Re: Racing High Lift Valve Springs
Posted: Sat Mar 05, 2016 10:30 pm
You cant really set up the valves and springs until you know what cam and cam base circle you are going to use. I doubt your set up will work with long valves and 3 mm shims under the springs as i know of no spring set that will work with that sort of shim and a high lift cam except perhaps the QED Q55 springs which are a very unusual design compared to most.
regards
regards
