Lotus Elan
Headlamp pods
PostPost by: "david_cusworth" » Wed Nov 24, 2004 10:20 am
I have just removed the headlamp pods from our S3 and have some
questions.......
1. The holes which the spring, and vacuum rod, fix to are
elongated. Is this because it gives you some adjustment so the pod
is in the correct position when down, or did someone drill it in the
wrong place?
2. Each pod had a switch which presumably inhibits the power to the
headlight. Only the right hand one (UK car) is wired up. Is this
correct? Why is there an unused switch on the other side?
3. There is nothing at the pivot bolts between the headlamp pod and
body. It's just paint, grinding on paint. Is it a good idea to fit
a thin neoprene/nylon washer here?
David
"david_cusworth"
PostPost by: "Simpson, Karl" » Wed Nov 24, 2004 10:32 am
Point 2. The microswitchs are used to prevent the headlamps coming on whenthe pods are retracted. With the headlamp switch off, the lamps will flash when raised (I presume this is the unused switch. There will be a flasher relay next to the headlamp relays). Conversely with the headlamps switch on the lights will come on when the pods are raised.
Hope this helps,
Karl
S4 FHC SE
-----Original Message-----
Sent: 24 November 2004 10:20
To: ***@***.***
Subject: [LotusElan.net] Headlamp pods
questions.......
wrong place?
David
To search the mailing list archives:
http://www.escribe.com/automotive/europ ... index.html
Yahoo! Groups Links
Jordan Grand Prix Limited
Tel: +44 (0)1327 850800
Fax: +44 (0)1327 850866
www.f1jordan.com
This message may contain information which is sensitive,
confidential and protected from disclosure. If you are not an
intended recipient of this message or any part of it, please
delete it immediately and telephone Jordan Grand Prix Ltd. You
should not disclose the contents to any other person or take
copies.
Any views expressed by an individual employee are not necessarily
representative of the views, policies or attitudes of Jordan
Grand Prix Ltd.
"Simpson, Karl"
PostPost by: types26/36 » Wed Nov 24, 2004 11:36 am
--- In ***@***.***, "Simpson, Karl"
coming on when the pods are retracted. With the headlamp switch
off, the lamps..............
Karl,
I dont think that is quite correct (or at least not on my cars)
The micro switch on the r/side (U.K driver side) earths the the main
headlight relay if the headlight switch is in the H/light on
positiion.
The micro switch on the l/side (passenger)earths the flashing
h/light relay if the headlight switch is in off or sidelight mode.
Although the flashing headlight is now illegal in the U.K.
64Elan/72Sprint/J.P.S.Europa
types26/36
PostPost by: "Roger Sieling" » Wed Nov 24, 2004 3:50 pm
David,
You will notice(unless DPO has been at it)that both the headlamp pod and the body bobbin are threaded 1/4" UNC. By having both threaded, you center the pod in it's opening and screw the bolts in so as to keep it centered in the opening. They work on the threads sort of like the steering trunnions. There is a special "thackery" washer on this too to keep them from unscrewing, although just this past year I had on that came adrift after about 20 years. I simply screwed it back in and checked all the others. If DPO has been at work and drilled out one or the other, well, you might want to investigate a helicoil or other thread insert repair.
>> ***@***.*** 11/24/04 5:20 AM >>>
questions.......
wrong place?
David
Yahoo! Groups Links
the system manager.
www.mimesweeper.com
"Roger Sieling"
PostPost by: TYPE45 at aol.com » Wed Nov 24, 2004 3:58 pm
Brian,
FYI, while rebuilding my steering column, I noticed that my Federal S4 came
from the factory with the flasher disconnected at the high beam lever switch.
I hooked it up and now I have the flasher function.
Frank Howard
'71 S4 SE
Minneapolis
TYPE45 at aol.com
PostPost by: types26/36 » Wed Nov 24, 2004 6:53 pm
--- In ***@***.***, ***@***.***e:
Brian,
lever switch.
Frank,
The flasher function (lever on column) is also disconnected on my
Sprint and S2, as far as I know this is normal because the
headlights are normally down.The flasher function I am refering to
is the mode when the headlights are raised (by vacuum)without the
headlights being switched on.If the headlights are raised with the
light switch in the off or sidelight position the headlights will
flash, as soon as the switch is moved to the headlight position this
cuts off the power to the headlight flasher relay and the main
headlight relay comes in.
As a footnote my Europa (same dip/main beam switch) is connected to
flash from this column switch.
Brian.
64Elan/Sprint/J.P.S.Europa
types26/36
PostPost by: TYPE45 at aol.com » Wed Nov 24, 2004 7:22 pm
In a message dated 11/24/04 01:00:05 PM, ***@***.***
writes:
<< If the headlights are raised with the
light switch in the off or sidelight position >>
Brian,
My headlights cannot be raised without the headlights coming on. On my car,
the micro switch that controls the headlights is the same switch that releases
the vacuum (fail-safe) allowing the spring to raise the headlight pods. By
hooking up the flasher switch at the high beam lever, I can flash my high beams
by pulling the high beam lever toward me while the headlights are on and
raised. Hope this makes sense to you.
Frank Howard
'71 S4 SE
Minnesota
TYPE45 at aol.com
PostPost by: Lincoln62 » Thu Nov 25, 2004 9:34 pm
David
Nothing should be needed between the surfaces. If you give it clearance
when you thread the bolts in the surfaces should never touch. They are
kept apart by being threaded onto the same bolt a couple of threads
apart. Pretty clever really.
Hope this makes sense.
Peter
66S2
David
Lincoln62
