Does a TTR 26R chassis need further strengthening?
As above really. I have a new TTR 26R chassis. I intend to use it for racing. The chassis has what I would consider to be all the 'usual' reinforcements. Is there anything else I should consider doing to it before sending off to the powder coater?
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
I can give a couple of pointers
First, I'd make sure it fits the body shell - they're not always compatible and then I'd drill the major mounting points and tap threads where appropriate.
There are two areas in particular where I'd do some extra work - the first is the engine mountings where I would weld on some 3/8" UNF (you could use 5/16") nuts on the backside - makes installing and removing engines so much easier.
The second is the rear mounting holes for the chassis on the rear turrets. This where the roll over bar attaches and also where the seatbelt pick up point is. FIA and MSA now seem to require the bolt to pass right through the chassis and be secured by a nut on the back side. (TTR sell the mounting kit) To this end, I'd install a tube (minimum 3/8" preferably 7/16" id) to allow the bolt to be securely tightened without crushing the turret.
So far as I can remember the rest of the chassis is good and I haven't had any failures on mine.
Also if you're planning to race it, I think it's better to paint with two pack paint (don't bother with lacquer) than powder coat as it makes touch ups and repairs so much easier. I do accept that the finish is not so durable and does rub off if you go in the kitty litter.
Hope that helps
Paul
Hope that helps
Paul
Turning money into noise!
- toomspj
Thanks Paul, that's very interesting.
I think I can live with the engine mounts but the rear turret mount is new to me. I guess an aluminium tube spacer to fit could be added at a later date.
Is there a definitive 'thou shalt' FIA list? ( this is a slight thread drift!)
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
Probably too late to register, but I agree w/ Paul about welding in a tube in the rear strut for the mounting. MMuch stronger! I also agree w/ 2-pac paint as opposed to powder coat. I do disagree w/ him on durability of powder coat. One scratch in the PC and it will fail It seems to not bond to the steel and eventually will peal off w. lots of rust underneath it.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Elan45 wrote:I do disagree w/ him on durability of powder coat. One scratch in the PC and it will fail It seems to not bond to the steel and eventually will peal off w. lots of rust underneath it.
I'd strongly second that opinion after just replacing 160 feet of rusted out, powder coated, sub frame tubing on my older motorhome. They have improved the durability over the years but I still wouldn't trust it where it will be subject to scratching and rock chips. One chip and the water/rust run under the coating further lifting the coating and exposing the metal. A good paint job does a much better job IMHP.
Powder coating wasn't developed to be a superior finish, but to provide a finish process that would comply to ever tightening air quality regulations faced by manufacturers and lower costs (go figure). A little history here:
http://www.cggc.duke.edu/pdfs/Brun_Goli ... option.pdf
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
You can live with the engine mounts without nuts welded on - I have that situation on my current car/chassis. But, if you race the car, the engine is in and out like a yo-yo (clutch, gearbox, exhaust, engine, access to chassis). And life is so much easier if you don't have to try and wedge a spanner on the backside with an exhaust manifold that has got pushed up against it.
As for alloy tube in the rear turret - you probably could do that but a thin walled steel tube would be much easier and if done before painting it would be straightforward. Downside is that you have to fit it to body first.
I guess i was being generous to the powder coating durability. I never use it on race cars for the reasons the other guys have stated - once breached you don't know what corrosion is going on until too late.
Oh, one other thing. Make sure the gearbox mounting has 4 captive (5/6" UNF) nuts welded on. I think most of the Gartrac chassis come with them. If not, you'll be cursing when you need to drop the box - again, it's possible without if you have special thin spanners but a complete and utter pain!
Good luck,
Paul
Good luck,
Paul
- toomspj
Thank you all.
Paul, I see your point regarding the engine mounts, I'll weld on some captive 3/8 UNFs .
The project presently is to make a rolling chassis and I don't have the bodyshell. I'll therefore have to cross the rear turret issue at a later stage.
This business about the paint has really unsettled me.
Plan A was to POR15 it , but with time and reading I've gone over to PC. I've spoke to various manufacturers and technical advisors. The consensus seems to be a 3 coat system. Zinc etch primer, epoxy primer, polyester top coat.
With 2 pack it would be wet applied and would be difficult to get into those difficult to access box sections. What primer did you use? I understand the ease with which you could touch up repairs.
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
Ditzler (PPG corp) DP40/ DP401. Great stuff. I've been using it for over 30 years on my Elans, my Eleven, my Falcon bodied Austin Healey Sprite and my Lotus 20/22. It has been re-fornulated over the years as it used to mix 50-50, now is some other proportion. I believe Ditzler are now recommending it on fiberglass.
'67 Elan S3 SS DHC
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
TTR offer a service to coat the chassis with stove enamel paint - what views and experience do people have of that solution?
David
David
David Rose
1963 S1 - Bourne bodied
1965 S2
1966 S3
1969 Europa - 210bbhp by Banks
1965 S2
1966 S3
- dunclentdr
When I got my chassis back from being modified to above 26R spec, I rust treated the bare metal bits then gave it two coats of Frost's Extreme Chassis Black:
http://www.frost.co.uk/automotive-paint ... -397g.html
When it came time to weld in the roll cage we tried to clean it off with a drill driven wire brush but it wouldn't touch it. Had to resort to paint stripper and even this took at least two applications. Amazing stuff, IMO.
The roll cage will be getting a couple of coats.
- stevebroad
batfish wrote:Regarding fia specs, adjustable spring platforms are definately not allowed when applying for new papers
Regards andy
Thanks Andy,
I've been following this. I'm sure the inventive mind will find a way around this.
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
Hi Andy
What's adjustable spring platforms got to do with this post?
But since we're off topic, my experience is that most race series will allow adjustable platforms. You are right that to get FIA papers you will need fixed platforms which is fairly easy to achieve - just a bit of buggering (I think I can use that word as not in US dictionary -I'm sure Wickey will advise) about.
I've also been told by an eligibility scrutiniser that holes in perspex windows aren't allowed as they weren't homologated - even though people drilled holes in everything in period!
Strange times we live in.
- toomspj
batfish wrote:Paul
In the previous posts Graeme ''asked Is there a definitive 'thou shalt' FIA list? ( this is a slight thread drift!)'' and so I answered him
Andy
No harm in a bit of drift. I need to soak up as much information as possible. Thanks to all contributors.
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
