Camber with Modern Tires
Sat Jan 30, 2010 5:19 pm
by jkolb
Lotus recommended 1 degree front and 2 degrees rear camber for the 26r. As this recommendation was made for bias ply race tires, is there another recommendation for today's radial ply race tires?
Thanx
Jerry
Re: Camber with Modern Tires
Sat Jan 30, 2010 11:33 pm
I run around minus 1.5 front and minus 1 rear
Sun Jan 31, 2010 4:53 pm
by toomspj
Can you define what you mean by modern tyres? Yokohama's for instance like at around 3 deg neg f+r . But it depends on how your car is set up and what you're doing with it.
Paul
Sun Jan 31, 2010 11:44 pm
by jkolb
I just mean a DOT legal radial with tread.
Jerry
Mon Feb 01, 2010 7:36 pm
by rennbaron
Yokohama A021R, A048 and A032-R are still roadlegal...
Christian
Tue Feb 02, 2010 4:26 am
The setting i gave before for my setup is with Yoko A-032R previously and Dunlop DZ3 currently both in 175 /60 x 13 size.
The front could use more static negative camber given the roll geometry but my class racing regulations allow a maximum of minus 2 degrees static setting. As a result i overload a little and wear out quicker the front outer edges more than is desirable
regards
Thu Feb 04, 2010 1:37 pm
by cabc26b
Hi Jerry,
This is an assumption based on your question but why are your looking to run radials ?
George
