Lotus Elan
Door bush replacement
PostPost by: davidallen » Tue Jun 07, 2005 7:35 am
To replace the bushes on the door pillar on my +2 I first have to remove the
countersunk screw located in the door bottom and it is stuck fast!
Rather than resort to drilling it out, are there any tips or suggestions to
aid removal.
Thanks in advance.
David
CONFIDENTIALITY NOTICE
The information contained in this e-mail is intended only for the
confidential use of the above named recipient. If you are not the intended
recipient or person responsible for delivering it to the intended recipient,
you have received this communication in error and must not distribute or
copy it. Please accept the sender's apologies, notify the sender immediately
by return e-mail and delete this communication. Thank you.
davidallen
PostPost by: "Peter Motte \(Scarl » Tue Jun 07, 2005 9:14 am
This might sound odd, but... if it is rust which blocks the screw, try to
poor Coca Cola over it. I've heard numerous rumours that it works.
----- Original Message -----
To: <***@***.***>
Sent: Tuesday, June 07, 2005 9:34 AM
Subject: [LotusElan.net] Door bush replacement
the
to
aid removal.
Thanks in advance.
David
recipient,
immediately
To search the mailing list archives:
http://www.escribe.com/automotive/europ ... index.html
http://www.lotuselan.net/publish/legal_stuff.shtml
Yahoo! Groups Links
PostPost by: type36lotus » Tue Jun 07, 2005 1:36 pm
Coca-Cola contains Phosphoric acid, same thing as the commercial
rust removers. Coke not being quite as concentrated. On my baby
Elan the hinge brackets are aluminum. If you can remove yours
(assuming they work the same)then a little heat might expand the
hinge bracket enought to free the screw.
Mike G.
--- In ***@***.***, "Peter Motte \(Scarlet\)"
try to
To: <***@***.***>
> Hi,
to remove
the
fast!
suggestions
to
> aid removal.
> Thanks in advance.
> David
the intended
recipient,
distribute or
immediately
> Yahoo! Groups Links
Mike Geiger
66 S3 Coupe', no more :-(
type36lotus
PostPost by: B7wal » Tue Jun 07, 2005 2:29 pm
I know this sounds drastic, but after much persuasion failed, I used an
impact screwdriver. A few prayers were offered initially, but the screws
cracked off with a crisp blow with a heavy hammer - and no damage -
honest!
Alan W
-----Original Message-----
Behalf Of Michael Geiger
Sent: 07 June 2005 14:35
To: ***@***.***
Subject: Re: [LotusElan.net] Door bush replacement
Mike G.
try to
To: <***@***.***>
> Hi,
to remove
the
fast!
suggestions
to
> aid removal.
> Thanks in advance.
> David
the intended
recipient,
distribute or
immediately
> CopyrightC LotusElan.net and the author:
> Yahoo! Groups Links
Yahoo! Groups Links
B7wal
PostPost by: john.p.clegg » Tue Jun 07, 2005 2:47 pm
David
If i remember correctly i had to hold mine upside down,protected from the floor and impact it out
"ALLEN, David" <***@***.***> wrote:
aid removal.
Thanks in advance.
David
PostPost by: "kandmpc" » Tue Jun 07, 2005 6:59 pm
I had the same problem and nothing I tried would move it, heat,
penetrating fluid or impact driver. I had to drill it out, it was
rusted solid.
Good luck
Ken
"kandmpc"
PostPost by: poiuyt » Wed Jun 08, 2005 4:02 am
Try the "screw out" things sold by Sears. My wife uses them at work
and has no trouble removing stuck or broken screws.
Steve B.
--- In ***@***.***, "ALLEN, David" <[email protected]>
wrote:
remove the
suggestions to
aid removal.
Thanks in advance.
David
intended
recipient,
distribute or
immediately
Steve B.<br>1969 Elan S4
poiuyt
PostPost by: davidallen » Wed Jun 08, 2005 7:38 am
Thanks for all your replies. I have already tried the impact option with no
success. Looks like I will have to get my drill out!
David
Sent: 07 June 2005 15:29
To: ***@***.***
Subject: RE: [LotusElan.net] Door bush replacement
honest!
Alan W
To: ***@***.***
Mike G.
try to
To: <***@***.***>
> Hi,
to remove
the
fast!
suggestions
to
> aid removal.
> Thanks in advance.
> David
the intended
recipient,
distribute or
immediately
> Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
davidallen
