vacuum leak
You can check for vacuum leak by spraying WD40 on the suspect points with
the engine running, this should change the idle if there is a leak by
momentarily blocking it. If it doesn't make a difference then you probably
need to look elsewhere.
You can also use propane onto the point to test it but I have never done
this. It's come up before so the details should be in the archives.
Peter
66S2
----- Original Message -----
replacement part number?
Peter
66S2
Lincoln62 - Third Gear
Yes, I used starting fluid. Spraying shaft bearing associated with the #3 cylinder damn near shuts down the engine.
To: ***@***.***
Sent: Friday, May 27, 2005 9:42 PM
Subject: [LotusElan.net] vacuum leak
Peter
66S2
To: ***@***.***
Peter
66S2
- 65 Lotus
Scott
Sounds like you have pinpointed it then. In most carbies the shaft is metal
on metal. As Webers have bearings it would be unlikely to have wear in the
shaft or carbie body still the air has to be getting in somewhere. I would
take the bearing to a local bearing supplier, they know how to decode the
numbers and if there is a sealed bearing available they should know about
it.
btw the Weber rebuild kits I bought had a leather seal for the shaft. Can't
see how that would seal vacuum but it could be important.
Good luck
Peter
66S2
it.
Good luck
Peter
66S2
