David vs Goliath Lotus Elan vs Corvette Grand Sport Track Ba
Great racing i wish I could build my Elan as light as that and that the Corvettes had their HP restrained as much as that. On a long straight in my class the Corvettes and other big V8's go past me as if I am standing still despite 180+ HP... their 600hp is somewhat overwhelming at above 200 kmh
On a tight track such as Winton here a little more chance against the Corvettes and Shelby Mustangs
Andy8421 wrote:Rohan,
Did all the heavy braking make the side stripe dip down at the front?
Ha Ha Ha The side stripe is horizontal when not braking but the original bad door fit puts a step in the line from the photo angle . In the end its a race car and I worry more about whats under the body
rgh0 wrote:If you look closely at the second photo you can see my nose hard down and left rear locking up and smoking as I turn left and brake hard to avoid the spinning cars .
there seems to be a shiny spot just outside your rear left wheel on that second photo...
the other problem with big american cars is that they take up all the space more easily ...
When you pass them without traffic for a block pass do you always go for the inside for fear they'll slide or do you go either way ?
S4SE 36/8198
nmauduit - Coveted Fifth Gear
nmauduit wrote:rgh0 wrote:If you look closely at the second photo you can see my nose hard down and left rear locking up and smoking as I turn left and brake hard to avoid the spinning cars .
I think the shiny spot is the smoke starting to come off my left rear wheel as it locks. Next to that is a black stripe from someone previously locking going into this corner.
Passing big wide American V8s in tight corners is an art I struggle to master. My friend in his S4 Seven is much better at it than me as he is a much better driver and the lighter Seven, wider track and his 20 extra Hp to around 200hp in a 1600 cc engine thats possible on the absolute development limit with the better exhaust and more radical cams possible in a lighter Seven makes it more doable also.
I just take the opportunities when presented and try to run under them when they go wide out of a corner, like I was doing in the photo. I dont like to do passing under brakes as its to unpredictable and I have seen to many people who try it come to grief. Going around the outside is hard in most corners as grip gets worse the wider you go. Every corner presents potential to pass depending on the race circumstances so no absolute answer
What weight do you have to run at?
Dave Hughes
Dave Hughes
Dave Hughes
S2 26R
Elan DHC Sprint
S2 26R
Elan DHC Sprint
bigvalvehead - Third Gear
bigvalvehead wrote:Rohan
Dave Hughes
No specific weight but the car is expected to be around its production weight and there are a limited list of allowed modifications that will affect weight away from the original production weight. Mine is 700 kg and I add a significant amount on top of that
No specific lightweight components are allowed as used by the 26R and all trim, electrics etc are required to be present and functional. The roll cage makes up for removing the spare tyre but in a FHC not much more can be done. Bumpers are allowed to be removed but in an Elan that saves you about 3 KG so i dont bother. Side and rear windows can have the glass replaced with polycarbonate and I have done that for the rear.
If you race a convertible you can remove the top and front screen and side windows so something like an MGB can actually legally shed about 100 kg after they remove all the glass and bumpers.
An S2 Elan would be able to race a lot lighter and be more competitive but at least I am much more comfortable if it rains
Another reminder why we love these little gems so much
- persiflage
