Trunnions. Angles and greasing
The balljoint isn't required if a different method of aligning the trunnion can be used. The elan (and all trunion style suspension by design) has parallel inner pivot axis' so the amount of bind doesn't change when articulated. All that needs to be accomplished is that the trunnion axis needs to intersect the upper balljoint centerpoint.
Scott
45/9011
Hawkestone, On, Ca
45/9011
Hawkestone, On, Ca
- snowyelan
snowyelan wrote:The balljoint isn't required if a different method of aligning the trunnion can be used. The elan (and all trunion style suspension by design) has parallel inner pivot axis' so the amount of bind doesn't change when articulated. All that needs to be accomplished is that the trunnion axis needs to intersect the upper balljoint centerpoint.
This what I have done with a re engineered , offset trunnion polybush.
The shock on a 26r has a spherical bearing at its lower end so no extra stresses there.
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
It would work if it replaced the bushings. Fitting it in with the upright thread so close could be an issue.
So the bore of the trunnion is 3/4".
OD around 28.5mm.
But smallest spherical rose joint (then with 1/2" bore for bolt) is 7/8" = 22.2mm.
For fitting this size the trunnion bore would need to be bored out from 3/4" to 7/8"
That would leave a wall thickness of around 3.1mm ... not much for brass.
- Vali
If you have access to a lathe and mill I suppose you could re-bore the trunnion slightly bigger with an angular offset, reface the ends, then turn up custom bushings to suit the larger bore and slightly shorter trunnion bore (thicker tophat rim). As my old drafting teacher would say, lots of ways to skin a cat.
Scott
45/9011
Hawkestone, On, Ca
45/9011
Hawkestone, On, Ca
- snowyelan
https://www.limora.com/en/suspension-li ... 18041.html
This might be a solution, too. Available in 3 degrees, too.
Bore out to 3/4" and press the Elan bushes in.
I will look into this. Might work out.
- Vali
Vali wrote:https://www.limora.com/en/suspension-link-trunnion-1-118041.html
Good spot. Why not just use the TR4A polybushes? The bolt may be smaller but if it's big enough for the heavier car it's probably OK for an Elan. I reinforced the holes in the wishbones anyway so a smaller hole could be made in them if needed.
I assume the 2 deg 40 mins would be added to the 3 deg the chassis should have, which would be about right.
I looked at the TR4A king pins and I assumed the threa into the trunnion would be the same as in the Elan?
How much depth was there in the botton plate of the trunnion for you to thread your grease nipple into and did you have to cut down the other side of the nipple to avoid touching the bottom of the king pin?
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
I'm not sure if this has been discussed, but I am of the opinion that you do not use a typical grease gun with grease to lube the trunnions. Regular grease is too heavy - thick to do any good in a trunnion. If you have removed a used trunnion before, and have had to use a small blade screwdriver to work out the goo between threads on the upright, you know what I'm trying to describe here. Cleaning the inside of the trunnion is a whole different exercise.
What I would like to bring forward is to use a more fluid gear lube. This requires a different type of 'grease gun' to inject via the grease nipple, but I've used it on my Triumphs for nearly 20 years now and have had no failures or binding. I submit the picture below for consideration.
Mike N
+2 50/1974
65 TR4A IRS
The Planning Fallacy refers to our tendency to underestimate the time it will take to complete a future task despite knowing that similar tasks have taken longer in the past.
+2 50/1974
65 TR4A IRS
- Mike+2
661 wrote:How much depth was there in the botton plate of the trunnion for you to thread your grease nipple into and did you have to cut down the other side of the nipple to avoid touching the bottom of the king pin?
I measured the plate with 2mm.
And I tried to cut down the nipple thread but then the spring inside just popped out. Cutting down the nipple thread is not recommended then.
Nipple thread is 4mm long so it sticks out in inner trunnion 2mm.
King pin had a space of 6mm I believe, thats enough space.
If possible use a rivnut or similar like Triumph must have let done to theirs.
https://rimmerbros.com/Item--i-133839
- Vali
Mike+2 wrote:I'm not sure if this has been discussed, but I am of the opinion that you do not use a typical grease gun with grease to lube the trunnions. Regular grease is too heavy - thick to do any good in a trunnion. If you have removed a used trunnion before, and have had to use a small blade screwdriver to work out the goo between threads on the upright, you know what I'm trying to describe here. Cleaning the inside of the trunnion is a whole different exercise.
This has been discussed many times - oil, semifluid grease , normal grease. They all work.... some better than others in differing conditions. I wont repeat myself except to say normal modern grease is probably best IMHO despite what Triumph said originally 60 years ago... time and technology moves on.
I agree with Rohan, modern grease is it.
I wanted it strong, so I took solid uprights.
But how to grease then?
I spot welded and soldered nuts to the trunnion bottom for grease nipples.
Works fine.
But propably my future project could be some Caterham uprights and home made lower adapters for spherical joints.
Regards, Christian
Works fine.
Regards, Christian
- ChrisD
