Elan Hood Pins
I'm looking for a nice pair of hood pins for the rear of my Elan hood
(bonnet) at the windshield (windscreen). I once saw a pair of pins
(pins)that had a perforated metal fin that stood 90 degrees to the
hood, and turned sideways to release the hood. (Might have been on a
Ferrari.) Any ideas for good looking and functional pins would be
appreciated. (It must also work for fiberglass... but you knew that
already.) I'm tired of having my hood pop up at the most inopportune
moments, like at 70 mph.
I am one of those guys who likes to keep it all stock, so I may not
have the nerve to do it anyway. Firstly, I'm going to see about
lengthening the release cable, because that's where my problem lies I
think. But I'd like to investigate my options...
Gary
Miami, FL
'71 Elan Sprint
Gary
Miami, FL
'71 Elan Sprint
archigator - Fourth Gear
I have not had my bonnet pop open at speed, but just in case I added a cable
from the bridge at the back of the head to the trailing edge of the bonnet.
I fiberglassed a washer to the hole I made in the lower edge of the bonnet,
then before shutting the bonnet all the way I hook a caribeaner (one of
those D shaped robe end pieces that have the spring closed opening) through
the hole. So if my bonnet ever does come unlatched it only opens an inch or
so and I can still see to drive.
Rob LaMoreaux
A & D Technology Inc.
4622 Runway Blvd.
Ann Arbor, MI 48108
734-822-9696
Fax 734-973-1103
Main Desk 734-973-1111
www.mtspt.com
Work email: ***@***.***
Home email: ***@***.***
Rob LaMoreaux
4622 Runway Blvd.
Ann Arbor, MI 48108
734-822-9696
Fax 734-973-1103
www.mtspt.com
- Rob_LaMoreaux
I had my bonnet flip over the top backwards if anything had been behind it would have done serious damage to them .I now have bonnet pins
Regards John 1969 S4 dhc
----- Original Message -----
To: ***@***.*** ; 'Gary'
Sent: Monday, February 27, 2006 7:44 PM
Subject: RE: [LotusElan.net] Elan Hood Pins
Rob LaMoreaux
4622 Runway Blvd.
Ann Arbor, MI 48108
734-822-9696
Fax 734-973-1103
www.mtspt.com
SPONSORED LINKS Plus Sprint Devoted
Impressions
a.. Visit your group "lotuselan" on the web.
b.. To unsubscribe from this group, send an email to:
c.. .
Rob LaMoreaux
4622 Runway Blvd.
Ann Arbor, MI 48108
734-822-9696
Fax 734-973-1103
www.mtspt.com
Impressions
c.. .
Regards John 1969S4DHC
- triumphelan
John,
I was recently told that this could not happen, on the Elan.net forum! I
was suggesting that it would not be a good idea to run without the big
spring at the front of the hood/bonnet because I thought the bonnet
could flip out if the catches released at speed; seems that I was
correct after all.
The best looking hood pins that I have seen are Dave Bean's Oddie Pins,
unfortunately they are excruciatingly expensive; I fitted some sliding
pins with a ring and safety catch, as used by most racers, not the
prettiest but my bonnet now stays down above 100mph!
I think there is a photo of the Oddies either in the files or photos
section, although they are mis-named Audi pins.
Pete.
correct after all.
Pete.
Pete.
http://www.petetaylor.org.uk
Pete.
I recommend www.summitracing.com
See part number SUM-G3871, Summit Hood Pin Set.
You will have to make a two right-angle brackets to bolt through the
firewall to have a place to mount the bottom of the pin, but they
work fine and look pretty good.
These were on my car when I bought it in 2003. See my car on the
photo pages, Steve's 1969 Elan.
Steve B.
Steve B.
Steve B.<br>1969 Elan S4
- poiuyt
Gary,
Sorry for the delay. Here are close-ups of the hood-pin brackets.
Because my TTR aluminum radiator sits over the rack, I can't and don't use
the hood spring. Accordingly, I need a pull to open the bonnet (hood),
which normally sits in the closed position. I used a rubber zipper pull
from a scuba shop for the purpose, shown in the 2nd photo.
I hope these are useful.
Warm regards,
Andres
45/8439
Manila
PS: Photos sent to your email address directly. Hope you get them.
Warm regards,
Andres
45/8439
Manila
- abstamaria
If those pictures could be posted, I would love to see them. Would
also like to figure out how to eliminate the hood spring in front as
the wider alum rad does make it a challenge to disconnect. Thanks. Dn
--- In ***@***.***, "abstamaria" <abstamaria@...>
wrote:
Has anyone thought of using Dzus fittings to hold down the rear edge of
the bonnet. I'm not afraid of losing the bonnet at speed on a street
car, but I've allways been concerned about an engine fire and having to
mess w/ the cable(s) to get the bonnet open. Hood pins or Dzus 1/4 turn
fasteners would solve that problem and the Dzus solution would be much
cleaner looking and aerodynamic. I'm seriously considering this for my
45/26R project that will spend some time on the track. The Dzus wire
clip could be mounted to corner brackets similar to those Andres has
done, w/ a riser to get up close to the bottom of the bonnet.
use
pull
Warm regards,
Andres
45/8439
Manila
SPONSORED LINKS
Plus Sprint Devoted Impressions
the system manager.
use
pull
Warm regards,
Andres
45/8439
Manila
SPONSORED LINKS
the system manager.
- Elan45
Before everyone tosses the original cable release mechanism and replaces it
with hood pins or Dzus fasteners, consider the following:
1. I recently fixed a non-working system by undoing a modification the PO
had made. In order to make the engine compartment look tidy, he had attached
the cable to the fire wall so that it ran across the top of it, out of the way
of the engine. If yours is set up this way, that is probably why it doesn't
work.
2. Lotus has redesigned the clips. The new ones do not have the break on
the back side which can sometimes catch the bonnet by accident. Big
improvement! No more chipping paint while you frantically try to release it with a screw
driver.
3. And speaking of screw drivers, I can't believe that in the event of an
emergency, digging through the glove box for the screw driver required to
release the Dzus fasteners, then undoing either the two Dzus fasteners or releasing
the two hood pin clips could be faster than simply pulling the cable release.
4. Granted that Dzus fasteners are cleaner looking than hood pins, the
original cable system is the cleanest looking system of all -- nothing on the
bonnet!
5. The original system (on my car, a single cable) requires plenty of
adjustment and lubrication, but when you get it right, it works like a dream.
Anyway, that's my 2 cents. Hopefully it helps someone.
Frank Howard
'71 S4 SE
Minnesota
work.
driver.
bonnet!
Frank Howard
'71 S4 SE
Minnesota
- Frank Howard
It is worth point out, that on the +2 at least, it is the cable sleeve which
"operates" the catches, not the cable. Consequently, if it is not lubricated
or worse, fixed to the fire wall, the catches will not work correctly.
David (+2, with a new bonnet release)
-----Original Message-----
Sent: 28 February 2006 15:42
To: ***@***.***; ***@***.***
Subject: Re: [LotusElan.net] Hood Pins
attached
way
work.
with a screw
driver.
releasing
release.
the
bonnet!
dream.
Frank Howard
'71 S4 SE
Minnesota
attached
way
work.
with a screw
driver.
releasing
release.
the
bonnet!
dream.
Frank Howard
'71 S4 SE
Minnesota
- davidallen
Here are the hood pins I made for my S3 Coupe in 1971. I used 1/8 in alum angle stock and a pair of hood pins I got form some dimly remembered source. This was after the hood doing the giant Frisbee on the Darmstadt to Frankfurt Autobahn. For some reason, I wasn't using the front hood spring. No more trouble after that. Excuse the humongous size, hope you can load it ok.
Stan
66 S3 Elan Coupe'
64 S1 Elan Roadster
Stan
66 S3 Elan Coupe'
64 S1 Elan Roadster
- saarhus
I guess the photos got stripped off. I have put them in a Yahoo LotusElan folder "Aarhus 66 Coupe Progress".
Stan
To: ***@***.***
Sent: Tuesday, February 28, 2006 9:58 AM
Stan
66 S3 Elan Coupe'
64 S1 Elan Roadster
Stan
To: ***@***.***
Stan
66 S3 Elan Coupe'
64 S1 Elan Roadster
- saarhus
I do agree with Frank on this. The original system is much better and
can work OK when set up properly.
I also agree with Frank on cable routing. I actually made a stand off
bracket for mine from the cam cover so that the cable follows its
natural curve. I think a similar thing was standard on the later Sprints?
I also regularly oil the cable to keep everything sweet and smooth
Here is the dealer service bulletin which details the modified
catches, cable route and cable clip, issued in 1972:
http://www.lotuselan.net/publish/lsb_bo ... able.shtml
Hope this is helpful.
trw99 - Coveted Fifth Gear
On Tue, 28 Feb 2006 09:05:29 -0500 "Roger Sieling" <***@***.***> wrote:
The snag with Dzus fasteners for a road car is that they look rather
knocked-about after a few applications. Any paint soon chips off and
the slot gets mangled by some numbskull using too small a screwdriver.
On a racer that's fine though, and for added aero get some racer-tape
matching the body colour and put a small piece over each fastener
OTOH, if I thought en engine fire was that likely I'd have a plumbed-in
extinguisher system....
Mike Causer Email - mailto:***@***.***
GPG KeyID 1C2DDA07 WWW - http://www.mikecauser.com
Flood the fen again! - Wicken Fen enlargement - http://www.wicken.org.uk
- mikecauser
