Zetec
Has anyone put a Zetec engine in a standard Elan? I am doing a body off
restoration on my 71 S4 FHC and wonder if this is the time to upgrade
to a Zetec and a five speed. My T/C is tired and even with its Weber
head the Zetec would be more power and less expensive to do. The shop
that supplies the type nine five speed transmission to birkin USA is
local and would help in that area. I would leave the rear end alone
except for my CV joint axles as the 3.77 gears would be ideal. I am
hoping to benefit from someone else that has tried this already. I have
all the information for the Spyder conversion to the Plus Two, but I
am looking for help with a standard Elan install.
Wayne
Wayne
- waschu2
Hi Wayne
I believe Spyder are currently developing a chassis for a Zetec Elan as they
mentioned about it at a talk they did for our local Lotus Club.
Clive
_________________________________________________________________
Want to block unwanted pop-ups? Download the free MSN Toolbar now!
http://toolbar.msn.co.uk/
Clive
- cliveyboy
Have you contacted Spyder cars? This is a standard conversion for them, these days (both baby Elan and Plus 2).
As far as I know, you can't do it with a standard pressed steel chassis, though - you will need one of Spyder's spaceframe jobs.
Martin Stuart
----- Original Message -----
To: ***@***.***
Sent: Monday, July 19, 2004 11:02 PM
Subject: [LotusElan.net] Zetec
Wayne
Martin Stuart
To: ***@***.***
Wayne
- Martin_StuartUK
Gidday Wayne, Bingo, I'm doing the Zetec swap. Same reason, more power, better econemy, cheaper and is a throw away item.
I assume you are in the USA, I'm in Australia.
Have a ' 70 +2s and a Lotus Cortina. I am part way through building a 1.8 Zon 45mm Webers, larger inlet valves, cams and bunch of bananas. This is anextra engine for the LC and another car we will race, the LC has 158HP TCas the original engine.
For the Elan I will use the 40's from its TC engine and more basic tune to around the 150 HP mark. I have photos of the Z in the Elan chassis during the Elan rebuild if you are interested.
Spyder did an excellent rebuild on there chassis with a Z but the engine finished up further foreward than the original.
IfI can help please drop me a lone.
See ya, Les
PS the TC engine is for sale for $4000-00 Australian.
To: ***@***.***
Sent: Tuesday, July 20, 2004 8:02 AM
Wayne
See ya, Les
To: ***@***.***
Wayne
- lotuselanman
Its not the Zetec that gives the problem, but the transmission. I recentlyevaluated a Zetec+T9 (from an XR4ti), and found that the rear of the transmission would not fit into the center section of the standard stamped steelframe. Engine height would probably be a problem, If I were going forwardwith this I would use a dry sump. HTH
Stan
To: ***@***.***
Sent: Tuesday, July 20, 2004 1:48 AM
Subject: Re: [LotusElan.net] Zetec
Martin Stuart
To: ***@***.***
Wayne
Stan
To: ***@***.***
Martin Stuart
To: ***@***.***
Wayne
- saarhus
I am considering doing this in Aaron's old plus two (and putting the twink
in a cortina). Does anyone know a source of knowledge in the US for this
endeavor? I am thinking fuel injected and a 5 speed, but I don't know what
tranny.
I am also thinking duratech rather than zetec as the duratech -- I have
heard -- are lighter and all alu. Is this true? Maybe that would offset
any forward movement of the engine due to tranny width.
P
tranny.
P
- pinsx3
But the engine has to fit behind the front cross-member/ vac. reservoir, and the existing twink hasn't any room to spare.
tranny.
P
the system manager.
tranny.
P
the system manager.
- Elan45
Peter,
I am leaning strongly towards the Duratec. In fact, I traded my Zetec evaluator for a Duratec 2.0l. Why?
The Duratec is all alu, and is about 50 lb. lighter than the Zetec.
The Duratec is designed for Ford and Mazda by Coswoth, and closely follows the design of their pure racing engines, DFV, etc.
The bottom end is Very robust with a deep bridal for the mains, and the sump heavily braced.
Chain driven cams, more compact and wear/breakage not a factor.
Engine is 19" from front edge of crank pulley to rear face, within half an inch of the TC. It fits!
Sump is convertible to dry sump, retaining the stiffening value of the original.
Exhaust and Intake are reversed, putting the exhaust on the right. Cooler feet for LHD versions.
The biggest problem is dealing with the unique starter mount.
This engine is available on the following:
Ford Ranger as a 2.3l
Ford Focus (PZEV) on SVT equivalents
Mazda 6 as a counterbalanced (removable) 2.3l
Mazda 3 as a 2.0 liter
More to follow. This is Ford's new World Engine. There will be millions of them out there.
Available in three sizes: 1.8, 2.0 (D-Mod size?), and 2.3l
An excellent source and knowledge is Gerry at
Dedonis, Gerry and Melodie
E-mail Address(es):
Business Information:
Title: Associate
Department: Racing
Company: Kansas Racing Products
Address:
1205 Manor Drive
Chapman KS 67431
USA
Phone: 785-922-6644
Web Page: http://www.kansasracingproducts.com
Notes:
Source for 2.0l Duratec engines
No personal or business relationship, just a happy customer
Stan A (mulling a minor upgrade)
tranny.
P
E-mail Address(es):
Title: Associate
Department: Racing
Address:
1205 Manor Drive
Chapman KS 67431
USA
Phone: 785-922-6644
Notes:
tranny.
P
- saarhus
The only (minor) problem is that for the first time since the late 50's
early 60's., Ford changed the bellhousing bolt pattern on the block on their
"european" 4 cyl engines , so the normal range of previously available
gearboxes will not be a straight forward fit. The kit car industry in UK are
however already onto it and making suitable ali bellhousings
Arno
Peter,
original.
of them out there.
E-mail Address(es):
Title: Associate
Department: Racing
Address:
1205 Manor Drive
Chapman KS 67431
USA
Phone: 785-922-6644
Notes:
twink
this
what
tranny.
offset
P
Arno
Peter,
original.
of them out there.
E-mail Address(es):
Title: Associate
Department: Racing
Address:
1205 Manor Drive
Chapman KS 67431
USA
Phone: 785-922-6644
Notes:
twink
this
what
tranny.
offset
P
- Arno Church
Peter -
Does this mean the car will finally get the Spyder Chassis I always
dreamed of?
Aaron
formerly '68 +2
currently '79 ESPRIT S2
St. Paul, MN USA
--- In ***@***.***, Peter Steilberg <psteilberg@m...>
dreamed of?
Aaron
formerly '68 +2
St. Paul, MN USA
wrote:
- elanplustwo
Gidday Peter
Lotuselanman here in Australia, call me Les for short.
Yes the Duratec is all Alloy, chain drive cams and is a Mazda designed unit. As for a g'box who knows. I suggest you liase with Spyder in the UK, theyare switched on. Maybe a Mazda group can suggest a box.
Good idead for the Twink into a Cortina. I have a MK2 LC which I use in club racing, 158 HP.
See ya, Les
To: ***@***.***
Sent: Saturday, July 31, 2004 7:08 AM
Subject: [LotusElan.net] Re: Zetec vs. duratec
Peter -
dreamed of?
Aaron
formerly '68 +2
St. Paul, MN USA
See ya, Les
To: ***@***.***
Peter -
dreamed of?
Aaron
formerly '68 +2
St. Paul, MN USA
wrote:
- lotuselanman
www.fordracing.com will sell you a new 2.3ltr duratec c/w injection for
$2295! OK it is out of a Ranger, but still develops 135HP and 153Ft/lbs of
torque.
I think if I was looking at a new engine, I would look seriously at
importing one.
David
-----Original Message-----
Sent: 01 August 2004 21:51
To: ***@***.***
Subject: Re: [LotusElan.net] Re: Zetec vs. duratec
Gidday Peter
racing, 158 HP.
See ya, Les
To: ***@***.***
Peter -
dreamed of?
Aaron
formerly '68 +2
St. Paul, MN USA
torque.
importing one.
David
To: ***@***.***
Gidday Peter
racing, 158 HP.
See ya, Les
To: ***@***.***
Peter -
dreamed of?
Aaron
formerly '68 +2
St. Paul, MN USA
wrote:
- davidallen
