Lotus Elan
weights
PostPost by: foggy » Sun Dec 19, 2004 7:57 pm
no help with weights????
motor,
trans
drive shaft
the big stuff...
thanks, all
foggy
PostPost by: garyeanderson » Sun Dec 19, 2004 11:14 pm
motor - 240 to to 250 pounds (240 in the Dave Bean Catalog)
trans - 70 to 75 including bellhousing (guessing, I've moved a few)
drive shaft - not a lot!
the big stuff...
thanks, all
garyeanderson
PostPost by: StressCraxx » Mon Dec 20, 2004 4:07 pm
Motor = 260lbs including accessories, generator, carbs, fuel pump, etc.
Gearbox including bell housing is approx 60-65 lbs
Driveshaft = not sure.
If you are trying to lose weight, I recall one or two of the usual vendors sell various bits in light alloy, such as the bell housing, tailshaft housing, diff housing, and there is an aluminum engine block available as well. All will lighten your elan as well as your wallet....
Happy Holidays to all
Dan Wise
Elan DHC S3-SS
45/7279
Message: 9
Date: Sun, 19 Dec 2004 19:56:09 -0000
Subject: weights
motor,
trans
drive shaft
the big stuff...
thanks, all
Do you Yahoo!?
Take Yahoo! Mail with you! Get it on your mobile phone.
StressCraxx
PostPost by: poiuyt » Tue Dec 21, 2004 2:49 pm
The Elan is so light to start with it seems silly to worry about the
weight of the mechanical bits. Just a thought, but unless you weigh
in the area of 150 pounds yourself, you can lighten the car more by
taking going on a diet!. I'm in this category myself.
There were 200 pound people in my bicycle club who used to spend large
amounts of money to lighten their bikes by a few ounces - but never
did anything about themselves.
Steve B.
etc.
wallet....
Dan Wise
Elan DHC S3-SS
45/7279
Message: 9
Subject: weights
motor,
trans
drive shaft
the big stuff...
thanks, all
Do you Yahoo!?
Steve B.<br>1969 Elan S4
poiuyt
PostPost by: foggy » Tue Dec 21, 2004 9:31 pm
I'm thinking about hayabusa power and trans...
the
weigh
large
Steve B.
pump,
etc.
usual
block
wallet....
> Dan Wise
> Elan DHC S3-SS
> 45/7279
> Message: 9
> From: "foggyalfa"
> Subject: weights
> motor,
> trans
> drive shaft
> the big stuff...
> thanks, all
> Steve
> Do you Yahoo!?
foggy
PostPost by: mct340 » Fri Dec 24, 2004 5:42 pm
Check this out. David has done the engineering for you. Not cheap.
www.super7cars.com
mct340
