Lotus Elan
experience with RS Motorsports in Closter, NJ; shock#spring
PostPost by: tvacc » Mon May 09, 2005 3:23 pm
No..I don't know of a book.
If you have the spring compressors that are 2 long bolts with hooks on both
ends..the job is a lot safer and easier.
I will be a happy to help you more.if you want to call or need more
help.contact me off list.
Tony V
_____
Of trdr_gonzo
Sent: Sunday, May 08, 2005 11:10 PM
To: ***@***.***
Subject: Re: [LotusElan.net] experience with RS Motorsports in Closter, NJ;
shock#spring ques
Hi Tony,
Thanks for the info, I have sliding splined u-joint rear axles, and
one is actually already out, due to a broken u-joint. Can you
recommend a good book that details this procedure?
best
Frank
--- In ***@***.***, "Tony Vaccaro" <[email protected]> wrote:
Get the car up in the air ..I put jackstands under the sills about
1 foot
inform the wheel wells. I also put a 2X4 between the stands and the
car. Put
a jack under the bottom of the rear hub.gently raising the rear hub
till you
just start to remove the weight of the jack stands...but then back
off ..to
put the weight back on the stands. You remove the top nut on the
shock
rod.and then you have to separate the donut at the brake disc. If
not
sliding splines..then put a ring of hose clamps around the donut
before you
remove it. This the toughest part of the job.
If you have a spring compressor..put it n the spring.that makes
this easier
and safer.
I have done this without a compressor..but watch out..that spring
it really
a missile if it gets loose. Then slowly lower the hub.keeping the
spring in
place with your hads..but again.WATCH OUT. and it will eventually
drop to
the level of the jack.and then you can pick the hub up by hand and
take out
the jack and lower it to the ground. By then the spring and shock
should be
able to "arc" out of the wheel well. You then have to remove the
shock by
turning the shock out of the tube. Very Very fine threads at the
top. I
have seen many a shock tube ruined.so be careful. If they are
originals..then there are springs and oil and stuff that must come
out of
the tube.then insert your new shock and reverse the procedure.
Don't forget
to safety wire the bolts for the disk.if it is CV's.
As for the fronts.they simply unbolt.. Take them to a Midas..or
some other
Muffler shop and have them put it on their spring compressor.and
replace the
shocks. I usually offer them $25 to do the job. Last time I did
this.the
guy nearly lost a finger. He was sorry he did it for me.
I know this is just glossing it over..but it is doable. The one
trick I
remember is the 3 bolts for the donuts that go through the
disk..only come
out in one place..right at 12 oclock. ..right in that "V" area.
Tony F
_____
On Behalf
Of trdr_gonzo
Sent: Sunday, May 08, 2005 7:42 PM
To: ***@***.***
Subject: [LotusElan.net] experience with RS Motorsports in Closter,
NJ;
shock#spring ques
Hi all,
I am considered having the shocks and springs replaced on my Lotus
Elan. Havent yet decided between Dave Bean AVO shocks with shorter
100+lbs sq inch spring setup or the original softer setup that my
car
came with.
Im not sure how big of a job this is. Is it a do it yourself kind
of
job or one best left to a pro. If its the latter, then was
wondering if
anyone has experience with RS Motorsports working on their car.
They
seem to be the closest to me. How much would a job like this cost?
Thanks in advance
best
Frank
69 Elan S4 DHC
and some other vintage vehicles
To search the mailing list archives:
http://www.escribe.com/automotive/europ ... index.html
CopyrightC LotusElan.net and the author:
_____
Terms of Service.
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
71 Spyder Elan, ElanGTS, 93 Caterham, 05 Elise,
99 Elise190, 91 M100 Elan, 74 Europa, 72 Europa JPS #15, 68 Elan Coupe RHD
tvacc
