Lotus Elan
Front spring shock dissassembly
PostPost by: Will Grainger » Tue Feb 21, 2006 1:53 pm
Here's a photo of mine. A local welding shop made it for 50 bucks. I
supplied them with the threaded rods and a sketch of what I wanted.
It was really worth it. Easy to use and safe as far as I can see.
http://members.shaw.ca/lotuselan/elan/s ... essor.html
Will
45/9693
Message: 11
Date: Mon, 20 Feb 2006 00:38:28 -0000
Subject: Front spring shock dissassembly HELP
I couldn't find any combination of tools in my extensive collectoin to
compress the front spring of my armstrong units.
Any suggestions?
Are these any good?
I need to go up to about a 140-160 lb. spring
to balance with 95# rears(?).
Thanks, all
Will Grainger
PostPost by: Briggs1 » Tue Feb 21, 2006 2:01 pm
You can do the same thing with Plywood.
I made one for my Europa shocks and it worked like a champ.
Double up the plywood on the ends and there is NO deflection. I used 3/8"
board.
There are a few pictures in the Europa Group Yahoo pictures section.
Briggs Pletcher
-----Original Message-----
Of Will Grainger
Sent: Tuesday, February 21, 2006 8:51 AM
To: ***@***.***
Subject: [LotusElan.net] Re: Front spring shock dissassembly
Will
45/9693
Message: 11
Any suggestions?
Are these any good?
Thanks, all
Briggs1
