Cylinder head breather
Many of the metal cages which hold the the water bottle to your bike
frame have holes only on one side. Some have a metal bottom which
you can drill some holes into so you can bolt the cage upright
without having to make a "L" bracket to support it.
--- In ***@***.***, "ALLEN, David" <david.allen@e...>
wrote:
Mike Geiger
66 S3 Coupe', no more
type36lotus - Fourth Gear
You CUT the drinking nipplle off ??? Thats the best bit
Regards John 1969S4 DHC
----- Original Message -----
To: ***@***.***
Sent: Thursday, December 09, 2004 12:05 PM
Subject: Re: [LotusElan.net] Cylinder head breather
Yes, that is what I have for my radiator overflow. I cut the
drinking nipple off, instered a gromet in the hole, then the tube
into the gromet. The bottle cage is screwed down from the bottom.
Mike Geiger
To: ***@***.***
Mike Geiger
wrote:
Regards John 1969S4DHC
- triumphelan
Trouble with using a pretty bottle here in the UK is that as a crankcase
breather system I don't think it is legal..
Hence the stealth approach...
BTW my current Rad over flow bottle is a indian tonic bottle (the car
came without one and this was the only one I could find that fitted!
Michael Geiger wrote:
Dr Tim Dafforn
MRC Fellow
Biosciences
University of Birmingham
Edgbaston
Birmingham
B15 2TT
(0121) 414 5881
Dr Tim Dafforn
MRC Fellow
Biosciences
Edgbaston
Birmingham
B15 2TT
(0121) 414 5881
tdafforn - Coveted Fifth Gear
Tim wrote:
I'm not so sure - I can't find any reference to breathers in
http://www.motuk.co.uk/manual/contents.htm
but as it happens I'm off to get the wife's Mini tested this afternoon, so
if I remember I'll ask.
Jon
Jon
- JonHobden
In 750 clubman racing/hillclimbing/sprinting etc where many of the cars have
to have MOT's, it is legal to have the pipe open and drip onto the
racetrack. However, the bottle solution has been used for years.
The good old crossflow is still widely used and you see many Sylva's etc
with plastic 2pt milk bottles strapped in the engine bay!
However as I don't go racing (yet) in my Stylus I just used a small K&N
filter and vented to atmosphere.
David
-----Original Message-----
Sent: 10 December 2004 10:37
To: ***@***.***
Dr Tim Dafforn
MRC Fellow
Biosciences
Edgbaston
Birmingham
B15 2TT
(0121) 414 5881
David
To: ***@***.***
Dr Tim Dafforn
MRC Fellow
Biosciences
Edgbaston
Birmingham
B15 2TT
(0121) 414 5881
- davidallen
If someone wants an oil breather with filter and valve for a 116E block, I
have some, used spare from my Lotus Seven pre-XF, which I will ship for
the costs of P&P. I can email a picture, if you want.
Vulcan http://www.vulcanengines.com/ has breathers and an aluminium catch
tank, which can be found on their home page.
Leo
"Hobden, Jon" <***@***.***>
10-12-2004 12:07
Please respond to
lotuselan
To
cc
Subject
RE: [LotusElan.net] Cylinder head breather
Jon
Leo
10-12-2004 12:07
Please respond to
lotuselan
To
cc
Subject
Jon
Lotus Elan Sprint FHC 1971
Lotus Seven S2 pre-XF 1961
leojenbo - First Gear
Remember you cannot use the valve unless the pipe is connected to the inlet
manifold, otherwise it will not work!
Sent: 10 December 2004 11:35
To: ***@***.***
Subject: RE: [LotusElan.net] Cylinder head breather
Leo
10-12-2004 12:07
Please respond to
lotuselan
To
cc
Subject
Jon
To: ***@***.***
Leo
10-12-2004 12:07
Please respond to
lotuselan
To
cc
Subject
Jon
- davidallen
Hi Jon,
The issue of crankcase breathers came up in the truimph forum when I
owned a spitfire. In theory apparently the reason car manufacturers
moved from an open breather system to putting the fumes through the
carbs was because the law changed (some of the older cars seemed to put
more nasty stuff out through the breathers than the exhaust).
This was an issue for me at the time as I had dumped the stock SUs in
favour of Webbers, making routing the breather system an issue.
However it seems now that MOT inspectors see so few cars old enough to
have the option of open systems, that they rarely look.
certainly, I just directed onto the road and no one noticed!
There is a nice Lucas water bottle used on later BMC cars. About the same
size as a drink bottle and there is a cage for it. I believe it is still
available.
Fred T.
available.
Fred T.
Fred Talmadge - Fourth Gear
Yes it was emission laws that got that fixed. I remember seeing cars
blowing oil out of the tube. A lot was a sign of immanent expense. Also
race tracks don't want you blowing oil on the road either.
Fred T
Fred T
I found that the only thing that kept the breather hose in the head
was the fact that it is squeezed between the head and the air
cleaner. If the pipe is hanging down into an overflow, what keeps it
from falling out of the head?
Steve B.
--- In ***@***.***, Tim Dafforn <T.R.Dafforn@b...>
Steve B.
wrote:
Steve B.<br>1969 Elan S4
- poiuyt
The vent to atmosphre pipe also had a tab with a hole to be mounted
to the tramsmission. This fastened the breather pipe to something
rigid.
Mike G
rigid.
Mike G
Mike Geiger
While I had my engine out and the head off I tapped the breather hole in the head and fitted an hose connector now it can`t fall out or leak and i route it to a bottle in front of the radiator
To: ***@***.***
Sent: Friday, December 10, 2004 6:05 PM
Steve B.
To: ***@***.***
Steve B.
- triumphelan
Tim wrote:
Straight from the MOT man's mouth (or VOSA man as it now seems to be):
(IANAL, but) he confirmed that there is no requirement to inspect or test
for fumes (or anything else) from any orifice other than the exhaust. The
manufacturers took to positive crankcase ventilation presumably in response
to some C&U reg (about 1964-5 as I remember), but (and HINAL either) "you
would be unlucky to find a copper that would do you" unless the engine is
breathing so heavily that the rings are so knackered the exhaust emissions
test would probably fail too.
So, with an engine in respectable condition, you should have no problem (in
the UK) running to a catch tank (which is only a competition requirement) or
simply venting to somewhere out of the way. Certainly from my experience
of Minis, after they had introduced PCV, they then went on to put an extra
breather in the flywheel housing which had not much more than a Brillo pad
by way of filtering, so I'm not at all sure how stringent the C&U regulation
was.
The other side of all this is the theory that if you use manifold vacuum to
evacuate the crankcase, it assists piston ring sealing, but I have never
been convinced that compared with combustion chamber pressure there would be
much to gain....
Anyway, wife's car now through, my Land Rover is booked in for this
afternoon, and as it has got through the last 5 tests without work, I'm
expecting to have to do something this year! And I really must get around
to having them tested at a better time of year, and preferably more than 2
weeks apart.....
Jon
was.
much to gain....
weeks apart.....
Jon
- JonHobden
