Dry Sumped Racing Engine ideal oil pressure
jkolb wrote:Johnson Pump Question
I have a Johnson pump (Mick) installed and just had a complete failure of oil pressure on start-up. Jackshaft is intact (engine ran until I shut it down), tank is full of oil, and I had not broken any of the line connections since the previous time the engine had run (7 days previous). Only about 25 minutes of time on the engine, none at high load. Engine is running 20-50 wt Valvoline racing oil and the oil was preheated to 120F.
Any thoughts? I have verified that the gauge is operating and am about to pull the pump which, as you can imagine, is no fun!
Jerry
How'd you end up with the pressure/pump Jerry??
James
Elfin Monocoque (Twin Cam)
[email protected]
[email protected]
SJ Lambert - Fourth Gear
found a nice piece the other day on the web from an engineering company.. now lost...
but this one is a little less nice, though fun for us engineers to decipher:
http://www.substech.com/dokuwiki/doku.p ... al_bearing
thanks to all for their empirical observation on oil pressure.
- foggy
Hi Roy,
My 26r was delivered new from factory with dry sumped Cosworth engine, which is still fitted, numbers all match factory records, I'd be very interested in getting a copy fo the Cosworth document that you have extracted the 2 pages from if possible.
V
V
- Vaughan
Vaughan,
Here are the other three pages and a cover sheet. You should be able to 'save as' but if you can't save them from here I will email them.
The handwritten notes are mine. The cover sheet is from '82 when I bought a piston ring set from them. (?44 including post and packing!) The spec sheets are dated '75 by the looks.
Roy
'65 S2
'65 S2
elj221c - Fourth Gear
[email protected]
[email protected]
