Petronix Ignition and Tach
I am posting this for the person that bought my Elan.72 Sprint
He just had a Petronix ignition installed and the tach now does not work. I
am sure somebody out there knows the answer.
How do I get the tach to work again.?
Tony Vaccaro
www.lotusowners.com
Tony Vaccaro
www.lotusowners.com
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
ElanGTS, 93 Caterham, 05 Elise,
99 Elise190, 05 Elise, 2005 MiataSpeed Turbo
tvacc - Coveted Fifth Gear
The original tach will not work with any electronic ignition system. You
must send the tach off to a gauge repair shop to have the entire guts replaced.
I don't know where to send it, but I can advise of two shops that you should
not sent it to.
The Gauge Guys (APT Instruments in Bloomington, MN)
Nisonger (in New York)
Bad experience with both.
Frank Howard
'71 S4 SE
Minnesota
not sent it to.
Frank Howard
'71 S4 SE
Minnesota
- Frank Howard
I just had a Petronix ignition and coil put into my S4 to replace a
previous Lumenition (?) electronic ignition, which will not work
with the original tach. Has something to do with sharing the
current, which the Petronix can do.
Dan
--- In ***@***.***, ***@***.***e:
Dan
I do not agree with you on this one. I installed a Pertronix ignitor ( here
in South Africa called an Aldon Igniter but the same thing ) and it worked
just fine on my original 1967 tach
Arno
replaced.
not sent it to.
Frank Howard
'71 S4 SE
Minnesota
_____
Internal Virus Database is out-of-date.
Checked by AVG Anti-Virus.
Version: 7.0.300 / Virus Database: 265.6.5 - Release Date: 2004/12/26
Arno
replaced.
not sent it to.
Frank Howard
'71 S4 SE
Minnesota
_____
- Arno Church
Dont know about other systems but Luminition works just fine in my
Sprint with original tach and a Bosch blue coil.
Brian.
64Elan/72Sprint/J.P.S.Europa/BirkinT.C.Seven
Brian.
Tony,
The Petronix works with all Smiths RMI, current sensing tachs.
Although, if my memory serves me the original wiring doesn't provide
as strong of a signal to the pulse loop pick up because of the way
it is grounded. This can lead to an intermittent or a bouncing tach.
The fix is very simple and straight forward. If you have a fax I can
send you a diagram.
send you a diagram.
- "twincams4u"
Hi there,
Any chance of just the description of what and where to do it. Difficult for me to get a fax.
twincams4u <***@***.***> wrote:
Tony,
send you a diagram.
Visit your group "lotuselan" on the web.
To unsubscribe from this group, send an email to:
How much free photo storage do you get? Store your holiday snaps for FREE with Yahoo! Photos. Get Yahoo! Photos
Tony,
send you a diagram.
The wire to power the ignitor should not be connected to the coil. It should
be run to the fuse box or some other place that is hot when in the run
position. Otherwise the power drawn by the ignitor through the tach sense
wire will confuse the ignitor. This works for me.
Rob LaMoreaux
Ann Arbor, MI USA
(734)-971-5583
Cell (734)-604-9280
Email: ***@***.***
Too many Hobbies.... Too Little Time
1969 Lotus Elan....It's not a restoration, it's a never-ending adventure.
- Rob_LaMoreaux
Mark,
On the back of the Smiths RMI tach there are three terminals on a
common plate. Two are bullet type (one male and one female) and the
other is a spade. The spade is your positive 12vdc from the vehicle
ignition switch. It's the same source of power supplying the
positive terminal of the ignition coil. The two bullet terminals are
for the pulse loop pick-up. One terminal should lead to the negative
side of the ignition coil. The other should lead to the black wire
or negative for the Ignitor. The red wire on the Ignitor can be
connected to the positive terminal on the coil. Remember it's being
fed 12vdc from the ignition switch. So in a nutshell the pulse loop
pick-up in the tach is wired in series between the negative side of
the coil and the black wire from the Ignitor. The tach in my Sprint
works perfectly this way.
I also recommend fusing the the tach power (+12vdc) from the
ignition switch with the low amp, fast acting fuse to protect
against shorts or possible surges. good luck!
- "twincams4u"
