Lotus Elan
Manometers was: timing problem
PostPost by: grat » Tue Apr 19, 2005 4:12 pm
On Mon, Apr 18, 2005 at 01:16:59PM -0500, Tim Engel wrote:
Unless you have to tune for emissions in your area, use a 4-tube
manometer and tune for peak vacuum (strongest vacuum) at idle.
which brings up the question: What method is used to connect a
manometer to a weber carb? Do you use a venturi plate, or clip inside
the stack, or some other method?
fj..
The one thing that unites all human beings, regardless of age, gender,
religion, economic status, or ethnic background, is that, deep down
inside, we all believe that we are above-average drivers.
-- Dave Barry
1969 S4 45/9297
grat
PostPost by: bill308 » Mon Apr 25, 2005 1:02 am
I drilled and tapped the underside of each intake manifold runner and
added a fitting at each location. When not in use, the fittings are
sealed. My friend Tim drilled and tapped the topside which make
connection of the manometer much easier but the fittings are visible.
Either location works very well with a 4-tube mercury manometer like
the motorcycle guys use. In all cases, you are measuring manifold
vacuum. This method is by far the best way to synchronize multiple
carbs. It is exquisitely sensitive and when all colums are equalized,
there is no question they are flowing equally.
Bill
fj..
-- Dave Barry
bill308
PostPost by: hantsjo » Mon Apr 25, 2005 2:04 pm
Hi Bill,
how high is the coulomb of mercury? and is there another way of taking a
tapping, without drilling. Also does anyone know of a good web site
concerning tuning dellortos.
The car's running now!! thanks to every one on the list for the help, and
Jeff for providing this forum.
TIA.
Jo
66 S2 broom broom ;-)
----- Original Message -----
added a fitting at each location.......................
hantsjo
First Gear
First Gear
PostPost by: bill308 » Mon Apr 25, 2005 11:59 pm
Jo,
I apologize in that I'm not exactly sure what the column height of
mercury is for the Elan at idle. The last time I synchronized the
carbs I used manometer fluid, for my Elan, with a specific gravity of
2.95. The column for this fluid was about 10-feet tall if I recall
correctly. Last summer I did my friend Tim's S3 Elan with a mercury
manometer but don't recall the column height of mercury. I did
however check photos I made synchronizing 40DCNF's on my 308 GTS and
they were at the 25-inch height with mercury. So, 25-inches of
mercury, with a specific gravity of about 13.54 yields a manometer
fluid column of (13.54/2.95) x(25 inches)=114.7 inches = 9.56 feet.
This agrees well with my recallection of about 10 feet. Further, you
can think of a 308 engine as 2 TC's in a V-configuration. The bottom
line is that you can expect about a 25-inch column of mercury at
idle. Remember, a near perfect vacuum will support about a 30-inch
column of mercury at atmospheric pressure.
Bill
--- In ***@***.***, "J. Lewthwaite" <[email protected]>
wrote:
Hi Bill,
taking a
help, and
TIA.
Jo
and
bill308
PostPost by: gwnorth68 » Tue Apr 26, 2005 1:05 am
More manometer tales. I can't believe anyone would actually do this!
Tom
Tom
'68 Elan S3 Roadster, '72 MGB, FFR Roadster Cxbxa Replica, 2001 Saab 9.3
Bolton Ouest, Quebec
gwnorth68
PostPost by: triumphelan » Tue Apr 26, 2005 6:30 am
I think that as long as all the manifold are reading the same ,then the carbs are in balance.
Regards John S41969 DHC
To: ***@***.***
Sent: Tuesday, April 26, 2005 12:59 AM
Subject: Re: Manometers was: [LotusElan.net] timing problem
Jo,
Bill
wrote:
Hi Bill,
taking a
help, and
TIA.
Jo
and
To search the mailing list archives:
http://www.escribe.com/automotive/europ ... index.html
Yahoo! Groups Links
a.. To visit your group on the web, go to:
http://groups.yahoo.com/group/lotuselan/
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Regards John 1969S4DHC
triumphelan
PostPost by: steveww » Tue Apr 26, 2005 7:19 am
Rather than use columns of liquid why not just use some vacuum gauges,
just like the bike boys.
e.g.
http://www.vehicle-wiring-products.co.u ... 2/vga4.jpg
William Sebestyen wrote:
Jo,
Bill
wrote:
>Hi Bill,
taking a
help, and
>TIA.
>Jo
and
Yahoo! Groups Links
Steve Waterworth
Einstein: "The faster you drive, the slower you age..."
steveww
PostPost by: "Tim Engel" » Tue Apr 26, 2005 3:21 pm
wrote:
Hi Bill,
another way of taking a tapping, without drilling.
Also does anyone know of a good web site concerning
tuning dellortos. The car's running now!! thanks to
every one on the list for the help, and Jeff for providing
this forum.
Jo,
I have written a Word.doc on the subject and would be happy to
forward it to you as a file attachment if you wish. Just ask and
forward the e-mail address where you wish to receive it I tried
uploading it to the Files section, but it's full. Are you also a
member of [email protected] ? The file is also posted there? as
well as S1S2S3Owners (naturally aspirated Esprits) and Turboesprit.
The Word.doc is written with DHLA 40's and 45's in mind (Lotus 907/
910/ 911/ 912 engines), but most of it will apply to Elans. The
only caveat is that some older Dellortos don't have all the ports the
newer ones have. For instance, the 9XX carbs have manometer vacuum
ports built in (no drilling required) as well as Air Bleed Screws for
balancing barrel to barrel on one carb. If you run into differences
we would have to talk through them.
If you drill vacuum ports, they need to be as close to the throttle
butterfly as possible. Some really funky flow dynamics take place
in an engine manifold and pressures are not uniform throughout. Get
very far from the butterfly and you could be measuring the pressure
of some reversion wave that really has nothing to do with what's
going on at the butterfly.
Tune the idle mixture screw to produce the strongest vacuum (highest
column) per cylinder. Then use the carbs' air bleed screws (in
their absence, twist the butterfly shaft) to balance the two bores on
one carb (weaken the stronger bore to match the weaker bore).
Finally, use the linkage coupler balance screw to balance one carb to
the other. The details are in the document.
I strongly recommend the Carbtune II mechanical manometer for
balancing carbs and have included source info for it. It uses steel
rods sliding in glass tubes instead of liquids. Most importantly,
it's mercury-free. There's also a link to the website of a guy who
built his own carb balancing manometer. An open manometer using a
light liquid (ie, not mercury) will be very tall. To avoid that,
he connects one end to one carb bore and the other end to the other
carb bore. That way the manometer only registers the difference in
pressure and can be quite short.
Pick up a copy of Des Hammill's book, "How to Build and Power Tune
Weber & Dellorto Carburetors".
Tim Engel
Lotus Owners Oftha North
"Tim Engel"
PostPost by: LotusRod » Tue Apr 26, 2005 8:45 pm
Bonjour Tim,
I sure would like to read your instructions on carb tuning.
If you have the time please send me a copy:
Rod
wrote:
> Hi Bill,
> this forum.
Jo,
Tim Engel
http://www.lotuselan.net/publish/legal_stuff.shtml
Yahoo! Groups Links
Rod McIntyre
LotusRod
PostPost by: "Paul Thompson" » Tue Apr 26, 2005 11:11 pm
Pls send me carb tuning instructions ***@***.***
-----Original Message-----
Behalf Of Rod McIntyre
Sent: 26 April 2005 21:45
To: ***@***.***
Bonjour Tim,
Rod
wrote:
> Hi Bill,
> this forum.
Jo,
member of [email protected] ? The file is also posted there. as
Tim Engel
CopyrightC LotusElan.net and the author:
Yahoo! Groups Links
Rod McIntyre
Yahoo! Groups Links
"Paul Thompson"
PostPost by: bill308 » Tue Apr 26, 2005 11:27 pm
Hi Tom. I saw your response below and was a bit surprised.
I think I've tried most methods at carb synchronizing over the years
so my preference of methods, in decending order, from least effective
to most effective, is as follows:
1. listening to the air hiss using a tube to the ear - not easily
repeatable and very subjective
2. a Unisynch - affects engine running at idle and is sensitive to
orientation. Can only look at one carb throat at a time
3. a BK synchrometer - gives a measure of flow rate but only does
one throat at a time. By the time you cycle through several carb
throats, the engine rpm has changed or you forgot the previous
reading. The best way to use a Synchrometer is to fix one in a carb
throat and use a second one to match the remaining throats to the
control meter. This method requires matched Synchrometers.
4. a 4-tube manometer system, one per throat, measuring the manifold
vacuum of all carbs simultaneously - all throats are monitored
constantly. An adjustment to one will affect all others and this will
be immediately visible and measureable. Actual readings are not
important, only that all columns are the same height.
Prior to purchasing a pair of 4-tube manometers for my F-car, I
considered the carbtune-II, which uses metal rods floating in a
tapered bore of glass. Environmentally, this is a good way to go but
I wasn't convinced the performance/accuracy was there.
Irregularities in the tapered bore, bore verticality, or a
contaminant causing intermittant sticking of the steel slug, was a
potential problem. In the end, I thought it difficult to beat
mercury, with all its toxicity issues. There is no sticking of the
fluid or dependance on bore taper or verticality.
Sensitivity/pulsations can be be controlled by line restrictionsl
It's the the verticle height of the column that counts. When the
columns are equal, the manifold vacuums are equal, the flows are
equal, and the engine will tick over nicely if the mixtures are
correct.
Balancing carbs is really an issue at idle and off idle. A good
balance allows one to accelerate smoothly from a stand still with
smoothness and little effort. Low speed gear changes are much
cleaner. Fuel economy is improved. I'm a happy driver.
The down side is that one has to install vacuum taps in the intake
runners. At idle, air flow is very low. Position of the tap is not
real important IMHO but, I would/did position the drilling/tap
fitting a reasonable distance from the butterfly valve of the carb.
In the case of the Weber TC head of my S2 Elan, I hid them on the
underside of the runners. For my F-Car, I modified the air injection
(emissions) plumbing from steel tubes to flexible (silicone) tubing
and achieved the same result. Balancing 8-throats is more difficult
than balancing 4-throats, but manometers make it predictable and
sure. Once you've tried it, you'll kick yourself for not always doing
it this way. The results are quite obvious to the tuner.
Bill
--- In ***@***.***, "tom moore" <[email protected]>
Tom
bill308
PostPost by: "Tim Engel" » Wed Apr 27, 2005 1:23 am
To: <***@***.***>
Sent: Tuesday, April 26, 2005 6:11 PM
Subject: RE: Manometers was: [LotusElan.net] timing problem
Paul,
See the attached Word documents. One is the instructions for tuning
Dellortos and the other is a photo with the various screws identified (it
usually opens at the start of the text... scroll up for the photo).
Feel free to get back to me if something doesn't make sense.
"Tim Engel"
PostPost by: "Tim Engel" » Wed Apr 27, 2005 1:32 am
Oops, I forgot to cut-n-paste addresses.
To the list, sorry.
To Paul, patience, it's coming.
Later,
To: <***@***.***>
Sent: Tuesday, April 26, 2005 8:24 PM
Paul,
instructions for tuning Dellortos and the other is a
photo with the various screws identified (it usually
make sense.
"Tim Engel"
PostPost by: hantsjo » Wed Apr 27, 2005 9:36 am
Hi Tim,
That would be much appreciated, Please send the attachment to
Jo
65 S2
I have written a Word.doc on the subject and would be happy to forward it to
The Word.doc is written with DHLA 40's and 45's in mind.... but most of it
will apply to Elans.....
hantsjo
First Gear
First Gear
PostPost by: "Simpson, Karl" » Wed Apr 27, 2005 9:40 am
Ditto me Tim.
Karl
S4 FHC SE
Mailto:***@***.***
Sent: 27 April 2005 10:37
To: ***@***.***
Hi Tim,
Jo
65 S2
it to
it
Copyright(c) LotusElan.net and the author:
Yahoo! Groups Links
Jordan Grand Prix Limited
Tel: +44 (0)1327 850800
Fax: +44 (0)1327 850866
www.f1jordan.com
This message may contain information which is sensitive,
confidential and protected from disclosure. If you are not an
intended recipient of this message or any part of it, please
delete it immediately and telephone Jordan Grand Prix Ltd. You
should not disclose the contents to any other person or take
copies.
Any views expressed by an individual employee are not necessarily
representative of the views, policies or attitudes of Jordan
Grand Prix Ltd.
"Simpson, Karl"
Next
