fia appk seats
Wed Mar 05, 2014 6:24 pm
by alan d bell
we are nearing the end of the rebuild of the gts elan but are having difficulty finding suitably narrow seats, eg cobra historic fia are 51.5 cm at the shoulder and the base may not fit between the bottom cross tube of the roll cage and the raised part of the floor. any ideas or past fittings please.
Re: fia appk seats
Wed Mar 05, 2014 7:07 pm
by trw99
Re: fia appk seats
Thu Mar 06, 2014 9:31 am
by vstibbard
Hi, ive Fitted an fia spec tillet B6F seat in my 26R that comes in two widths, one all carbon allows the edge of seat to be removed. The normal verson needs the edge for its strength, still light and beautifully made, really comfortable and makes you feel like you are part of the car.
Cheers V
Re: fia appk seats
Fri Mar 07, 2014 8:13 pm
by alan d bell
thanks guys I am talking to motor drive seats who make a seat specifically for the elan fie approved and starting at ?360,amazing
Re: fia appk seats
Fri Mar 07, 2014 9:38 pm
by toomspj
I have had two Motordrive seats, for my S1 Roadsports and also for my 26R. They are superbly comfortable and fit easily in the Elan.
In fact I had originally put a Tillet seat in the 26R, but changed to the Motordrive seat as it felt more in keeping (visually at least)
For the 26R I changed the floor to being flat simply because that way I could get exactly the right seating position and also make the mounting very secure (attached to Chassis and side-bars).
Good luck with it - Motordrive are a really nice business to deal with.
Paul
Re: fia appk seats
Fri Mar 07, 2014 10:02 pm
by patrics
Hi Alan,
I also have a motordrive seat and agree with Paul as I also changed my floor to get a good seating position. You can remove the inclined side bits and remove the raised cross piece behind the the standard mounting points.
How much trouble you have fitting it will depend on how tall or short you are - taller being easier.
Hope this helps
Re: fia appk seats
Sat Mar 08, 2014 10:43 pm
by twincamman
I guess the FIA does not want wide bottomed people to race
..ed
Re: fia appk seats
Thu Apr 24, 2014 6:05 pm
by Greg Cozier
Please explain what is involved in changing the floor to flat. I'm building a rally car and have used motor drive seats for decades so could do with a proper padded rally seat.
Re: fia appk seats
Fri Apr 25, 2014 8:44 am
by alan d bell
thanks for all the help I now have a pair of motor drive seats fia approved for three more years,
Re: fia appk seats
Fri May 02, 2014 8:33 am
by Richard hall
Greg Cozier wrote:Please explain what is involved in changing the floor to flat. I'm building a rally car and have used motor drive seats for decades so could do with a proper padded rally seat.
i am also building a Fia spec Elan for rallying, any information out there on setup, brakes,seat mountings etc ?
Re: fia appk seats
Sun Jun 07, 2015 9:49 am
by Richard hall
Build going well and now looking to sort out front brakes, looking at the 26r set up is it a big improvement ?
also looking for door hinges S3
Re: fia appk seats
Mon Jun 08, 2015 7:42 pm
by CBUEB1771
Richard hall wrote:Build going well and now looking to sort out front brakes, looking at the 26r set up is it a big improvement ?
We are going well off topic here but are you asking about 26R front calipers, a dual brake master cylinder arrangement or both? The Girling AR calipers used on the 26R are aluminum and quite a bit lighter than the iron Gilding type 14 calipers used on the Elan. The AR calipers also have larger diameter pistons, 2.00 inch v. 1.88 inch and therefore will give about 14% more braking force at the caliper for a given force at the brake pedal, all other variables held constant. The ARs will also shift the front/tear bias a bit more to the front. The AR and NR calipers (used at the rear) do not have dust seals, fine for circuit racing but perhaps less so for rallying.
