Water pump
1 post
I have a S4 which is my daily ride in which I do about 5K miles pre year,I fitted a new water pump 6yrs ago along with a tooth belt drive conversion ,because of the toothed bely the tension can be minimal ,I can remove the belt without slacking the alternator.So no loads on the pump plus the car is in regular use.I am about to pull the engine to replace the clutch and at the same time I will replace the pump etc
Regards John 1969S4 DHC
Regards John 1969S4DHC
- triumphelan
1 post
