Crown Wheel
There are no crown wheels in an Elan gearbox....the crown wheel is found in the diff.
And of all the things you could do to improve performance in an Elan, I would think lightning the crown wheel would be about number 1346 on the list.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
Not impossible, but tough to do in a hardened Crown Wheel.
Ian
Ian
- Ianashdown
Ian, Its a strange thing to want to lighten.
I could sort of understand it if the Elan had a live axle, but with IRS, the diff is sprung weight. In terms of rotational inertia, it has a small diameter, and even in 4th gear, is still geared down by the diff ratio. If improving acceleration is the aim, far better to lighten the flywheel or crank.
What was your thinking behind this?
Andy.
Andy.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
Andy8421 wrote:Ian, Its a strange thing to want to lighten.
Andy.
Apologies Ian & the OP, I wasn't paying attention.
Question still stands though, I did a bit of googling and all I could find was reducing overall diff weight to reduce unsprung weight, so I am still in the dark about why this would be done on an Elan.
32 Standard 12
32 Standard 12
- Andy8421
Having worked in the design office of a racing gearbox manufacturer I can give some input. We lightened the Crown Wheel on high end racing ‘boxes, F1 but not FF, because we lightened everything we could. But doing it while it was still soft, before heat treatment, is a very different proposition than after it is hard.
The amount that can be removed is quite small, and the effort very high. I think there are other places I’d look to save vehicle weight. The affect on rotating mass will also be small as a percentage of the rotating mass.
My advice, look elsewhere, there are easier places to lighten, even on an Elan!
Ian
Ian
- Ianashdown
