ride height
Hi.
Maybe the collective wisdom of the group could help be solve a long
running mystery with my S3.
I built the car some years ago from a dismantled wreck. Ever since then it
has ridden too high at the back by maybe 11/2" (compared to friends' cars)
and hence the handling is iffy.
Everything is standard (as far as I can tell) except that its on a Spyder
(non -space-fame) chassis. I have changed the springs for new ones and
checked the Lotocones are the right way up.
What else could it be?
Is it possible that I have inadvertently got +2 uprights? Does anyone know
if the spring platforms on a +2 are higher then on a small elan?
Any help gratefully received.
Nick
This is a PRIVATE message. If you are not the intended recipient, please
delete without copying and kindly advise us by e-mail of the mistake in
delivery. NOTE: Regardless of content, this e-mail shall not operate to
bind CSC to any order or other contract unless pursuant to explicit
written agreement or government initiative expressly permitting the use of
e-mail for such purpose.
Nick
- NickWilmshurst
Nick,
I don't know if this will help, but if you tightened the pivot bolts that
attach the lower control arms to the chassis while the car was raised and the
suspension was at full droop, it's possible that is what is causing the jacked up
situation. Loosen the attachment bolts, drive the car up on to ramps, then
go under and re-tighten the bolts. Hope this helps.
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
'71 S4 SE
Minnesota
- Frank Howard
Were the rear wishbone bushing nuts tightened with the car's weight
on the wheels? If the wheels were hanging when these bolts were
tightened the bushings will act as tortion bars and cause an
increased ride height (although I don't know if it woild make a 1
1/2" difference).
Steve B.
--- In ***@***.***, Nick Wilmshurst <NWilmshurst@C...>
1/2" difference).
Steve B.
wrote:
Steve B.<br>1969 Elan S4
- poiuyt
Being the curious type.
I experimented to see if the position in which the rear wishbone bolts
were tightened affected the ride height.
Well, it doesn't.
I think however, that it'll shorten the life of the bushes.
How much? I can't say. I'll leave that experiment to someone else.
Paul Adamson.
-----Original Message-----
Sent: 29 November 2004 16:05
To: ***@***.***
Subject: [LotusElan.net] Re: ride height
1/2" difference).
Steve B.
wrote:
CopyrightC LotusElan.net and the author:
Well, it doesn't.
Paul Adamson.
To: ***@***.***
1/2" difference).
Steve B.
- paul_adamson
