GROOVED TAPPET - SEE PHOTOS
PostPosted: Sun Feb 05, 2006 9:59 pm
by poiuyt
I just added an album called TWIN CAM TAPPET with scans of the grooved
tappet I pulled out of the engine on Saturday. None of the other
tappeta are damaged and the cam lobe is ok.
I'm guessing the tappet was defective because there was no shortage of
oil in the head.
By the way - I wound up removing the gear because I could not get
enough slack to lift the chain off the gear, even though I backed the
adjuster all the way out. Did not give me any problem at all - let's
hope it goes back the same way!
I have the chain wedged in place with a block of wood to keep it on all
of the other gears.
Steve B.
PostPosted: Mon Feb 06, 2006 1:46 am
by "Tim Engel"
"Steve B" <***@***.***> wrote:
(Snip)...
there was no shortage of oil in the head.
Steve,
Wow! That's much more erosion than I was expecting... sorta re-defines
"groove". Trench, maybe. There's a lot of metal missing and it had no
where to go but into the engine. Regardless of how localized the original
damage is found to be, there should be real concern for the collateral
damage all the bits of iron could still do in the future if not removed.
A proper fix should involve an engine tear down and thorough cleaning. All
the oil passages, the hollow parts (cams, crank, etc), the oil pump, the
oil cooler and hoses... everything the circulating oil touches must be
cleaned. Brushed, not just flushed.
It's a leap to assume the tappet is the root cause simply because there was
no shortage of oil. I suspect there's more at work in there than just
friction/wear and I'm not confident that replacing that tappet will correct
the problem. If the valve was replaced, measure it to make sure the
retainer groove wasn't cut too low. If the valve spring was replaced,
measure it's compressed-solid length to make sure it's not too long.
Either of those conditions could cause the spring to go coil-bound before
the cam reaches full-open, and that would put huge loads into the tappet
and cam. Enough to crack the hardened top surface and cause it to flake
out.
The tappets are surface-hardened. If it was an original tappet that had
worked for years, then there's a low probability of it suddenly going soft
and wearing like that. If it was a replacement tappet that was dead soft
(defective), then it could have worn to that point in a short time. Have
an undamaged surface on the tappet checked for hardness. If it's hard,
then you need to be looking for other culprits before you re-assemble the
engine and call it good.
The top of a good tappet should appear smooth/ polished. In the photo,
the tappet's top surface looks "grainy". Like what you would see in the
fractured edge of a broken cast iron part. Is that what it really looks
like? Or am I seeing something else like oil deposits (that doesn't make
sense either). If the thin, case-hardened top surface cracked, flaked out
and exposed the plain cast iron below, then that sub-surface would wear
quickly. Again, in that case you would really want to know where those bits
of hardened surface went. They cannot be left in the engine.
could not get enough slack to lift the chain off the gear,
even though I backed the adjuster all the way out.
As mentioned before, the idea isn't to remove the chain from the sprocket.
Rather to lift the cam, sprocket and chain up out of the bearing journals as
far as full tensioner slack will allow. Then lift the back end of the cam
higher yet, tilting the cam "tail high" to clear all but the front
bearing cap studs. Then swing the back of the cam toward the center of the
head and lay the cam down at an angle between studs with the sprocket still
meshed with the chain. Pad the stud threads and the head with rags to
protect the cam lobes and bearing journals.
But it's certainly a good procedure to dismantle everything. That for sure
forces the issue of re-timing the cams from scratch, and that's a good
thing.
----- Original Message -----
To: <***@***.***>
Sent: Sunday, February 05, 2006 3:58 PM
Subject: [LotusElan.net] GROOVED TAPPET - SEE PHOTOS
oil in the head.
of the other gears.
PostPosted: Mon Feb 06, 2006 2:21 am
by Lincoln62
I wouldn't panic. The oil filter do it's job and trap that amont of
metal before it gets to the oil galleries. Worth checking the internals
of the oil pump for damage though.
Peter
66S2
PostPosted: Mon Feb 06, 2006 10:10 am
Just picking up on one of your comments
"The tappets are surface-hardened".
The original Lotus tappets were chilled cast iron and given their
thickness would have been hard all the way through and typically they
crack if major damage occurs. Modern replacements are steel and
normally nitrided to achieve a thin hard surface layer on a more
ductile subsurface.
Given that the tappet has not cracked and yet it has so much damage it
would not surprise me if it was a modern steel replacement that maybe
was not hardened properly.
PostPosted: Mon Feb 06, 2006 1:36 pm
by poiuyt
I drove the car close to 100 miles after the tapping started, to get
home, which would explain why the damage was so bad. I suspect if I
was near home when the problem started the damage would not have been
so bad.
The engine has almost 8000 miles since it was rebuilt, and it was
done by a shop that builds these for racing, so I don't believe that
the wrong parts were used. There is no damage on any of the other
tappets and the cam bearings are clean. I intend to change then oil
again after running it for a short time, and look at the tappets on a
regular basis to see if the problem returns.
Steve B.
--- In ***@***.***, "Tim Engel" <[email protected]> wrote:
"Steve B" <[email protected]> wrote:
> (Snip)...
Steve,
defines
had no
original
collateral
removed.
cleaning. All
pump, the
must be
there was
just
correct
the
replaced,
long.
before
tappet
flake
out.
that had
going soft
dead soft
time. Have
hard,
assemble the
photo,
in the
looks
doesn't make
flaked out
wear
those bits
sprocket.
journals as
the cam
front
center of the
sprocket still
rags to
for sure
good
thing.
To: <***@***.***>
grooved
shortage of
> oil in the head.
the
let's
on all
> of the other gears.
PostPosted: Mon Feb 06, 2006 3:12 pm
by Harald S. Feeß
Steve,
could you ask the shop and tell us what they say ?
Harry
Steve B.
PostPosted: Mon Feb 06, 2006 6:49 pm
by poiuyt
I'm doing the work myself, but will be in contact with the engine
builder. In fact, I just came back from there with some suggestions:
1. measure from the top of the valve to the deck and compare with the
other valves to check whether the valve has been pushed into the head.
2. Possible broken valve spring
3. 3. chack the bad tappet for out of round causing sticking
What I'll be doing is to chaek the measurements in #1 @ #3 and, if I
can't ID a problem there, replace the tappet with new and see what the
gaps look like. If normal I'll put everything back together and run
the engine. I don't see a down side to this because if the problem
doesn't return I'll chalk it up to a defective tappet. If it returns,
I'll have the head pulled. I don't see any down side to this because
if the problem returns I can then pull the engine apart.
Steve B.
--- In ***@***.***, Harald S. Fee? <[email protected]> wrote:
Steve,
Harry
a
> Steve B.
PostPosted: Mon Feb 06, 2006 10:01 pm
by gwnorth68
I'd like to see the damaged cam bucket? Where is the photo? Sorry for being
obtuse.
Tom Moore
PostPosted: Mon Feb 06, 2006 11:16 pm
by poiuyt
Actually, you sound acute to me!
Look in Twin Cam Tappett in the photo section.
Steve B.
being
obtuse.
Tom Moore
