+2 Rear bumper
Does anyone know what the +2 rear bumper was off? The front bumper, as
everyone know's, was from a Ford Anglia, but from what was the rear bumper
taken?
Thanks in advance.
David
taken?
Thanks in advance.
David
- davidallen
David,
As I understand, the tooling was the same as the Riley Elf/Wolseley Hornet, with the centre section extended, ie it's not a bolt-on swop.
Sean Murray
----- Original Message -----
To: ***@***.***
Sent: Wednesday, December 01, 2004 9:17 AM
Subject: [LotusElan.net] +2 Rear bumper
taken?
Thanks in advance.
David
Sean Murray
To: ***@***.***
taken?
Thanks in advance.
David
Foxie - Coveted Fifth Gear
I have just had a look at a few elf's for sale on ebay, and I think you may
be right!
It looks like they use the same number plate lights, but have overriders
fitted, so I guess that is why my bumper has two chrome bolts, one at each
end, which do not seem to serve any purpose.
David
-----Original Message-----
Sent: 01 December 2004 11:53
To: ***@***.***
Subject: Re: [LotusElan.net] +2 Rear bumper
David,
Sean Murray
To: ***@***.***
taken?
Thanks in advance.
David
be right!
David
To: ***@***.***
David,
Sean Murray
To: ***@***.***
taken?
Thanks in advance.
David
- davidallen
I have posted this list to the group before.......I'm not saying its the
bible of where the bits came from but it?s a good guide......if anyone
knows any differences for certain please could you let me know so I can
update my list.......
Gareth
Boot hinges ? Hillman Imp
Windscreen ? Ford Capri Mk1 , Consul Classic, Scimitar
Chrome windscreen Filler strip ? BL mini
Wiper blades ? Trico B7
Window motor Ford Wiper motor
Exterior door Handle, Early +2 BL 100 & 1300
Late +2s BL Dolomite, TR6, Toledo.
Interior Door Handle
Early +2 Ford Cortina Mk 1 & Mk 2
Late +2s BL Maxi, 1800 & 3 Litre
Cooling air intake Chrome trim ? Anglia Basic Saloon and Van
Front Bumber Ford Anglia
Rear Bumper Wolseley Hornet / Riley Elf Extended approx 1? by joining
three sections.
Door Check arms Rover 2000
Door hinge bushes same as Trunnion bushes.
Front Suspension
Front Discs ? Triumph
Vertical Link? Triumph
Steering arm? Triumph
Trunnion and kits? Triumph
Damper and anti roll bar bushes? Triumph
Upper Ball Joints? Triumph
Shock absorber Lower bushes ? Same as Differential torque bushes
Wheel Bearings ? Hoffman Inner 1A 17
Outer 1B 12
Rear Suspension
Upper Leg spring plate ? Ford Anglia
Disc ? Girling
Doughnuts ? Lotus only (Imp and Imp competition Doughnuts are the same
dimensions)
Wheel Bearings ? Outboard & Inboard 6206 2 RS
- Inboard with seal 412971
- Ford Cortina
Engine
Engine based on MK1 1500 Ford Cortina Engine block Many parts are Ford
Anglia, Classic, Cortina MK1 & MK2 Original fitment.
Oil Filter ? AC MF 63000A
Water Pump ? Some Parts are Ford.
Valve shims ? BL Rover SD1, Princess, Dolomite ( check thickness range)
Oil Pump ? Ford 105E, 1600 GT
Oil Pressure sender unit ? Smiths Part No. PT1817/06
Fuel Pump ? AC mechanical (Kit AC BD6)
Fan Belt ? Dynamo Belaco R547 or RH789
- Alternator RH 684
Air Filter ? AC 2047
Bellhousing and Crankcase plates ( 4 Speed Box ) Ford Cortina
Sump ? Ford Cortina
Gearbox
4 Speed Ford Corsair 200E
Mounting Ford Cortina ( Ford Part No 170169)
5 Speed Austin Maxi internals ? Lotus Case
Road Wheels
Wheel Trim - Ford Escort
Steering
Rack ? Basically Triumph Herald/Vitesse/Spitfire, but modified for Lotus
by fitting lock limiting spacers
Column & UJ ? Triumph Herald/Vitesse/Spitfire
Indicator Switch and housing Triumph Herald/Vitesse/Spitfire
Ford Cortina MK2
Brakes
All brake systems are Girling
Caliper Pistons ? Girling:
Front: Early 6432 5561 ( Kit ? SP 2501)
Late 6432 1880 ( Kit ? SP2589)
Rear 6432 5873 ( Kit ? SP 2515)
Rear Calipers Lotus only by Girling
Servo ? Girling Early kit SP 2228 / 3
Late kit SP 2625
Hoses Front & rear Girling 7404 7464
Cooling
Radiator ? Triumph ( two Types) ? Herald
Top hose ? Ford Anglia 105E
Fuel System
Sender unit ? Smiths
Filler Caps ? Scimitar, Gilbern, Triumph
Electrics
Main items ? Lucas ( some AC )
Points ? Lucas CS1 Cortina Mk1
Headlamps ? Lucas 700 ? BL Mini / 1100 etc
Headlamp Chrome Rim ? MGB.
Front Indicator Lamps ? Lucas ? Lotus only
Rear Lamps Lucas modified E-type Jaguar, Alfa Romeo
Number plate Lamp ? BL Wolseley Hornet / Riley Elf.
Wndscreen wiper switch ? Lucas , Cortina Mk1 & MK2
Starter Solenoid ? Lucas Part No 76766
Tachometer ? Smiths RVI 2402/04 (Positive Earth)
Dynamo ? Lucas C40 ? BL Mini, Ford Cortina.
Heating
Heater ? Smiths - MG Midget
Air Facia Vents ? Hillman Hunter ( circa 1965) Still made in Iran!
Clutch
Clutch Plate and Pressure plate ? AP 47625/209
Master Cylinder ? Girling 64068832 (Kit SP 1963)
Slave Cylinder ? Girling 64067950 ( Kit SP 2204)
Clutch operating arm/thrust bearing ? Ford Cortina.
Clutch Hydraulic Pipe ? Ford Anglia (Ford Part No.174 7211
Rear Drive
Diff internals ? Ford. Ratios differ, but all are ford except 3.55:
nearest is 3.54 Ford Escort RS.
Sent: 01 December 2004 15:31
To: ***@***.***
Subject: RE: [LotusElan.net] +2 Rear bumper
may
be right!
each
David
To: ***@***.***
David,
Hornet,
Sean Murray
To: ***@***.***
bumper
taken?
Thanks in advance.
David
Gareth
three sections.
Front Suspension
Outer 1B 12
Rear Suspension
Disc ? Girling
dimensions)
- Ford Cortina
Engine
- Alternator RH 684
Sump ? Ford Cortina
Gearbox
Road Wheels
Steering
Ford Cortina MK2
Brakes
Late kit SP 2625
Cooling
Fuel System
Electrics
Heating
Clutch
Rear Drive
To: ***@***.***
may
be right!
each
David
To: ***@***.***
David,
Hornet,
Sean Murray
To: ***@***.***
bumper
taken?
Thanks in advance.
David
- EMA7K
Gidday Gareth,
That is a bloody good list you have compiled, my compliments.
Les, Australia.
To: ***@***.***
Sent: Thursday, December 02, 2004 1:42 AM
Subject: RE: [LotusElan.net] +2 Rear bumper.......now +2 PARTS LIST
bible of where the bits came from but it's a good guide......if anyone
Gareth
Boot hinges - Hillman Imp
Windscreen - Ford Capri Mk1 , Consul Classic, Scimitar
Chrome windscreen Filler strip - BL mini
Wiper blades - Trico B7
Cooling air intake Chrome trim - Anglia Basic Saloon and Van
Rear Bumper Wolseley Hornet / Riley Elf Extended approx 1" by joining
three sections.
Front Suspension
Front Discs - Triumph
Vertical Link- Triumph
Steering arm- Triumph
Trunnion and kits- Triumph
Damper and anti roll bar bushes- Triumph
Upper Ball Joints- Triumph
Shock absorber Lower bushes - Same as Differential torque bushes
Wheel Bearings - Hoffman Inner 1A 17
Outer 1B 12
Rear Suspension
Upper Leg spring plate - Ford Anglia
Disc - Girling
Doughnuts - Lotus only (Imp and Imp competition Doughnuts are the same
dimensions)
Wheel Bearings - Outboard & Inboard 6206 2 RS
- Ford Cortina
Engine
Oil Filter - AC MF 63000A
Water Pump - Some Parts are Ford.
Valve shims - BL Rover SD1, Princess, Dolomite ( check thickness range)
Oil Pump - Ford 105E, 1600 GT
Oil Pressure sender unit - Smiths Part No. PT1817/06
Fuel Pump - AC mechanical (Kit AC BD6)
Fan Belt - Dynamo Belaco R547 or RH789
- Alternator RH 684
Air Filter - AC 2047
Sump - Ford Cortina
Gearbox
5 Speed Austin Maxi internals - Lotus Case
Road Wheels
Steering
Rack - Basically Triumph Herald/Vitesse/Spitfire, but modified for Lotus
Column & UJ - Triumph Herald/Vitesse/Spitfire
Ford Cortina MK2
Brakes
Caliper Pistons - Girling:
Front: Early 6432 5561 ( Kit - SP 2501)
Late 6432 1880 ( Kit - SP2589)
Rear 6432 5873 ( Kit - SP 2515)
Servo - Girling Early kit SP 2228 / 3
Late kit SP 2625
Cooling
Radiator - Triumph ( two Types) - Herald
Top hose - Ford Anglia 105E
Fuel System
Sender unit - Smiths
Filler Caps - Scimitar, Gilbern, Triumph
Electrics
Main items - Lucas ( some AC )
Points - Lucas CS1 Cortina Mk1
Headlamps - Lucas 700 - BL Mini / 1100 etc
Headlamp Chrome Rim - MGB.
Front Indicator Lamps - Lucas - Lotus only
Number plate Lamp - BL Wolseley Hornet / Riley Elf.
Wndscreen wiper switch - Lucas , Cortina Mk1 & MK2
Starter Solenoid - Lucas Part No 76766
Tachometer - Smiths RVI 2402/04 (Positive Earth)
Dynamo - Lucas C40 - BL Mini, Ford Cortina.
Heating
Heater - Smiths - MG Midget
Air Facia Vents - Hillman Hunter ( circa 1965) Still made in Iran!
Clutch
Clutch Plate and Pressure plate - AP 47625/209
Master Cylinder - Girling 64068832 (Kit SP 1963)
Slave Cylinder - Girling 64067950 ( Kit SP 2204)
Clutch operating arm/thrust bearing - Ford Cortina.
Clutch Hydraulic Pipe - Ford Anglia (Ford Part No.174 7211
Rear Drive
Diff internals - Ford. Ratios differ, but all are ford except 3.55:
To: ***@***.***
may
be right!
each
David
To: ***@***.***
David,
Hornet,
Sean Murray
To: ***@***.***
bumper
taken?
Thanks in advance.
David
Les, Australia.
To: ***@***.***
Gareth
three sections.
Front Suspension
Outer 1B 12
Rear Suspension
Disc - Girling
dimensions)
- Ford Cortina
Engine
- Alternator RH 684
Sump - Ford Cortina
Gearbox
Road Wheels
Steering
Ford Cortina MK2
Brakes
Late kit SP 2625
Cooling
Fuel System
Electrics
Heating
Clutch
Rear Drive
To: ***@***.***
may
be right!
each
David
To: ***@***.***
David,
Hornet,
Sean Murray
To: ***@***.***
bumper
taken?
Thanks in advance.
David
- lotuselanman
