Caliper Rebuild
Baloney indeed. Fair enough. I rescind my recommendation to never use
compressed air to remove a sticky caliper piston. Far be it from me to
suggest a way in which, assuming an Elan owner does a thorough strip and
clean (of the caliper bits, get your minds out of the gutter) afterward, can
not injure him/herself.
We should encourage more daring-do on this list. The scuba tank is a great
idea - the more pressure the better (I think it was said 2000psi, vs my home
shop compressor of a measely 125psi). For laughs, can one of the
not-mathematically-challenged engineers on this list calcualte the parting
velocity of a freed caliper piston with 2000psi behind it, and also
calculate how far it might travel before landing? And while I'm at it, I
think I'll....
- Run with scissors
- Smoke at the filling station
- Light the BBQ with the lid closed
- Ride my motorcycle with no helmet
- Drive the car without seatbelts
- Carry our infant in the front seat
- Remove all eye protection from the workshop.
Ah, the zen-like freedom of a careless existance...................
Bill
-----Original Message-----
Sent: 2005/03/22 20:14
To: ***@***.***
Subject: Re: [LotusElan.net] Caliper Rebuild
Bunch of baloney.
Did this myself, biggest problem is that once one piston comes out it has to
be held in place to get the other out. If a caliper were to come apart
during this process, it would be have been very dangerous in service, as the
brake pressure can get that high. Other than that there is no danger, the
pistons CANNOT shoot anywhere.
----- Original Message -----
To: ***@***.***
Date: Tue, 22 Mar 2005 22:03:05 +0000
_______________________________________________
NEW! Lycos Dating Search. The only place to search multiple dating sites at
once.
Financiere Banque Nationale et NBCN n'assument aucune responsabilite quant a la confidentialite et l'integrite du present courriel en raison des risques d'interception inherents a l'Internet. Pour cette raison, toute opinion exprimee au terme des presentes ne reflete pas necessairement celle de Financiere Banque Nationale et de NBCN.
Due to the security risks involved in sending information over the Internet, National Bank Financial and NBCN can not be held
responsible for ensuring the confidentiality and integrity of the present e-mail. For this reason, the opinions expressed herein do not
necessarily reflect those of National Bank Financial and NBCN.
think I'll....
- Run with scissors
Bill
To: ***@***.***
Bunch of baloney.
To: ***@***.***
once.
- s2lola
I used the "reaction block" technique the last time I rebuild my calipers. In my case it is a piece of white oak cut to fit. In applying the air, just hold he nozzle near, not on, the bleeder screw. Between the nozzle trigger and varying the distance from the bleeder screw you get a relatively low pressure. If it doesn't move right away, I hold it at that level for a bit and wait. Don't be in a big hurry to increase the pressure. Moderate air pressure and patience have worked for me. I haven't tried it yet, but Iwould guess that a pressure regulator would be good to help maintain the low pressure.
Cheers!
Stan
To: ***@***.*** ; 'Martin Evans'
Sent: Wednesday, March 23, 2005 6:33 AM
Subject: RE: [LotusElan.net] Caliper Rebuild
I do note that AP says "a perfect seal between the air gun and fitting is
neither necessary or advisable". They are using low pressure air on the
pistons so they do not explode out and damage themselves against the
"reaction block".
Compressed air will continue to expand after the piston comes loose, where
an uncompressible liquid will stop expanding when the piston begins to move.
One of the best ways to move the piston is an hydraulic pump and hydraulic
fluid including the master cylinder of the car.
Rob LaMoreaux
Ann Arbor, MI USA
(734)-971-5583
Cell (734)-604-9280
Email: ***@***.***
Too many Hobbies.... Too Little Time
1969 Lotus Elan....It's not a restoration, it's a never-ending adventure.
Cheers!
Stan
"reaction block".
Rob LaMoreaux
Ann Arbor, MI USA
(734)-971-5583
Cell (734)-604-9280
Email: ***@***.***
- saarhus
Me too. Call me Lefty......
Sent: 2005/03/23 12:33
To: ***@***.***
Eye protection in the workshop? Whats that then? I just close my eyes
when using the angle grinder
Bill Tebbutt wrote:
Steve Waterworth
Einstein: "The faster you drive, the slower you age..."
To: ***@***.***
Bill Tebbutt wrote:
Steve Waterworth
- s2lola
It's Paul again - I was glad I split my calipers in half because there was
crud in the bores of some of my calipers. (There- avoided all use of the
words: "You should"!!!). Agree about the stainless. If you decide to split
your calipers, all I can say is that "I used my bolts over again". Cleaned
them up, primed the heads so that the caliper paint would adhere. When I
return to the States, I'll probably repaint them, as the (in retrospect)
crappy acrylic paint I used from the hardware store has not held up well.
Color match was real good for a year - but overall not worth it. Next time
I go for flame red urethane or maybe a nice turquoise or mint green or deep
purple. HA
Paul
26/4600
I'm in Geneva - Elan is in Cincinnati - and it's Spring in Switzerland. There's
some great roads over here. Could easily do some sliding around curves -
but if I miscalculated - they wouldn't find me till Spring! (guard rails
optional in some areas!)
purple. HA
Paul
26/4600
- brassringfarm
