Removing diff & hub shafts
Hi All,
I am considering replacing my diff output shafts and hub shafts while the body is off the car.
The book makes it sound easy, says to "remove the clips and slide the shafts out".
How easy is it to do this as I have removed one of the clips and knocked the shaft with a rubber hammer to no avail.
Mark.
Mark.
- Bits
I use a slide puller and sometimes it requires heating the case around the axle bearing.
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
I used a slide hammer for this. It shouldn't take a lot of force if it is applied along the shafts axis. There was loctite on my bearings OD so I also used a propane torch to gently warm the casing.
The bearing bore should be cleaned before attempting to get them separated. Any bit of grit will cause friction and scoring.
Edit: Seniorchristo beat me to it, same approach though.
Scott
45/9011
Hawkestone, On, Ca
45/9011
Hawkestone, On, Ca
- snowyelan
I recently changed my ouput shaft bearings and seals with the body on and diff in situ and it not a nice job to do whilst lying on your back!
I made up a small sliding hammer, see below, and warmed the diff casing up for a few minutes with a hot air gun and the shaft then came out quite easily. You will also need to warm the casing up when you refit the shaft.
I note you have the rotoflex flexi safety pins sticking out of your output shafts which I didn't have so you may have to either cut them off or make up an alternative version of the sliding hammer.
Alan.
Alan.
'71 +2 S130/ 5speed Type9.
- alanr
Mark,
My diff (like most things on my Elan) was heavily corroded, your photo looks nice and clean, and I think it should come apart as described by others, I needed a new casing. I could not get the circlips out without damage to the grooves. On reassembly I used stainless circlips, hoping for an improvement. When reassembling the bearings into the casing, you may need to use force, and this should be applied to the outer ring of the bearing. I used a piece of pipe of the correct diameter with three notches cut into it to straddle the three arms of the output shafts, to help keep the bearing square to the bore in the casing.
Hope this helps,
Richard Hawkins
Hope this helps,
Richard Hawkins
- RichardHawkins
Good evening Richard,
There is a possibility that by using stainless clips you have improved it worse!
As I understand it stainless steel and aluminium are a long way apart on the galvanic scale and in the presence of moisture they can start a fight and cause corrosion to one or both of them.
It may be worth checking this out.
Just a thought.
Eric in Lanzarote
1967 S3SE DHC
Just a thought.
Eric in Lanzarote
1967 S3SE DHC
- ericbushby
I used ordinary circlips which I think are fine, a bit of a soak with something before removal and all will be good.
The problem is these circlips are very strong and you need long and strong circlip pliers to get them out and back in. I think not using substantial circlip pliers and then not squeezing the circlip hard enough is when the groove gets damaged.
Alan.
Alan.
- alanr
Eric,
Thanks for the warning.
Richard Hawkins
Richard Hawkins
- RichardHawkins
You shouldn't have to cut the safety pins off your shafts, you can just use longer bolts and 3 spacer tubes and your slide hammer adapter can be flat.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
