Rear hub puller
Does anyone living in south western Ontario have a rear hub puller
that I can borrow. I need to strip both the left & right hubs.
Keith Marshall
69 S4 SE
Keith Marshall
69 S4 SE
Keith Marshall
- saildrive2001
Keith,
If you're in Windsor, I'm only 3 hours away in central Ohio. I don't
really want to ship them anywhere, but you're welcome to use them here.
Keith Marshall
69 S4 SE
the system manager.
Keith Marshall
69 S4 SE
the system manager.
- Elan45
Subject: Re: Rear hub puller
Roger,
I appreciate your offer. I live in Burlington (just west of Toronto) & would
like to find someone closer if possible. I am however going down to the Log
25 & will be picking up my friend who lives in Montpelier Ohio. If I don't
get the hubs removed before then maybe I could stop by your place on the
way. Where do you live in Ohio.
Keith Marshall
Keith,
Keith Marshall
69 S4 SE
Roger,
Keith Marshall
Keith,
Keith Marshall
69 S4 SE
Keith Marshall
- saildrive2001
So make your own. Since it is a 69 S4 SE it should be knock off, which means
a tool to remove the hubs is easy to make.
Remove or just loosen the axle nut. Get a couple of nuts to screw onto the
axle shaft so the end nut is just proud of the axle stub. Then take some
thick washers about the inner diameter of the knock off and put them in the
knock off nut. Now screw the knock off nut on so it pushes against the nuts
through the washers. This will apply uniform pressure to all the threads.
Tighten the knock off until the hub comes loose. This was shown to me by an
Elan racer and has worked fine. Now if I can just get the time to use it
again this week so I can get the bad bearing replaced.
You can also get a short piece of tube to use instead of the nuts. I think
1/2" or possibly 3/4 black gas pipe will work.
Rob LaMoreaux
Ann Arbor, MI USA
(734)-971-5583
Cell (734)-604-9280
Email: ***@***.***
Too many Hobbies.... Too Little Time
1969 Lotus Elan....It's not a restoration, it's a never-ending adventure.
- Rob_LaMoreaux
Keith,
I'm in Columbus, just off I-71. I have both a bolt-on puller and a pair
of K-O pullers I've made from steel specifically for my Elans. I would
assume you would be passing through earlier than Friday on the way to
LOG. I'd love to just take them along to LOG and pop them off for you
right there, BUT, SWMBO has other plans.
LOG 25 theme is formula cars and I'd love to be taking my 20/22 Formula
Junior. I'd love to hear the Bob Dance and Bob Sparshot talks and all
the anecdotes they will have to tell. Bear in mind I've even made the
pilgrimage to the Jim Clark room in Scotland and the other associated
Jim Clark sites in the area. (Thank you, Mike Causer for the
directions). But, we have a niece who has decided she wants to get
married in Las Vegas, of all places, the Saturday of LOG. I was furious,
but it's a losing battle. Anyone want to tow and display my car at LOG?
GRRRRRH!!!!!
Roger,
would
the Log
don't
the
Keith Marshall
Keith,
here.
Keith Marshall
69 S4 SE
the system manager.
GRRRRRH!!!!!
Roger,
would
the Log
don't
the
Keith Marshall
Keith,
here.
Keith Marshall
69 S4 SE
the system manager.
- Elan45
I have a diagram with I think dimensions on that any engineering company
could make.
Give me a few hours and I'll get it from the garage and scan it. I'll
upload it to the gallery if the quality is good enough.
Jeff 72+2
rob_lamoreaux wrote:
could make.
Jeff 72+2
jeff jackson - Fourth Gear
No to the tow and "display" offer. Now if there was an opportunity to "tow
and race", well that's another story altogether!
Say Hi to Elvis in LV for us!
BT
-----Original Message-----
Sent: 2005/06/28 09:50
To: ***@***.***
Subject: Re: [LotusElan.net] Re Rear hub puller
Keith,
I'm in Columbus, just off I-71. I have both a bolt-on puller and a pair of
K-O pullers I've made from steel specifically for my Elans. I would assume
you would be passing through earlier than Friday on the way to LOG. I'd love
to just take them along to LOG and pop them off for you right there, BUT,
Junior. I'd love to hear the Bob Dance and Bob Sparshot talks and all the
anecdotes they will have to tell. Bear in mind I've even made the pilgrimage
to the Jim Clark room in Scotland and the other associated Jim Clark sites
in the area. (Thank you, Mike Causer for the directions). But, we have a
niece who has decided she wants to get married in Las Vegas, of all places,
the Saturday of LOG. I was furious, but it's a losing battle. Anyone want to
tow and display my car at LOG? GRRRRRH!!!!!
Roger,
Keith Marshall
Keith,
If you're in Windsor, I'm only 3 hours away in central Ohio. I don't really
can borrow. I need to strip both the left & right hubs. Keith Marshall 69 S4
SE
This email and any files transmitted with it are confidential and intended
solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager.
AVIS DE NON-RESPONSABILITE:
Ce document transmis par courrier electronique est destine uniquement a la personne ou a l'entite a qui il est adresse et peut contenir des
renseignements confidentiels et assujettis au secret professionnel. La
confidentialite et le secret professionnel demeurent malgre l'envoi de ce
document a la mauvaise adresse electronique. Si vous n'etes pas le
destinataire vise ou la personne chargee de remettre ce document a son destinataire, veuillez nous en informer sans delai et detruire ce document ainsi que toute copie qui en aurait ete faite.Toute distribution, reproduction ou autre utilisation de ce document est
strictement interdite. De plus, le Groupe Financiere Banque Nationale et ses filiales ne peuvent pas etre tenus responsables des dommages pouvant etre causes par des virus ou des erreurs de transmission.
DISCLAIMER:
This documentation transmitted by electronic mail is intended for the use of the individual to whom or the entity to which it is addressed
and may contain information which is confidential and privileged.
Confidentiality and privilege are not lost by this documentation having
been sent to the wrong electronic mail address. If you are not the intended recipient or the person responsible for delivering it to the intended recipient please notify the sender immediately and destroy this document as well as any copies of it. Any distribution, reproduction or other use of this document is strictly prohibited. National Bank Financial Group and its affiliates cannot be held liable for any damage that may be caused by viruses or transmission errors.
BT
To: ***@***.***
Keith,
Roger,
Keith Marshall
Keith,
SE
DISCLAIMER:
- s2lola
Well, Bill, how much of "another story" is there, ie: how badly would you like to race it? There is the track day.
BT
To: ***@***.***
Keith,
Roger,
25 & will be picking up my friend who lives in Montpelier Ohio. If I don't get the hubs removed before then maybe I could stop by your place on the way. Where do you live in Ohio.
Keith Marshall
Keith,
SE
confidentialite et le secret professionnel demeurent malgre l'envoi de ce document a la mauvaise adresse electronique. Si vous n'etes pas le
strictement interdite. De plus, le Groupe Financiere Banque Nationale et ses filiales ne peuvent pas etre tenus responsables des dommages pouvant etrecauses par des virus ou des erreurs de transmission.
DISCLAIMER:
been sent to the wrong electronic mail address. If you are not the intendedrecipient or the person responsible for delivering it to the intended recipient please notify the sender immediately and destroy this document as well as any copies of it. Any distribution, reproduction or other use of this document is strictly prohibited. National Bank Financial Group and its affiliates cannot be held liable for any damage that may be caused by viruses or transmission errors.
Copyright* LotusElan.net and the author:
BT
To: ***@***.***
Keith,
Roger,
Keith Marshall
Keith,
SE
DISCLAIMER:
- Elan45
