Exhaust-side oil drainage
Has anyone ever contemplated fabricating an oil drain for the rear ofthe head on the exhaust side? Something to keep oil from pooling aroundthe tappets in such large quantities. Maybe some outdoor plumbing; apipe fitted to a hole drilled in the head and draining back to thesump. Or is such an idea sheer lunacy? Loss of all the engine's oiljust waiting to happen. I would be interested in the thoughts of thosethat have contemplated such a drain.
Rich Boyd
Rich Boyd
richboyd - Third Gear
Rich
The later heads had a cross drilling at the rear from the exhaust to
the inlet side where there is better drainage. Dont know when this
was introduced but my two later heads have it and my early head does
not.
In practice with the right valve stem clearances non of them smoke in
normal use.
I understood the cross drilling was introduced to stop smoking
complaints when the car was parked on a slope with its nose steeply
uphill. Over night the oil would drain into the exhaust through the
rear valve guide which was below the pooled oil level if the hill was
steep enough. This resulted in a large cloud of smoke on startup.
No one in real life parks their Elan on a steep hill as no one really
trusts the hand brake !!!
not.
normal use.
In my experience, worn valve guides = smoke on start up. New or good
guides don't.
I also found that if you don't use the original or quality replacement
guides, they wear very quickly which = smoke on start up within months
or even right away in some cases. It is not so bad for racing, but
embarrassing on a road car.
I have used, for example, Perkins guides which are identical in diameter
and bore; they just required shortening, but started smoking very
quickly.
I don't think that modifying the head is the answer - the designer was
very clever and I am sure he knew more about cylinder heads than us. New
guides are cheep enough anyway.
Eric
_____
Behalf Of Rohan Hodges
Sent: Monday, February 27, 2006 11:51 AM
To: ***@***.***
Subject: [LotusElan.net] Re: Exhaust-side oil drainage
Rich
not.
normal use.
SPONSORED LINKS
Plus
<http://groups.yahoo.com/gads?t=ms&k=Plus&w1=Plus&w2=Sprint&w3=Devoted&w
4=Impressions&c=4&s=52&.sig=0JmZMxFvZsC1_4q4AiO96A>
Sprint
<http://groups.yahoo.com/gads?t=ms&k=Sprint&w1=Plus&w2=Sprint&w3=Devoted
&w4=Impressions&c=4&s=52&.sig=fCbd1nSa8N0l5X1n3P7l4Q>
Devoted
<http://groups.yahoo.com/gads?t=ms&k=Devoted&w1=Plus&w2=Sprint&w3=Devote
d&w4=Impressions&c=4&s=52&.sig=coTGsjuoLJ86FK2pOfHHfQ>
Impressions
<http://groups.yahoo.com/gads?t=ms&k=Impressions&w1=Plus&w2=Sprint&w3=De
voted&w4=Impressions&c=4&s=52&.sig=sv0upjHsFHKJ8fu5wUlVHw>
_____
* Visit your group "lotuselan
<http://groups.yahoo.com/group/lotuselan> " on the web.
* To unsubscribe from this group, send an email to:
<mailto:***@***.***ect=Unsubscribe>
* the Yahoo! Terms of
Service
_____
guides don't.
quickly.
Eric
_____
To: ***@***.***
Rich
not.
normal use.
SPONSORED LINKS
Plus
Sprint
Devoted
Impressions
_____
Service
_____
- ericsalomon
Rich,
What's the matter - it doesn't have enough places to leak oil from
already?
Steve B.
already?
Steve B.
Steve B.<br>1969 Elan S4
- poiuyt
If the designer was very clever, why did he come up with such an awful
design for the water pump!
Don't bother replying, - I know the answer already!
David
-----Original Message-----
Sent: 27 February 2006 14:42
To: ***@***.***
Subject: RE: [LotusElan.net] Re: Exhaust-side oil drainage
guides don't.
quickly.
Eric
_____
To: ***@***.***
Rich
not.
normal use.
SPONSORED LINKS
Plus
Sprint
Devoted
Impressions
_____
Service
_____
David
To: ***@***.***
guides don't.
quickly.
Eric
_____
To: ***@***.***
Rich
not.
normal use.
SPONSORED LINKS
Plus
Sprint
Devoted
Impressions
_____
Service
_____
- davidallen
Umm, I could be wrong, but original guides would be iron, not bronze and lasted a hefty 30k miles. Sure, my car had many more on it before they were changed, but they came out in pieces. My guess is they were out of tolerance in 15k miles. the lack of seals is also a serious engineering problem if you intend to not burn oil.
The twin cam is a nice little motor, but it is no engineering study
- stupidemail5 at lycos.com
The twin cam is a really good engine - one of the best - in its day.
To give you and idea of what was expected, my 1967 fiat 124 owners
manual recommended a de-coke every 25 000 miles. We are very spoiled
with the modern engines.
Besides, they did not seem to mind dripping and using a bit of oil in
those days, especially as service intervals were only 1 000 miles.
Eric
_____
Behalf Of ***@***.***
Sent: Thursday, March 02, 2006 11:02 PM
To: ***@***.***
Eric
_____
To: ***@***.***
- ericsalomon
It might not be a "engineeering study, but for the reported ?1000
that Harry Mundy recieved, it was a very good value to Lotus. It cost
Ford 100 times that for Cosworth FVA and DFV and they just got the
publicity, not a production engine to power their complete production
line for 13 years. This isn't a slam at Cosworth, I'm just trying to
put it into perspective.
Gary
--- In ***@***.***, ***@***.***e:
Gary
