Boot Hinges
Lotus Nuts -
I suspect that the boot hinge recesses are at a slight angle to the body
because the body curves slightly down toward the outside. If the hinges
just sat on the surface, the hinge pins would be pointing slightly away from
each other at a slight angle - so when you went to open the boot, it would
put a some stress on them as the boot lid tried to open straight up. Hinge
pins have to be parallel to each other and perpendicular to the plane of
opening of the boot or door.
Voila!
Paul Zimmerman
26/4600
Voila!
Paul Zimmerman
26/4600
- brassringfarm
FWIW, I always assumed that the recesses in the bodywork were
caused by somebody tightening down the hinges before the fiberglass was
fully cured, therefore still soft. You mean they actually engineered that
in? I'm impressed!
Art
Arther H. Frederick
Initial Reaction - embroidered and decorated apparel
3869 Route 66, Chatham Centre
Valatie, NY 12184
518-392-4287
in? I'm impressed!
Art
Arther H. Frederick
Valatie, NY 12184
518-392-4287
Art Frederick
S2 Roadster, built in 1965, registered in 1966, No. 26/4934
Nothing else of interest at present
frearther - Fourth Gear
