differential
Coming home from an autocross yesterday the car was making a new noise. It
was there at steady speed, but not on acceleration or deceleration. When I
put it in the garage I needed to move it over so I pushed it and it wasn't
as smooth as it used to be. I jacked it up and the front wheel bearings are
good, but the rear end is not right. It feels like too much play in the ring
and pinion to me.
So I will be pulling the differential some time in the next few days if I
can get time in the midst of all the other things (less than 2 weeks to our
wedding).
Since I am going to take the differential out, I think I will go back to the
open differential, and try to get a 3.55:1 ring and pinion.
Anyone have a 3.55:1 set or better yet a 3.55:1 set with carrier? Of course
depending on what I find when I get things open I may be satisfied with
another 3.7:1 ring and pinion.
Rob LaMoreaux
Ann Arbor, MI USA
(734)-971-5583
Cell (734)-604-9280
Email: ***@***.***
Too many Hobbies.... Too Little Time
1969 Lotus Elan....It's not a restoration, it's a never-ending adventure.
and pinion to me.
wedding).
Rob LaMoreaux
Ann Arbor, MI USA
(734)-971-5583
Cell (734)-604-9280
Email: ***@***.***
- Rob_LaMoreaux
Well last night I went out and spun the rear wheels again and now they feel
fine. So I am thinking that it might be the bearings not the ring and
pinion.
I'll try to drain the oil in the differential and transmission tonight to
see if there is anything in there, but I am wondering if there is any easy
way to determine which bearing it might be without taking everything apart.
Any suggestions?
Rob LaMoreaux
MTS Systems Corp.
Powertrain technology Division
4622 Runway Blvd.
Ann Arbor, MI 48108
734-822-9696
Fax 734-973-1103
Main Desk 734-973-1111
www.mtspt.com
Work email: ***@***.***
Home email: ***@***.***
pinion.
Any suggestions?
Rob LaMoreaux
MTS Systems Corp.
4622 Runway Blvd.
Ann Arbor, MI 48108
734-822-9696
Fax 734-973-1103
www.mtspt.com
- Rob_LaMoreaux
Hi. My rear differential just went out on my 69 Elan +2 after push
starting the car. Can turn the drive shaft into diff with no resistance
at all with wheels on the ground, but no grinding, etc. Any guesses?
Any tricks on removing the differential (I'm planning on following
steps in shop manual). I'm thinking the spider pin may have dropped
out or sheared, which might mean simple repair if that's the case, once
I remove the diff from the car.
thanks,
steve
thanks,
steve
- nygroup
--- In ***@***.***, "nygroup" <Nygroup@a...> wrote:
Steve,
Good possibility, but check the stub axles first. They're known to
break and can be replaced with the diff in the car, albeit not easily.
Its probably just as easy to pull the diff. Comes out on the LH side,
if I recall. If the stub axle is broken, you'll come across those
first with disassembly.
Greg Z
'72 Sprint
Steve,
Greg Z
'72 Sprint
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
Greg Zelazek wrote:
car, get the car as high as possible before you start!
Pete.
Pete.
Pete.
http://www.petetaylor.org.uk
Pete.
Good chance it is a broken stub axle. The originals don't seem that strong.
And if you are taking the diff out it can be a tight fit. At first it seems
like it won't come out.
I've pulled 2 of these and both times I had to use a lever to ease it out.
Peter
66S2
----- Original Message -----
Peter
66S2
Lincoln62 - Third Gear
Could it not be a broken output shaft. If one is broken , and with an open ( ie not LS or locked) diff, you'll also be able to turn the input (prop) shaft
Arno
To: ***@***.***
Sent: Tuesday, May 17, 2005 9:05 PM
Subject: [LotusElan.net] Differential problem
thanks,
steve
Arno
To: ***@***.***
thanks,
steve
- Arno Church
Exactly this happened to me last September, when push starting the
car. It transpired it was a broken diff output shaft. I replaced
it without removing the diff, and it was easier than I expected. The
first thing is to figure out, is which side the problem is, which is
not as easy as you think, as diffs are funny things. After removing
the rotoflex coupling, I removed the circlip retaining the bearing,
and knocked out the output shaft. I could then see the break, and
could see the other section still in the diff. To my surprise I
could pull it out with my fingers. The break was not at the
splines, but it was an early shaft where they 'turned down' the
centre section, and the break was at the 'radius root', as you might
expect. On later shafts they did not 'turn down' the centre section.
I hope you find this is your problem.
David
David
- cusword
Steve,
Greg's/ Peter's advice is good. Check the stub axles first.
Since your're going to get the back of the car up in the air anyway, put the gearbox in neutral, then go under the back of the car and turn one rear wheel then the other. More than likely, turning one wheel will cause the propshaft between the diff and gearbox to turn, while the other won't. I had this same problem just last spring. The side which doesn't turn the propshaft is the broken side.
I have a short stub axle slide hammer to allow me to pull the stub axles inthe car. You could make one too. I'll send you a photo if you wish. I was very lucky in that the stub axle in my car broke very cleanly. It was not atorsion failure which results in a twisted stub axle, which then fails in a whole bunch of dirty little pie shaped fragments. In a clean two piece break, you could replace the stub axle w/o any other work. But, if it's a torsion failure w/ lots of broken pieces, the diff has to come out, come apartand be spotlessly cleaned. There is too much chance that a fragmet will remain inside and get lodged in between the gear teeth and destroy the CWP.
I also have a pot type strong magnet, about 3/4" in diameter mounted on a long screw (maybe 4" long) that I use to pull out the broken piece(s) after the stub axle/bearing has been removed.
Good luck,
Peter
66S2
the system manager.
Good luck,
Peter
66S2
the system manager.
- Elan45
Yes, it turned out exactly as described by David. Left side Output
shaft broken clear thru between splines and outside end of the shaft.
Splined piece slid right out. Had to use slide hammer to get the part
of shaft attached to bearing out, but fortunately, local Pep Boys
lets you borrow tools at no charge!
Getting the doughnut bolts out was a challenge, but compressing the
spring on that side helped. I'm replacing both side output shafts
with used Sprint shafts purchased from Dave Bean.
Thanks for all of the advice. Very helpful indeed.
steve
--- In ***@***.***, "david_cusworth"
steve
- nygroup
