Lucas starter
Good day
I am helping a friend with his Elan starter motor
What is the no of teeth on the starter Bendix drive ?
My memory says it is a 9 tooth, but . I am sure it is the original
flywheel/ring gear and the starter is the Lucas inertia type, but we got
confused with the teeth , he has a 9 and a 10 tooth version availble
Also , what is the dia of the Bendix drive gear, is it 25 mm or 29 mm?
Arno
Arno
- Arno Church
In a message dated 2/19/06 12:04:45 AM, ***@***.***es:
<< What is the no of teeth on the starter Bendix drive ? >>
Nine, but I have heard that the original (which mine is) is not quite right
for the ring gear and the 10 tooth works better. Somebody on this list should
know for sure.
<< Also , what is the dia of the Bendix drive gear, is it 25 mm or 29 mm? >>
25mm.
Arno, you owe me big time because I had to go out to my detached unheated
garage to get this for you at 2:00 a.m. and it's -6 F (-35 C). Let's put it this
way. If I was removing my ring gear, I wouldn't need any dry ice.
Frank Howard
'71 S4 SE
Minnesota
know for sure.
25mm.
Frank Howard
'71 S4 SE
Minnesota
- Frank Howard
Greetings Arno,
The original bendix had 9 teeth and I think Miles Wilkins also says
fit a 9 tooth BUT I had a lot of problems with the 9 tooth having to
replace it every couple of months, I fitted a 10 tooth and no more
problems. There are those who swear by a 9 tooth but I would only
fit a 10 tooth now.
The diameter across the teeth is + - 29 mm and across the bendix
body + - 37mm
Regards Brian.
(PS. I am again in S.A. for a couple of months but don't think I'll
get to Cape Town)
fit a 10 tooth now.
body + - 37mm
Regards Brian.
get to Cape Town)
Hi Brian
Thanks for that , Eric will probably stay with the 10 AND a new battery
So what is wrong with Cape Town then?
Oh and I was in London for 4 days in Dec ? other than flying in at Heathrow
, the closest I came to Windsor though ,was Chiswick ? for ? an hour
Arno
Greetings Arno,
fit a 10 tooth now.
body + - 37mm
Regards Brian.
get to Cape Town)
_____
Arno
Greetings Arno,
fit a 10 tooth now.
body + - 37mm
Regards Brian.
get to Cape Town)
_____
- Arno Church
Both 9 and 10 tooth were used. From what I have heard they both work about
the same. The 9 tooth would give slightly more torque, but not enough to
really bother I would guess.
Rob LaMoreaux
Ann Arbor, MI USA
(734)-971-5583
Cell (734)-604-9280
Email: ***@***.***
Too many Hobbies.... Too Little Time
1969 Lotus Elan....It's not a restoration, it's a never-ending adventure.
- Rob_LaMoreaux
Gents
can I suggest a retrofit gear driven starter as on Ebay. - Over 30 plus years I went thru 3 Lucas starters and a stack of pinion gears before I spent $150 and got rid of the problem.
I must admit that I am not ashamed that I had to go to an oriental solution to defeat that dreaded "Prince of Darkness"
Wild Bill -- 26/0538
----- Original Message -----
To: ***@***.***
Sent: Saturday, February 18, 2006 11:14 AM
Subject: RE: [LotusElan.net] Lucas starter
Good day
Arno
SPONSORED LINKS Plus Sprint Devoted
Impressions
a.. Visit your group "lotuselan" on the web.
b.. To unsubscribe from this group, send an email to:
c.. .
__________ NOD32 1.1413 (20060217) Information __________
This message was checked by NOD32 antivirus system.
http://www.eset.com
To: ***@***.***
Good day
Arno
Impressions
c.. .
http://www.eset.com
Bill Rathlef
Vancouver Island, Canada
Bill - Fourth Gear
--- In ***@***.***, "Arno Church" <stuckect@...> wrote:
Hmm! well how about no electricty for a start!and lets not get into
that wind you guys have!
Brian.
64 Elan/72 Sprint/Birkin T.C.Seven
Brian.
Well
The wind keeps the Gautengers away !
And - What did Cape Town use for lighting before the advent of parafin lamps?
Electricity !!!
Arno
Brian.
SPONSORED LINKS
Plus Sprint Devoted
Impressions
c.. .
Electricity !!!
Arno
Brian.
SPONSORED LINKS
Plus Sprint Devoted
Impressions
c.. .
- Arno Church
