Lotus Elan
Door Hinge Bobbin hole size question, and an Update
PostPost by: "Ian Phillips" » Mon Sep 26, 2005 8:32 pm
-----Original Message-----
Of david_cusworth
Sent: Monday, September 26, 2005 6:13 PM
To: ***@***.***
Subject: [LotusElan.net] Re: Door Hinge Bobbin hole size question
Through hole.......what through hole? What is it for? If it's drainage the
water will go into the car.
David
--- In ***@***.***, "Ian Phillips" <[email protected]> wrote:
Does anyone know the diameter of the central (through) hole in the
Mazak
hinge bobbin (the ones bonded in to the bodywork)
I have a cunning plan to refurbish the door hinges on my S4 and
want to make
a tool that spigots in the bottom of the hemispherical recess. I
know the
hemispherical recess is 5/8" diameter but if anyone has easy
access to a
door aperture, or has a spare bobbin they can get to without
taking a door
off I would be grateful if they could take a couple of
measurements.
Apart from the hole diameter I would also like to know the wall
thickness of
the die-casting, and the thickness of the top flange.
TIA
Ian Phillips
David
I am not sure what the through hole was put there for originally. My
suspicion is that it was used to locate the bobbin in the mould when the
body was being laid up.
Anyway, the through hole is about 3/16" diameter. For the purposes of my
door hinge improvement scheme I drilled out the hole to 8mm. Interestingly I
found that some of the swarf that came out was magnetic, so there seems to
have been some steel plate/bracket or whatever very close to, or fastened
to, the bobbin.
I did not remove the interior trim but would be interested to know if the
bottom door hinge bobbins are fastened to something other than just
glassfibre.
When I removed the door last weekend I found that the bottom hinge bobbin
had worn severely oval to the extent that the Mazak was completely worn away
at one part of the hemispherical recess.
I will post some pictures in the next few days showing the Bronze 'shell' I
made to reline the body recess, the stainless steel hemispherical (female)
adjusting screw, and the stainless steel ball bearing.
The drivers door now closes in a much more satisfying manner, not like a VW
door does though!
Ian Phillips
"Ian Phillips"
PostPost by: cusword » Tue Sep 27, 2005 7:55 am
As you know my interior panels are not in the car at the moment, so
I just had a look. The two bottom bobbins just sit in the sill.
From the underside there is no additional steel support. It just
looks like any other bobbin. On invesigation is does seem there was
a through hole that was filled, presumably to keep the water out.
The hole is probably to locate the bobbin, on a pin, on the jig.
Bye.............
David
On Behalf
Of david_cusworth
To: ***@***.***
drainage the
David
the
Mazak
want to make
know the
access to a
taking a door
measurements.
thickness of
> TIA
> Ian Phillips
David
My
when the
of my
Interestingly I
seems to
fastened
to, the bobbin.
if the
glassfibre.
bobbin
worn away
Bronze 'shell' I
(female)
like a VW
door does though!
Ian Phillips
cusword
PostPost by: "Ian Phillips" » Sat Oct 01, 2005 8:08 pm
Apologies if the answer to this is already in the archives but I just for
curiosity I would be interested to know where Lotus sourced the hardware for
the hinges on the 2 seater doors.
I presume the cup shaped bobbin was specifically made but were the ball
ended nylon screw and the Mazak casting proprietary to Lotus I wonder.
The casting in particular seems to be heavier (costlier) than they could
have devised if they had needed too, so perhaps the whole hinge set had come
from some other piece of equipment. It looks tailored for a GRP structure
(maybe a container manufacturer used them on lids over garbage bins!)
Ian Phillips
"Ian Phillips"
