spring source??
Hello Steve,
hypercoils - http://www.hypercoils.com has a 125lb 1.875" ID with a
12" free length in their catalog, part #12D0125.
Has anyone in the list tried using 10" free length front coil
springs (with and adjustable perch of course) with any success?
regards
carl
regards
carl
- "C.D.S."
Carl
10 inch free length front springs OK for 150 lb/in. Probably getting
to short for 100 lb/in springs and i would stic with 12 inch
freelength. 10 inch free length maybe OK for 125 lb/inch springs.
What works and does not depends on what ride height you want and what
amount of adjustment is available in your shocks.
Rohan,
Thank you for the advice. I just measured the spax shocks with the
upper and lower perches.
I think I can get the springs on and off without having to use a
spring compressor with the 10"
coils.
I am going to use your guidelines for spring rates on an S3 right
now, but for the life of me I
cannot find 115lbs rear springs in a 2.5" ID. Any suggestions?
Best Regards
Carl
coils.
Best Regards
Carl
- "C.D.S."
I had mine custom made locally by a small local spring works in
Melbourne . I dont think the rate is really critical and plus or minus
10# will affect nothing. If you can get 110# or 120# sprngs that should
be fine as springs are not made to that close a tolerance anyhow.
A well respected suspension tuner I know told me once that most drivers
cannot feel a spring rate change of less than 50% ( even a lot of top
professional racing drivers he works with).
1 7/8" ID is a common size spring in the roundy-round world. They use
'em on midgets, mini-sprints, dwarf cars, and suchlike. Don't know if
you'll find any that soft and long, but there are many suppliers to
that community.
Gerry
On Apr 8, 2006, at 10:50 AM, ***@***.***e:
that community.
Gerry
- G. Strickfaden
There was just a long thread on spring rates and spring sources on the
Europa group. You might download and search the knowledgebase at:
http://www.lotus-europa.com/knowledgebase.html
or just ask again on that group. There are several autocrossers active
there who can help you to the right F/R spring rates to suit your
purposes. The calculations seem to live in their heads!
I concluded that there are many sources of custom springs out there,
but that you want a reputable vendor to make yours due to the many
variables that can mess up a spring. The cost for a quality spring
would probably be comparable to or less than DB, who is just acting as
a middleman in this transaction.
Doug Nicholls, 54/1822 Ma~
- denicholls2
