elan race set up specs
Fri Jul 08, 2005 5:34 pm
by pinsx3
what do you guys run for the following suspension specs for racing
front toe in
front camber
rear toe in
rear camber
how much travel do you guys use on the suspension (by shock rod length)
what spring rates?
what tire pressures (I am using Avon FF fronts all round)
My car seems to step the rear out a bit on turn-in after a high speed
straight. I am wondering what could cause this. I have yet to corner
weigh the car though. This could reveal something.
Pete
Fri Jul 08, 2005 5:46 pm
by s2lola
The very first thing I would check would be rear toe (check it against the
car's centreline as defined by the suspension pick up points). Then camber
(which can only be accurately adjusted with the assistance of a pyrometer).
Corner weights are the least important of the lot.
Cheers,
Bill Tebbutt
-----Original Message-----
Sent: 2005/07/08 13:34
To: ***@***.***
Subject: [LotusElan.net] elan race set up specs
front toe in
front camber
rear toe in
rear camber
how much travel do you guys use on the suspension (by shock rod length) what
spring rates? what tire pressures (I am using Avon FF fronts all round)
straight. I am wondering what could cause this. I have yet to corner weigh
Pete
AVIS DE NON-RESPONSABILITE:
Ce document transmis par courrier electronique est destine uniquement a la personne ou a l'entite a qui il est adresse et peut contenir des
renseignements confidentiels et assujettis au secret professionnel. La
confidentialite et le secret professionnel demeurent malgre l'envoi de ce
document a la mauvaise adresse electronique. Si vous n'etes pas le
destinataire vise ou la personne chargee de remettre ce document a son destinataire, veuillez nous en informer sans delai et detruire ce document ainsi que toute copie qui en aurait ete faite.Toute distribution, reproduction ou autre utilisation de ce document est
strictement interdite. De plus, le Groupe Financiere Banque Nationale et ses filiales ne peuvent pas etre tenus responsables des dommages pouvant etre causes par des virus ou des erreurs de transmission.
DISCLAIMER:
This documentation transmitted by electronic mail is intended for the use of the individual to whom or the entity to which it is addressed
and may contain information which is confidential and privileged.
Confidentiality and privilege are not lost by this documentation having
been sent to the wrong electronic mail address. If you are not the intended recipient or the person responsible for delivering it to the intended recipient please notify the sender immediately and destroy this document as well as any copies of it. Any distribution, reproduction or other use of this document is strictly prohibited. National Bank Financial Group and its affiliates cannot be held liable for any damage that may be caused by viruses or transmission errors.
