Removing rear shock inserts
I need some help removing my rear shock inserts. I made a tool to
remove them. It is a thick steel plate with a hole in the middle that
fits over the shaft of the insert and has two tapped holes that hold
pins that fit into the notches on the threaded cap of the insert. The
problem I am having is that the metal on this cap is so soft that
whenever I try to loosen it the metal is just tearing and the cap is
not spinning.
I have torn up two of the notches on one of the inserts and wanted to
stop before trying to go further. Is there any other way of removing
this cap? It doesn't really matter if the cap is destroyed in the
process since the new shock has a new cap with a large hex nut that is
used to tighten it. I was hoping someone could give me some advice.
Nick
not spinning.
Nick
- ngiovas
Nick,
The new cap will screw into the threads replacing the old cap. I just
tapped my old ones out with a chisel.
Doug 65 Elan
Doug 65 Elan
- Howie97630
Thanks Doug. There is nothing funny about the caps (like a left hand
thread) is there? It just seems like they aren't budging. Of course, they
have been in there for over 40 years. I will try the chisel and see if that
will work. I was just worried about damaging the threads.
-----Original Message-----
Of Doug Troutman
Sent: Saturday, June 04, 2005 9:46 PM
To: ***@***.***
Subject: Re: [LotusElan.net] Removing rear shock inserts
Nick,
Doug 65 Elan
Of Doug Troutman
To: ***@***.***
Nick,
Doug 65 Elan
- ngiovas
Most of the original strut tubes had a small area peened into a recess near the top edge of top screw-in retainer. The does a very good job of preventing removal of the top cap. Suggest that you use a drill just slightly larger than the depression and drill away the depression. No need to penetrate the cap, just remove the steel tube dimple. This will free up the top to unscrew WITHOUT stripping those soft alumin(i)um threads.
Stan
Nick,
Doug 65 Elan
Stan
Nick,
Doug 65 Elan
- saarhus
Have you also tried a little heat? I have one of those high temp heat
guns which are wondeful for heating things in an even fashion. I
think mine goes to 1,500 - 1,700 degress.
Mike Geiger
66 S3 Coupe', no more
type36lotus - Fourth Gear
I did not fancy using a chisel, so I used a suitable sized plumber's
pipe wrench to grip the edge of the screw. The advantage of a pipe
wrench being the more pressure the stronger the grip. It worked a treat
and no damage.
Alan W
Behalf Of Michael Geiger
Sent: 05 June 2005 15:25
To: ***@***.***
CopyrightC LotusElan.net and the author:
and no damage.
Alan W
To: ***@***.***
- B7wal
On Sun, 05 Jun 2005 16:49:48 +0100 "***@***.***" <***@***.***> wrote:
No. In principle the fluid should flow very slowly, but stiction in the
seals would stop the whole thing moving.
My test of dampers for a slightly heavier Lotus is to pull it fully out
and push it back by hand. If I can _only_ _just_ do it, the damper is
fine, but would give a ride on the soft side of my preference. If it
won't move at all by hand then I back off the adjustment (for Koni or
Spax) until it will move, then harden until it won't. If opening &
closing it by hand is anything less than very difficult then it's shot
unless it is adjustable.
Mike Causer Email - mailto:***@***.***
GPG KeyID 1C2DDA07 WWW - http://www.mikecauser.com
Flood the fen again! - Wicken Fen enlargement - http://www.wicken.org.uk
- mikecauser
Nick
I used a pipe wrench first time around with my struts. This will mangle the
cap, but the new cartridge will have a new cap.
Andres
Andres
- abstamaria
Tube is steel; retaining nut is steel
My [steel] strut tube was also peened in several spots, but it was done later. I did not repeat it, and did have one unscrew later, handles funny thatway
----- Original Message -----
To: ***@***.***
Date: Sat, 4 Jun 2005 22:34:03 -0500
_______________________________________________
To: ***@***.***
- "e s"
On Mon, 06 Jun 2005 16:03:17 -0500, "e s" <***@***.***>
wrote:
On the replacement Koni's I've used that's certainly the case but all
the original Armstrong insert retaining nuts I've come across and had
the misfortune to remove have been aluminium.
Martin
72/45
Martin
72/45
Martin
72 Sprint DHC
72 Sprint DHC
M100 - Fourth Gear
