Fuel sender for fuel cell
PostPost by: griffo » Mon Jan 17, 2005 4:37 pm
Has anyone found a way to make the Centroid fuel sender CFG 12 in the direct
replacement fuel cell work with the Smiths gauge FG 2530/71 as used in the
series 1, 2 and early series 3. Bean says it should work but I have not had any
success.
Thank you Peter
griffo
First Gear
First Gear
PostPost by: triumphelan » Mon Jan 24, 2005 11:46 am
Thanks for all the responce.
I put a 10K pot on place of the sender and could move the gauge from empty to full ,sender u/s ,but when I replaced the wire on the sender it is now working ???.I now have 2gal can of petrol in car and will monitor the gauge
Regards John 1969S4 DHC
Regards John 1969S4DHC
triumphelan
PostPost by: nebogipfel » Mon Jan 24, 2005 7:57 pm
--- In ***@***.***, "John Harrison" <johnharrison@d...>
monitor the gauge
If the wire was shorting to earth you would get a full reading on the
gauge, but I can't really see how it would happen from what you describe?
I dunno!
nebogipfel
PostPost by: triumphelan » Tue Jan 25, 2005 2:01 pm
Whats the norm. for an S4 with Webers 40`s.I am getting about 18miles/imp. gal.just local runs no high speed or motorway use.
BTW re my posting recently on fuel tank sender units mine is NFG ,the gauge sat at full for ever then moved to half full where it sat for ever it then went quickly to empty ,it happened so quick I ran out of fuel ,I have been carring a can of petrol since the sender has been suspect so no big deal .
triumphelan
