Lotus Elan
Colin's quotes
PostPost by: "Ian Phillips" » Thu Feb 10, 2005 10:46 pm
Good thinking Ian, but too technical for me. I am still thinking about where
the UK bus industry would be today if Lotus had made buses.
BTW, where is everybody? us CLOGs seem to have taken over this group
tonight, well in a small way.
Ian P
-----Original Message-----
Sent: Thursday, February 10, 2005 10:20 PM
To: ***@***.***
Subject: Re: [LotusElan.net] Colins quotes
How about E=MC2 :-)
Don't forget that if it was a Lotus bus it would be very light !!!!!!
Ian 'baffled' F.
----- Original Message -----
To: <***@***.***>
Sent: Thursday, February 10, 2005 10:13 PM
According to the EU directive, the tensile yield strength of a 6mm (1/4" in
old money) bolt must be:
Yield strength Rp0, 2 min 640 MPa.
So does that answer your question?
Pete.
"Ian Phillips"
PostPost by: M100 » Thu Feb 10, 2005 11:13 pm
On Thu, 10 Feb 2005 22:46:02 -0000, "Ian Phillips"
<***@***.***> wrote:
I am still thinking about where the UK bus industry would be today if
At the side of the road with the bonnet up?
Martin
72/45
Martin
72 Sprint DHC
M100
PostPost by: "Paul Adamson" » Thu Feb 10, 2005 11:41 pm
Maybe the rest of the LotusElan.net are out driving along winding
mountain roads.
Leaving a trail of Porches and BWM's in their oily tracks.
Bob Metz is parked at a drive through trying to explain why his car has
no "Cup" holders. Super size or otherwise.
Rob LaMoreaux is trying to measure the luggage capacity of his Elan -v-
his Corvette
65 Lotus was hurt in a bizarre "Gas tank" welding experiment
ardee_slby is trapped by defective door stays
Brian Goodison is still perplexed by his gearbox
Briggs Pletcher is looking for a windshield
***@***.*** in Africa or someplace.
e s is playing at a re-wire.
Edwards Ray, is gluing a model Elan together
elanspring71 is struggling with his bad back.
Ian Phillips is attempting to measure the tensile strength of 1960's
1/4" bolts. (We want a graph)
Brian Gush is trying to get an S4 bonnet (hood) to fit an S2..........
eFFing Ian is gazing a grazing sheep.
Trevor can't get his starter to start.
Gareth is busy changing his wheels.
Scott potter's looking for a grommet
Sean murray's got 5 speeds and a squeak
William "kip" king can't get his dipping stick to seal
<Drum roll>
At the end of the alphabetical list.....
Zuckerman tells us that "Land Rover is owned by Ford."
Get out more Zuckerman!
Paul <Needs a new hobby> Adamson.
Sent: 10 February 2005 22:46
To: ***@***.***
Subject: RE: [LotusElan.net] Colin's quotes
where
Ian P
"Paul Adamson"
PostPost by: jeff wolfson » Fri Feb 11, 2005 4:44 am
...And Paul Adamson DEFINITELY has too much time on his hands!
Jeff
Sent: 11 February 2005 01:43 AM
To: ***@***.***
Maybe the rest of the LotusElan.net are out driving along winding mountain
roads. Leaving a trail of Porches and BWM's in their oily tracks.
Bob Metz is parked at a drive through trying to explain why his car has no
"Cup" holders. Super size or otherwise. Rob LaMoreaux is trying to measure
the luggage capacity of his Elan -v- his Corvette 65 Lotus was hurt in a
bizarre "Gas tank" welding experiment ardee_slby is trapped by defective
door stays Brian Goodison is still perplexed by his gearbox Briggs Pletcher
is looking for a windshield ***@***.*** in Africa or someplace. e
s is playing at a re-wire. Edwards Ray, is gluing a model Elan together
elanspring71 is struggling with his bad back. Ian Phillips is attempting to
measure the tensile strength of 1960's 1/4" bolts. (We want a graph) Brian
Gush is trying to get an S4 bonnet (hood) to fit an S2.......... eFFing Ian
is gazing a grazing sheep. Trevor can't get his starter to start. Gareth is
busy changing his wheels. Scott potter's looking for a grommet Sean murray's
got 5 speeds and a squeak William "kip" king can't get his dipping stick to
seal & <Drum roll> At the end of the alphabetical list..... Zuckerman tells
jeff wolfson
First Gear
First Gear
PostPost by: john.p.clegg » Fri Feb 11, 2005 7:04 am
And i'm busy trying to fit my five speeder(saving 14lbs and with the gear lever 1" further back
mountain roads.
PostPost by: twincamracing » Sat Feb 12, 2005 1:04 am
mountain roads.
and why aren't you? ;)
been busy as my son had a lady pull out in front of him
writing off his Alfa 75 V6,
very messy but he walked away :)
scott
__________________________________
Do you Yahoo!?
The all-new My Yahoo! - Get yours free!
http://my.yahoo.com
twincamracing
