Elan Hood Pins
Mon Feb 27, 2006 1:47 pm
by archigator
I'm looking for a nice pair of hood pins for the rear of my Elan hood
(bonnet) at the windshield (windscreen). I once saw a pair of pins
(pins)that had a perforated metal fin that stood 90 degrees to the
hood, and turned sideways to release the hood. (Might have been on a
Ferrari.) Any ideas for good looking and functional pins would be
appreciated. (It must also work for fiberglass... but you knew that
already.) I'm tired of having my hood pop up at the most inopportune
moments, like at 70 mph.
I am one of those guys who likes to keep it all stock, so I may not
have the nerve to do it anyway. Firstly, I'm going to see about
lengthening the release cable, because that's where my problem lies I
think. But I'd like to investigate my options...
Gary
Miami, FL
'71 Elan Sprint
Elan Hood Pins
Mon Feb 27, 2006 7:44 pm
by Rob_LaMoreaux
I have not had my bonnet pop open at speed, but just in case I added a cable
from the bridge at the back of the head to the trailing edge of the bonnet.
I fiberglassed a washer to the hole I made in the lower edge of the bonnet,
then before shutting the bonnet all the way I hook a caribeaner (one of
those D shaped robe end pieces that have the spring closed opening) through
the hole. So if my bonnet ever does come unlatched it only opens an inch or
so and I can still see to drive.
Rob LaMoreaux
A & D Technology Inc.
4622 Runway Blvd.
Ann Arbor, MI 48108
734-822-9696
Fax 734-973-1103
Main Desk 734-973-1111
www.mtspt.comWork email: ***@***.***
Home email: ***@***.***
Elan Hood Pins
Mon Feb 27, 2006 8:30 pm
by triumphelan
I had my bonnet flip over the top backwards if anything had been behind it would have done serious damage to them .I now have bonnet pins
Regards John 1969 S4 dhc
----- Original Message -----
To: ***@***.*** ; 'Gary'
Sent: Monday, February 27, 2006 7:44 PM
Subject: RE: [LotusElan.net] Elan Hood Pins
Rob LaMoreaux
4622 Runway Blvd.
Ann Arbor, MI 48108
734-822-9696
Fax 734-973-1103
www.mtspt.com Work email: ***@***.***
SPONSORED LINKS Plus Sprint Devoted
Impressions
a.. Visit your group "lotuselan" on the web.
b.. To unsubscribe from this group, send an email to:
c.. .
Elan Hood Pins
Mon Feb 27, 2006 10:47 pm
by elansprint71
John,
I was recently told that this could not happen, on the Elan.net forum! I
was suggesting that it would not be a good idea to run without the big
spring at the front of the hood/bonnet because I thought the bonnet
could flip out if the catches released at speed; seems that I was
correct after all.
The best looking hood pins that I have seen are Dave Bean's Oddie Pins,
unfortunately they are excruciatingly expensive; I fitted some sliding
pins with a ring and safety catch, as used by most racers, not the
prettiest but my bonnet now stays down above 100mph!
I think there is a photo of the Oddies either in the files or photos
section, although they are mis-named Audi pins.
Cheers,
Pete.
John Harrison wrote:
Elan Hood Pins
Tue Feb 28, 2006 5:20 am
by poiuyt
I recommend
www.summitracing.comSee part number SUM-G3871, Summit Hood Pin Set.
You will have to make a two right-angle brackets to bolt through the
firewall to have a place to mount the bottom of the pin, but they
work fine and look pretty good.
These were on my car when I bought it in 2003. See my car on the
photo pages, Steve's 1969 Elan.
Steve B.
--- In ***@***.***, "Gary" <MCGRAW@...> wrote:
Hood Pins
Tue Feb 28, 2006 1:43 pm
by abstamaria
Gary,
Sorry for the delay. Here are close-ups of the hood-pin brackets.
Because my TTR aluminum radiator sits over the rack, I can't and don't use
the hood spring. Accordingly, I need a pull to open the bonnet (hood),
which normally sits in the closed position. I used a rubber zipper pull
from a scuba shop for the purpose, shown in the 2nd photo.
I hope these are useful.
Warm regards,
Andres
45/8439
Manila
PS: Photos sent to your email address directly. Hope you get them.
Hood Pins
Tue Feb 28, 2006 1:58 pm
by collins_dan
If those pictures could be posted, I would love to see them. Would
also like to figure out how to eliminate the hood spring in front as
the wider alum rad does make it a challenge to disconnect. Thanks. Dn
--- In ***@***.***, "abstamaria" <abstamaria@...>
wrote:
Hood Pins
Tue Feb 28, 2006 2:05 pm
by Elan45
Has anyone thought of using Dzus fittings to hold down the rear edge of
the bonnet. I'm not afraid of losing the bonnet at speed on a street
car, but I've allways been concerned about an engine fire and having to
mess w/ the cable(s) to get the bonnet open. Hood pins or Dzus 1/4 turn
fasteners would solve that problem and the Dzus solution would be much
cleaner looking and aerodynamic. I'm seriously considering this for my
45/26R project that will spend some time on the track. The Dzus wire
clip could be mounted to corner brackets similar to those Andres has
done, w/ a riser to get up close to the bottom of the bonnet.
Roger
use
pull
Warm regards,
Andres
45/8439
Manila
SPONSORED LINKS
Plus Sprint Devoted Impressions
This email and any files transmitted with it are confidential and
intended solely for the use of the individual or entity to whom they
are addressed. If you have received this email in error please notify
the system manager.
This footnote also confirms that this email message has been swept by
MIMEsweeper for the presence of computer viruses.
Hood Pins
Tue Feb 28, 2006 3:43 pm
by Frank Howard
Before everyone tosses the original cable release mechanism and replaces it
with hood pins or Dzus fasteners, consider the following:
1. I recently fixed a non-working system by undoing a modification the PO
had made. In order to make the engine compartment look tidy, he had attached
the cable to the fire wall so that it ran across the top of it, out of the way
of the engine. If yours is set up this way, that is probably why it doesn't
work.
2. Lotus has redesigned the clips. The new ones do not have the break on
the back side which can sometimes catch the bonnet by accident. Big
improvement! No more chipping paint while you frantically try to release it with a screw
driver.
3. And speaking of screw drivers, I can't believe that in the event of an
emergency, digging through the glove box for the screw driver required to
release the Dzus fasteners, then undoing either the two Dzus fasteners or releasing
the two hood pin clips could be faster than simply pulling the cable release.
4. Granted that Dzus fasteners are cleaner looking than hood pins, the
original cable system is the cleanest looking system of all -- nothing on the
bonnet!
5. The original system (on my car, a single cable) requires plenty of
adjustment and lubrication, but when you get it right, it works like a dream.
Anyway, that's my 2 cents. Hopefully it helps someone.
Frank Howard
'71 S4 SE
Minnesota
Hood Pins
Tue Feb 28, 2006 3:55 pm
by davidallen
It is worth point out, that on the +2 at least, it is the cable sleeve which
"operates" the catches, not the cable. Consequently, if it is not lubricated
or worse, fixed to the fire wall, the catches will not work correctly.
David (+2, with a new bonnet release)
-----Original Message-----
Sent: 28 February 2006 15:42
To: ***@***.***; ***@***.***
Subject: Re: [LotusElan.net] Hood Pins
attached
way
work.
with a screw
driver.
releasing
release.
the
bonnet!
dream.
Frank Howard
'71 S4 SE
Minnesota
Hood Pins
Tue Feb 28, 2006 3:59 pm
by saarhus
Here are the hood pins I made for my S3 Coupe in 1971. I used 1/8 in alum angle stock and a pair of hood pins I got form some dimly remembered source. This was after the hood doing the giant Frisbee on the Darmstadt to Frankfurt Autobahn. For some reason, I wasn't using the front hood spring. No more trouble after that. Excuse the humongous size, hope you can load it ok.
Stan
66 S3 Elan Coupe'
64 S1 Elan Roadster
Hood Pins
Tue Feb 28, 2006 4:29 pm
by saarhus
I guess the photos got stripped off. I have put them in a Yahoo LotusElan folder "Aarhus 66 Coupe Progress".
Stan
To: ***@***.***
Sent: Tuesday, February 28, 2006 9:58 AM
Stan
66 S3 Elan Coupe'
64 S1 Elan Roadster
Hood Pins
Tue Feb 28, 2006 5:31 pm
by nebogipfel
I do agree with Frank on this. The original system is much better and
can work OK when set up properly.
I also agree with Frank on cable routing. I actually made a stand off
bracket for mine from the cam cover so that the cable follows its
natural curve. I think a similar thing was standard on the later Sprints?
I also regularly oil the cable to keep everything sweet and smooth
Hood Pins
Tue Feb 28, 2006 5:55 pm
by trw99
Here is the dealer service bulletin which details the modified
catches, cable route and cable clip, issued in 1972:
http://www.lotuselan.net/publish/lsb_bo ... able.shtmlHope this is helpful.
Hood Pins
Tue Feb 28, 2006 7:06 pm
by mikecauser
On Tue, 28 Feb 2006 09:05:29 -0500 "Roger Sieling" <***@***.***> wrote:
The snag with Dzus fasteners for a road car is that they look rather
knocked-about after a few applications. Any paint soon chips off and
the slot gets mangled by some numbskull using too small a screwdriver.
On a racer that's fine though, and for added aero get some racer-tape
matching the body colour and put a small piece over each fastener
OTOH, if I thought en engine fire was that likely I'd have a plumbed-in
extinguisher system....
Mike Causer Email - mailto:***@***.***
GPG KeyID 1C2DDA07 WWW -
http://www.mikecauser.comFlood the fen again! - Wicken Fen enlargement -
http://www.wicken.org.uk
