Steering rack bush
Andrew,
I've done this. The steering rack bush is split along one side, and can be removed by gentle use of a nail or small chisel to curl it in and then pull out with a needle nosed pliers.
The new bush can be tapped in easily.
There is only one bush, 1 1/2" long, 23.5mm OD, 20.65 ID. The bush is steel with a perforated copper type inlay.
I failed to source a bush in the UK, and got it from Moss Motors California, USA.
$14.95 each. Get two or more and save on shipping !
Triumph Spitfire rack assembly and part nos can be seen at:
http://www.mossmotors.com/Shop/ViewProd ... exID=33018
Some time ago I fitted a "reconditioned" steering rack supplied by a well known UK Lotus parts supplier. When I took it for an Engineer's Report, everything was OK except for the bush. When I got the new bush and dismantled the rack, it was plain to see that the bush in the "recon" unit was badly worn but had been "bodgered" by peening the outer end with a hammer and screw driver to stop it rattling around. So always check what you're getting, or do it yourself to be sure !
Sean Murray
Sean Murray
Foxie - Coveted Fifth Gear
Norwich.
"Trust, but verify"
Ronald Reagan
----- Original Message -----
To: ***@***.***
Sent: Wednesday, October 20, 2004 6:16 PM
Subject: Re: [LotusElan.net] Steering rack bush
On Wed, 20 Oct 2004 15:27:26 +0100, "Sean Murray" <***@***.***>
wrote:
Thanks for the link Sean but do we get a name and shame or do we
condemn every UK supplier?
Martin
72/45
"Trust, but verify"
Ronald Reagan
To: ***@***.***
Martin
72/45
Laid off aircraft workers and aerospace engineers are keeping our cars
running at modest price! Hurray from Moss Motors and others. (I have no
knowledge of Moss but there are a lot of others out there.)
Ken
Ken
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
- lotuselan2
