Lotus Elan
Found it--now what? Re: Brake Fluid Leaks
PostPost by: davidwinegar » Sat Jan 15, 2005 12:05 pm
Ian, You were right--I checked under the pedals and my rubber mat
(luckily I had those and not just carpet) had brake fluid all over it.
Now what should I look for? Is it the master cylinder that is
leaking? Should I tear it all apart? Can it be repaire, or should I
look for a new one?
Thanks all for the suggestions.
David
--- In ***@***.***, "Ian Phillips" <[email protected]> wrote:
It might be worth checking to see if the carpet and underfelt behind the
pedals is saturated. They can be quite absorbent so you might not
see it at
first.
Ian Phillips
-----Original Message-----
Sent: Thursday, January 13, 2005 6:35 PM
To: ***@***.***
Subject: [LotusElan.net] Brake Fluid Leaks
Put my car away for the winter in mid November and now have noticed
that the brake fluid reservoir is loosing fluid. The leak is very
slow--I have filled it twice in the past 2 months adding just a bit
but it is for sure leaking.
I have looked at the obvious locations around the servos and all the
break line connections and even around the wheels to see if the
calipers are leaking, but so far nothing has shown up. I even put
clean cardboard under the car to try to spot leaks, but again nothing
has shown.
Anyone have an idea of where I might look or how I might go about
tracing the leak?
Thanks for the help.
David
1970 +2S Helsinki
To search the mailing list archives:
http://www.escribe.com/automotive/europ ... index.html
http://www.lotuselan.net/publish/legal_stuff.shtml
Yahoo! Groups Links
davidwinegar
PostPost by: Briggs1 » Sat Jan 15, 2005 3:27 pm
Pull the master cylinder and rebuild it.
Easy job, then bleed the brakes.
Briggs Pletcher
Sent: Saturday, January 15, 2005 7:04 AM
To: ***@***.***
Subject: [LotusElan.net] Found it--now what? Re: Brake Fluid Leaks
look for a new one?
David
Briggs1
PostPost by: "nebogipfel2004" » Sat Jan 15, 2005 5:08 pm
You could put a seal kit in it I certainly would the clutch master but
as it is the brakes and they aren't expensive I would always suggest
fitting a new master cylinder.
"nebogipfel2004"
