Wiring Harness
I purchased a wiring harness from BritishWiring in Chicago for my S2 and
was quite pleased with the product. The issue I faced when I got it was "Which
wire is which?" --- relating the wiring diagram to the loom in front of me.
With a blow up of the manual's diagram - I was able to start with simple
things like the Alternator, horn, rear end and fuse box and then use a multimeter
to figure out which wire was which - by simply tracing colors on the wiring
diagram. I then labeled each one with some masking tape and was ready to
go. Took me about 3 evenings to get the whole thing figured out. Went back
into the car easily. I didn't have any pictures of the old car (I bought
it in boxes) - and everything worked perfectly the first time!!
Easier than I thought it would be - once I got into it.
Good luck
Paul Zimmerman
65 S2
Good luck
Paul Zimmerman
65 S2
- brassringfarm
Good timing... I just got my Sprint back from the paint shop, and it
seems they've crossed up most all of my lighting wiring in the
process. May be a good excuse to get a new wiring loom to replace that
funky 35 year old set anyway. You make it sound fairly easy. Thanks for
the courage.
Gary
'71 Elan Sprint
Miami, FL
_____________________________________________________________________
--- In ***@***.***, ***@***.***e:
and was quite pleased with the product.
Paul Zimmerman
65 S2
the courage.
Gary
'71 Elan Sprint
Miami, FL
Paul Zimmerman
65 S2
archigator - Fourth Gear
