Rear lights
Posted: Thu Feb 09, 2006 1:19 pm
A subject (just) slightly more relevant than 4th gears and DAF
transmissions!
I am struggling to get some good rear lights for my +2 (which I am sure you
are aware, were also used on the later +0). This is probably because I am
not prepared to pay the inflated cost of such items.
However, it occurred to me it might be possible to have the chrome section
copied and remanufactured, using an original one as a template, ideally in
plastic this time. Chrome plating may be tricky but virtually every kids toy
has chromed plastic, so it should not be an insurmountably problem
The factory I work for actually has a pattern shop, although they are more
used to dealing with cast iron! However, they may be a useful source of
info. Has anyone else had experience of similar work, or may be interested
in getting involved?
David
CONFIDENTIALITY NOTICE
The information contained in this e-mail is intended only for the
confidential use of the above named recipient. If you are not the intended
recipient or person responsible for delivering it to the intended recipient,
you have received this communication in error and must not distribute or
copy it. Please accept the sender's apologies, notify the sender immediately
by return e-mail and delete this communication. Thank you.
transmissions!
David
