas le destinataire vise ou la personne chargee de remettre ce document a son destinataire, veuillez nous en informer sans delai et detruire ce document ainsi que toute copie qui en aurait ete faite. Toute distribution, reproduction ou autre utilisation de ce document est strictement interdite. De plus, le Groupe Financiere Banque Nationale et ses filiales ne peuvent pas etre tenus responsables des dommages pouvant etre causes par des virus ou des erreurs de transmission.
DISCLAIMER: This documentation transmitted by electronic mail is intended for the use of the individual to whom or the entity to which it is addressed and may contain information which is confidential and privileged. Confidentiality and privilege are not lost by this documentation having been sent to the wrong electronic mail address. If you are not the intended recipient or the person responsible for delivering it to the intended recipient please notify the sender immediately and destroy this document as well as any copies of it. Any distribution, reproduction or other use of this document is strictly prohibited. National Bank Financial Group and its affiliates cannot be held liable for any damage that may be caused by viruses or transmission errors.
other) engines?
Bill Tebbutt
- s2lola
--- In ***@***.***, "Tebbutt, Bill" <bill.tebbutt@...>
wrote:
Bill
I have replied to this more fully on LotusElan.net. In summary I
personally dont think the issue of reducing EP levels in modern oils
is a significant problem for us twin cam people provided other normal
build quality standards and running in precautions are taken. The
only time I would be concerned for a twin cam was if I was running a
full race engine with steel cams and buckets, with a high lift cam
and heavy springs and even then its probably only during the initial
running in where you need the high levels of EP additives in the oil.
I have run Mobil 1 in these types of engines for years without
problems provided the cam and bucket hardness was right and the
running in was done right.
Off course I could be wrong !!! but if it was a real problem in twin
cams in terms of engine failures in road engines it would have come
to light on the forums and it has not. Maybe their is a whole bunch
of potential failures out there just growing quietly but lots of
people play with these engines all the time and I am sure they would
have seen something by now.
The cam and bucket design of a Lotus twin cam is still modern and
used by many modern twin cam engines and I dont see many people
complaining about their toyotas or VW's engines wearing out too
quickly
I have not read the article yet and journalists often simplify
problems such as this to make a good headline. I am sure there are
elements of truth in what they are saying, the real question is
whether this is relevant to our engines compared to lots of other
potential causes of premature cam or bucket failures.
Chev V8's stress their cam to bucket follower interface much more
than a Lotus does with their big valves and heavy valve trains and
agressive cam profiles in the competition engines to try to
compensate for all the other breathing constraints in the head. The
inverted followers also dont live in the sea of oil on their running
surface like the Lotus ones do. Maybe the problem is just specific to
that style of engine
regards
PS but its a good topic for forum discssuions as everyone always has
an opinion on oils
wrote:
Bill
quickly
regards
an opinion on oils
You're right, Rohan, everybody likes to spread oil gossip. I can
attest that the cam-to-follower interface is the most highly loaded
region in a TC. Almost 30 years ago (egad!!) I was racing a TC-powered
CSR Elva Mk 7. Thinking I was catching the wave of tribology tech, I
tried some newfangled synthetic oil, Amzoil (before it became Amsoil).
Cam buckets (steel, Alfa Romeo) would not last a weekend - demonstrated
every time for several races. In desperation I switched back to
Valvoline Racing dino lube and the problem completely vanished.
Synthetic has definitely improved in the interim. Just a few years ago
I ran my Elan vintage racer with Valvoline synthetic 20W-50 with no
wear on the buckets after several weekends. Believe me, I checked
often. I wouldn't hesitate to use it again at this point, but this
thread about reduced EP capacity is fascinating and we should be
vigilant.
Gerry
vigilant.
Gerry
- G. Strickfaden
