Wife complaining...
... that after I come home from driving the S4 I smell like fumes.
While I would never admit it to her, I sometimes feel like I get a bit
of a headache after driving. The previous owner says that the header
gasket is new. The vent pipe seems well sealed to the block and air
filter. On start-up after leaving the car sit for a week or so, I get
white smoke drifting out from under the engine and into the footwells,
which seems to go away after a minute or so, but maybe its the white
color that's going away, not the fumes. Any ideas of what I can check?
Thanks. Dan '70 S4 SE
Is the car consuming coolant? Does the white cloud smaell "sweet"?
the system manager.
the system manager.
- Elan45
Dan,
I would check to see if oil is coming from the rear crank seal, running out
of the bell housing and collecting on the exhaust. Once the exhaust heats up,
it burns the oil, creating the smoke until the oil is burnt off.
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
'71 S4 SE
Minnesota
- Frank Howard
Coolant is not a problem. Car consumes a fair amount of oil, not
coolant, and no oil in coolant. Dan
Well, there you go.
the system manager.
the system manager.
- Elan45
Dan,
I would put park the car in your garage, light off, put a trouble light
inside the engine compartment and close the bonnet lid as much as
possible..then get on your knees and look in each footwell for light
leaks around all the grommets/holes from the engine bay/ firewall into
the interior.
Do the fumes smell like oil or gas (petrol)? If it's petrol, you need to
also check the fuel tank/sending unit connections/vents and any passages
from the trunk (boot) into the interior.
Or say it's the latest cologne from AXE. (Excellent TV commercials here
in the US)
Good luck.
-David
69 S4
the interior.
in the US)
Good luck.
-David
69 S4
schwartzd13 - Second Gear
The one place you should look first is inside the "drain or vent tube"
between the head and the block. See if that is plugged (you said it was not
leaking).
White smoke is usually a head gasket problem (antifreeze).but that is
usually in the exhaust..
Due to the lower pressure in the car..you will suck in anything hanging
around the engine compartment.
Tony Vaccaro
_____
Of David Schwartz
Sent: Monday, September 12, 2005 8:41 PM
To: ***@***.***
Subject: Re: [LotusElan.net] Wife complaining...
Dan,
the interior.
in the US)
Good luck.
-David
69 S4
leaking).
Tony Vaccaro
_____
Of David Schwartz
To: ***@***.***
Dan,
the interior.
in the US)
Good luck.
-David
69 S4
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
ElanGTS, 93 Caterham, 05 Elise,
99 Elise190, 05 Elise, 2005 MiataSpeed Turbo
tvacc - Coveted Fifth Gear
--- In ***@***.***, "collins_dan2000" <collins_dan@h...>
wrote:
Dan,
I'd check the condition of the trunk/boot seal. It can let in fumes
due to the shape of the body back there. As a test, you can seal it
all up with some masking tape and go driving.
Greg Z
'72 Sprint
wrote:
Dan,
Greg Z
'72 Sprint
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
