CAMSHAFTS
• Page 5 of 5 • 1, 2, 3, 4, 5
SJ Lambert wrote:How much torque do the best camshafts produce days?
I'm planning on using a TILTON clutch with a 200 ft/lb capacity, I reckon that in an open wheeler, that it will be fine. I don't want to use a heavier clutch because besides being "heavier" I'd have to move the slave cylinder from a remote mounted one to a bobbin replacing one.
I think 200 ft/lb sounds plenty. You will be struggling to get 140 ft/lbs out of a 1600 twin cam
you will be like Corvette owners with an over developed left foot muscle causing you to walk in small circles all day----oh yes NEVER put youself in a situation where you say ' I WONDER WHAT WILL HAPPEN IF I TRY THIS '---ed
rgh0 wrote:SJ Lambert wrote:How much torque do the best camshafts produce days?
AP offer a few green rated (144-161 ft lb ) clutch assemblies, the most expensive (and I presume the lightest) is an A ring type with an alloy cover (that's 300 grams lighter than the same thing with a steel cover), the other type is a lug type (like the Tilton one that I've already got). The light weight AP one may get a run on the 90 tooth flywheel.
James
Elfin Monocoque (Twin Cam)
[email protected]
[email protected]
SJ Lambert - Fourth Gear
rgh0 wrote:...................
I recently did some back to back tests on 2 otherwise identical race engines one running 45DCOE's with 38 mm chokes and one running 36mm chokes and had no difference in maximum power output. I would only consider going to 38mm if you have a very light car (seven or open wheeler) as the risk of low speed response loss possibly balances any potential for top end gain.
I better get a set of 36s for mine - as John also recommends 36 and up for mine too.
[email protected]
[email protected]
I didn't realise that chokes in the odd sizes were offered these days, 37s and 39s are obtainable for 45 DCOEs in Melbourne at the moment.
[email protected]
[email protected]
Weber Performance are doing them - they may well be enlarging 36s.
I've had a set of 33s for DCOE 40s gathering dust for ages, but hadn't seen the odd sizes for the 45s.
[email protected]
[email protected]
Users browsing this forum: ericbushby, mark030358, Spyder fan and 12 guests
